Page 26 of 32
Posted: Sat Oct 30, 2021 9:25 pm
by m.art.y
Hi, could somebody clarify if US versions of tesla chargers can function as 3 phase after control board replacement and any chance to get full power out of them in Europe? Thanks
Posted: Mon Nov 01, 2021 7:26 pm
by coleasterling
You guys have any source for the board connector: SM24B-CPTK-1A-TB(L) ? I can't find one in stock.
Posted: Tue Nov 02, 2021 8:46 am
by EV_Builder
m.art.y wrote: ↑Sat Oct 30, 2021 9:25 pm
Yes only 3phase + N is needed.
Tesla SDU main contactor not closing
Posted: Sat Nov 06, 2021 12:00 am
by qmedia2651
My board v5 with commercial firmware have to reset button to start led to Blink wifi working after reset but if power off must reset again.
Any one can have any input on this matter.
Qmedia from Orlando Florida. Working on 1991 300CE Mercedes conversion project.
Posted: Sat Nov 13, 2021 7:24 am
by retkimora
Hello,
I have a v3 logic board in my hands. It doesn't output anything to serial monitor. In Arduino IDE I've compiled v3 and v4 code and both upload fine to the board but serial monitor stays blank. Speed is set to 115200. Putty throws error message when trying to connect to the board. Board worked out-of-the-box when installed in the charger but we could never configure its parameters. We've tried two different computers and several usb cables. Any help is appreciated. If you think the board is shot we'll just buy a v5 board.
Posted: Sat Nov 13, 2021 11:03 am
by EV_Builder
retkimora wrote: ↑Sat Nov 13, 2021 7:24 am
Can you elaborate on that sentence?
Posted: Sat Nov 13, 2021 1:23 pm
by retkimora
EV_Builder wrote: ↑Sat Nov 13, 2021 11:03 am
Sure thing. It was bought directly from Damien two years ago, I think. It was never configured by anyone (except Damien) but installed directly inside a gen2 charger. Seemed to work as charger was wired directly to a charge port. Now I'd like to check its settings so we could proceed on some proper charging of battery.
Posted: Sat Nov 13, 2021 2:42 pm
by EV_Builder
Ok so you opened up the cover and soldered in the USB connector and plugged in the laptop?
Posted: Sat Nov 13, 2021 3:59 pm
by catphish
I'm considering buying a Gen 2 charger, but I am worried that there is no way to obtain the SM24B-CPTK-1A-TB(L) connector. Does anyone have any of these spare? Would I be better off hacking in a different connector?
Posted: Sat Nov 13, 2021 6:00 pm
by EV_Builder
catphish wrote: ↑Sat Nov 13, 2021 3:59 pm
You can desolder it and reuse it from the Tesla board.
Posted: Sat Nov 13, 2021 6:10 pm
by catphish
EV_Builder wrote: ↑Sat Nov 13, 2021 6:00 pm
Thanks! Not sure why I didn't consider that! I'll give it a go.
Posted: Sun Nov 14, 2021 2:05 pm
by retkimora
EV_Builder wrote: ↑Sat Nov 13, 2021 2:42 pm
USB connector was already there. Arduino IDE recognizes the board and I can upload stuff there.
Posted: Tue Nov 16, 2021 9:00 pm
by Roadstercycle
I just received my newest Gen 2 board. Couple questions. Is the new firmware in it? The other question is about the 30 pin connector. I ordered the suggested part number but when receiving it the number 1 terminal has been deleted. Damien uses the number one pin so can I just flip it around so the missing pin is on the opposite end? It looks like there's no connections there if it's just a 2 layer board.
Posted: Wed Nov 17, 2021 12:03 am
by EV_Builder
Yes that's correct. You flip it.
Posted: Wed Nov 17, 2021 12:07 am
by catphish
Roadstercycle wrote: ↑Tue Nov 16, 2021 9:00 pm
Yes, see this image from the wiki, pin 30 is not needed:
Posted: Fri Nov 19, 2021 11:52 am
by m.art.y
Hi, I know Tesla and some people here are using 2 gen2 Tesla chargers in parallel for 20 kw charging power. Is it possible to do the same with Tesla gen3 48A US version chargers for use in Europe with 3 phase? Main question is wiring - since gen2 chargers have 3 modules inside wiring 2 chargers for 3 phase in parallel is no problem. I have seen conflicting info whether gen3 48A US version has 2 or 3 modules and I am hesitant to open one if I can't use 2 in parallel since I want a 20 kw AC charging setup. If indeed there is only 2 modules the wiring does not work out for charging on 3 phase or does it? Thanks!
Posted: Mon Nov 29, 2021 1:54 pm
by janosch
We considered drilling and tapping an extra bleed screw into our Gen2 charger because of our positioning (sideways & upright & high in the cooling circuit).
So we X-Rayed one!
Added picture to the wiki:
https://openinverter.org/wiki/GEN2
Posted: Mon Nov 29, 2021 2:01 pm
Interesting! So current flows top to bottom I guess. Grid filter (2 common mode chokes) PFC stage (two more chokes), TO-247 transistors mounted on the side of the module. Then capacitor bank, transformer, output filter.
Posted: Mon Nov 29, 2021 4:37 pm
by joromy
janosch wrote: ↑Mon Nov 29, 2021 1:54 pm
Not so easy to see the waterflow.
I found this
- coldplate2.JPG (18.24 KiB) Viewed 11388 times
Posted: Mon Nov 29, 2021 4:45 pm
by janosch
joromy wrote: ↑Mon Nov 29, 2021 4:37 pm
I found this
Wow this is great! Do you have a link to the video? Who is the guy in the picture?
Posted: Mon Nov 29, 2021 5:13 pm
by joromy
janosch wrote: ↑Mon Nov 29, 2021 4:45 pm
Not sure i snipped it a while ago. But if I'm not wrong it was "Rich Rebuilds" on YouTube
Posted: Tue Nov 30, 2021 4:11 am
by Mekanix
Long time lurker, first time poster.
Ordered a Gen 2 V3 and a Gen 3 V2 from Damien last year. Got the Gen 2 working fine and used it for a while. Now getting the Gen3 charger going and have been chasing some issues.
Using the wiring and already installed and proven pack setup in the vehicle, North American, 72A Gen 3 charger, and for testing only, using the chademo charge cables into the charger with a J1772 adapter to a 40A 240V Grizzl-E charger
Got the wiring completed on the charger, and reading 0s for the DC/AC side charger 36000, cable 20000, setV 403V, termination V 400V. AC amps set to 36A
Grizzl-e reads OK, proxy 1.7V, pilot 7.8V. Modules are on, INI1 is H, batt voltage not showing, but I've metered it at 378V. Grounds all common, termination resistor on phase #1 @120 ohms.
Interestingly, I've heard no relays click inside the Gen3 charger at all no matter what we try.
Confirmed all fusing is good, voltage present after all fuses and DC voltage present at each card.
All modules reading 0 v Ac, 0V DC, 0 charge, 0 temp, 00000000000 and more 0.
Much care was taken to ensure that the CAN wires are matched twisted pairs, with Belden foil wire from the charger to the EVBMW board.
Seems like there's something missing? Am I just staring at it too long?
Posted: Tue Nov 30, 2021 5:37 pm
by Mekanix
OK,
I was just staring at it too long.
found a couple things:
the USB and CAN wires on the 20 pin were left unterminated, as we were just testing the system. depinning them one at a time established better communication between the V3 charger and the DM controller. It popped up right away once those were removed.
Damien's video doesnt show him having the CAN/ USB and other wires attached, so that should probably be noted.
problem solved.
Posted: Thu Dec 09, 2021 5:19 pm
by catphish
I just wanted to note on this thread that I have successfully tested the Tesla Gen2 Charger 1014963-00-C with Damien's v5 logic board and Johannes's (*ahem* not open source) firmware at low current levels (only 2A without cooling) and everything works correctly. AC and DC voltages are correctly reported, AC and DC current limits are correctly calculated and confirmed with ammeter. Keep up the good work!
Posted: Thu Dec 09, 2021 5:31 pm
by catphish
Jack Bauer wrote: ↑Fri Mar 22, 2019 7:53 am
No need to precharge the charger. It does it itself during startup. Just connect with an appropriate fuse.
I just wanted to note that while precharge may not be necessary, there is a 6.6uF capacitor in parallel with the battery connector on each charge module. Connecting all 3 modules in parallel to a 300+ volt battery made enough of a bang that I wouldn't want to switch this without a precharge, and even in testing, i used a precharge resistor before connecting it up. Maybe I'm just a wimp
