Posted: Sat Jun 17, 2023 6:57 pm
by Gregski
MattsAwesomeStuff wrote: ↑Sat Jun 17, 2023 6:08 pm
Buy a 3/8", drill it out, tap it for 7/16". Easy. Only takes a few hours and is easy to screw up.
makes sense
Posted: Sun Jun 18, 2023 1:26 pm
by Gregski
Let's see where we can shove these?
Posted: Sun Jun 18, 2023 1:29 pm
by Gregski
six holes each and Home Depot still got em wrong, so I had to moke some modifications, I can't stand aftermarket EV conversion parts
Posted: Sun Jun 18, 2023 1:30 pm
by Gregski
a little trial fit
Posted: Sun Jun 18, 2023 1:31 pm
by Gregski
the angle triangle is just a prop
Posted: Sun Jun 18, 2023 1:33 pm
by Gregski
time to poke some holes
Posted: Sun Jun 18, 2023 1:34 pm
by Gregski
that's not too shabby
Posted: Sun Jun 18, 2023 2:26 pm
by Gregski
Posted: Mon Jun 19, 2023 12:47 pm
by Gregski
in keeping up with the current social media trends I now break my silence on the Tesla Model S water pump installation
one or two of the many part numbers
PN: 6008047-00-E, 1035348-00-G
so I call this the Tesla Model S water pump but I think someone else makes it for them and the only thing that makes it Tesla is this neat rubber bracket
Posted: Mon Jun 19, 2023 1:23 pm
by Gregski
"Due to the thermal expansion of rubber coolant hoses, LPE does not recommend using
worm gear clamps to clamp the hoses to the intercooler pump. Because worm gear clamps
do not apply constant tension to the hoses, the hoses can leak when exposed to cooler
temperatures. LPE recommends the use of the OEM constant-tension clamps or spring
clamps as superior alternatives to the standard worm gear clamp."
Posted: Mon Jun 19, 2023 1:31 pm
by Gregski
What will this pump cool?
the Lexus transmission (it has two electric motors inside of it)
the Lexus Inverter (think carburetor/distributor combo)
the Chevy Volt battery charger
FYI the Chevy Volt DC DC Converter (aka alternator) is air cooled and does not require the water pump action
What? I like to watch.
Posted: Mon Jun 19, 2023 1:44 pm
by Gregski
so tested it out with a bucket, it worked
plumbed it on the truck, it didn't work
Posted: Mon Jun 19, 2023 1:58 pm
by Gregski
Time to troubleshoot
of course the place that sales the 3/4" I.D. clear hose by the foot was out of the 3/4" I.D. clear hose, so off to Home Depot I went (like a fool) and instead of buying just one foot of it I had to buy a spool, at California prices mind you !
Posted: Mon Jun 19, 2023 2:04 pm
by Gregski
so now we can see what is going in to the water pump as well as what is coming out... we shall call this Science !
Posted: Mon Jun 19, 2023 2:10 pm
by Gregski
don't ask me how I got rid of that air bubble as this is a family friendly forum
Posted: Tue Jun 20, 2023 1:44 pm
by Gregski
with the plumbing done and the pump pumping it was time to affix the first gen Chevy Volt onboard battery
unlike it's cousin the DC DC converter the charger's feet are flat on the aluminum plate so I couldn't wedge a nut under them to hold the bolts in the plate so I had tap the aluminum plate so that I could screw them in, last thing we need is bolts falling down on a 351 volt battery pack
Posted: Tue Jun 20, 2023 1:50 pm
by Gregski
after two trips to ACE Hardware where I bought the wrong length bolts twice, I finally managed to get the 1 1/4" long ones that would not bottom out on the acorn nuts, cause that's what matters most here when building an electric vehicle and is time well spent
also that "water proof" battery tray lid now has more holes in it than fancy Swiss cheese
Posted: Tue Jun 20, 2023 2:31 pm
by Gregski
had to do a little minor repair on the first gen Chevy Volt onboard battery charger, the coupling for the regular car battery cables was loose and I needed to get inside to turn the nut on it
Posted: Wed Jun 21, 2023 1:25 pm
by crasbe
Gregski wrote: ↑Mon Jun 19, 2023 1:58 pm
Did you check how the clear hose behaves when it's warm/hot? I had variants that became very soft. From what I could find, the Everbuilt brand you have there is good for 65°C (or 150°Bananenheit).
Not much reserve I guess, especially in California, where the ambient temperature reaches 2/3 of the maximum rating already.
Posted: Wed Jun 21, 2023 1:33 pm
by Gregski
crasbe wrote: ↑Wed Jun 21, 2023 1:25 pm
thank you, it is not meant to be a permanent solution, I even noticed that the self gripping clamps don't contract enough to grip the 5/8ths one that connects the charger to the inverter (highest hose in the pics) so I will remove these as soon as I am ready for my first test drive, I just needed something on there to troubleshoot why the pump was not pumping
Posted: Wed Jun 21, 2023 1:34 pm
by Gregski
Just took that old B&M shifter off the shelf
I hope to install it all by myself
Today's aftermarket ain't got the same soul
I like that old time rock 'n' roll
Posted: Wed Jun 21, 2023 1:49 pm
by Gregski
not your father's B&M
Posted: Wed Jun 21, 2023 1:51 pm
by Gregski
So I'm thinkin' something like this, should be totally fine as long as I can grow my right arm another 6"
Posted: Wed Jun 21, 2023 1:57 pm
by Gregski
WARNING: these next few updates of my sheet metal fab skills will make Damien Maguire's reverse engineering 3 hour long videos seem like sit on the edge of your seat riveting !
