Pretty sure it's all covered in his video series. But it wouldn't hurt to review them regardless.
Re: The SuperYacht BMW E65 7 Series
Posted: Fri Feb 07, 2020 7:01 pm
by RE3Rotor
Igor wrote: ↑Fri Feb 07, 2020 7:24 am
From what I have gathered:
GS450h gearbox
GS450h inverter w/ his opensource control board
Tesla Gen 3 (?) charger w/ his opensource control board
I also would like to know if he has BMS with the batteries, and what else is inside that high voltage junction box.
Posted: Fri Feb 07, 2020 7:10 pm
by Kevin Sharpe
RE3Rotor wrote: ↑Fri Feb 07, 2020 7:01 pm
No physical BMS is used with the test pack (it's monitored manually). When the long range pack is fitted then I suspect it will use the BMS fitted to the modules (if OEM) or Johannes BMS.
Contactors and Precharge relay/resistor.
Posted: Sun Feb 09, 2020 2:44 pm
by xp677
Can someone remind me, is the splined coupler for the transmission 21-spine, 28mm major diameter? For the wiki.
Posted: Sun Feb 09, 2020 4:19 pm
by Alexstarex
xp677 wrote: ↑Sun Feb 09, 2020 2:44 pm
Yes. all right
Posted: Sun Feb 09, 2020 9:01 pm
by xp677
Excellent, thank you.
Posted: Wed Feb 12, 2020 3:38 pm
by Kevin Sharpe
Look out for update video from Damien
Posted: Wed Feb 12, 2020 4:24 pm
Bexus Lives!!!!
Posted: Wed Feb 12, 2020 4:47 pm
So with today's testing of the Bexus (current weight 2050kg) and a crappy 450v battery that sags like a ton of bricks under load the car was pulling like a train up through 70mph up a hill. So imho we don't need 650v.
Posted: Wed Feb 12, 2020 5:12 pm
Thats super amazing. Who said electric motors can't have good sound
I wonder how they react at road worthiness test.. sir, we can see a gear box but where is this cars motor?
Posted: Wed Feb 12, 2020 5:22 pm
by Zapatero
Love the sound, very cool.
Posted: Wed Feb 12, 2020 5:55 pm
by JaniK
Great sounds. That bexus is very good proof of concept!
Posted: Wed Feb 12, 2020 6:34 pm
by RE3Rotor
Jack Bauer wrote: ↑Wed Feb 12, 2020 4:47 pm
What is the range for a 450V pack?
Voltage doesn't dictate range. Kilowatt hours is a better general indicator.
But weight of car, driving style, terrain and even climate factor into the range calculation.
Posted: Wed Feb 12, 2020 7:07 pm
by RE3Rotor
I guess a better question to ask is how much kWh does Damiens pack have? And that is driving the motors at all of 450V? Is there any boosting using the boost converter?
Posted: Wed Feb 12, 2020 7:13 pm
by sfk
RE3Rotor wrote: ↑Wed Feb 12, 2020 7:07 pm
From what I know, the battery pack in this test BMW is pretty much junk and only for testing purposes.
I don't think the boost converter is being used, rather the pack voltage is configured at 450V and wired directly into the inverter at that voltage.
Correct, these are old hybrid bus batteries that we use for test because they take a *lot* of abuse. Damien estimated the capacity as ~35kWh iirc.
In a couple of months the BEXUS will get a long range pack ready for it's drive to the Fully Charged Live show in the UK.
sfk wrote: ↑Wed Feb 12, 2020 7:13 pm
No boost converter so ~450V at the inverter. We want to understand how the system performs without the complexity of the boost converter.
Posted: Wed Feb 12, 2020 9:59 pm
by RE3Rotor
Kevin Sharpe wrote: ↑Wed Feb 12, 2020 8:02 pm
I seem to recall the motor(s) in the gearbox is rate at over 600V. So is there a plan to run the gearbox at that voltage using the boost converter?
His videos have convinced me I need to pick up a GS450h inverter and the control board. I just need to sell some more parts to make that happen.
Posted: Wed Feb 12, 2020 11:03 pm
by Kevin Sharpe
RE3Rotor wrote: ↑Wed Feb 12, 2020 9:59 pm
A great deal of speculation surrounds these hybrid solutions and we're trying to understand the reality... today's test drives reinforce our belief that a practical vehicle can use a 350-450V battery without the boost converter. We also believe that the dual speed gearbox and rear differential ratio will overcome any limitations resulting from HV below 600V.
Obviously, we hope someone will test the boost converter
We have lots track, road, dyno, and towing tests planned. In a few months we will know a lot about the Lexus solution.
Posted: Wed Feb 12, 2020 11:05 pm
by RE3Rotor
I did notice mine has 2 drive positions on my gearbox. I would love to know if it is as easy as just connecting the shift lever so I can manually switch to the second location.
Posted: Wed Feb 12, 2020 11:09 pm
by Kevin Sharpe
RE3Rotor wrote: ↑Wed Feb 12, 2020 11:05 pm
I hope more people are going to step forward and start testing these systems now that we've confirmed this is viable
One of our course participants is building a race car which will be interesting
Posted: Wed Feb 12, 2020 11:10 pm
by sfk
I'm pretty sure you could use the switch output from the shift selector as input to the VCU and then trigger the solenoid that controls the 2-stage gearbox output.
Posted: Wed Feb 12, 2020 11:14 pm
by RE3Rotor
Time to do more research/reading.
I have my eye on an inverter. It is just a matter of time before I can jump in and test some of the stuff out.
Posted: Thu Feb 13, 2020 7:31 am
Who decided these are 600v motors? Who told you? Did they actually demonstrate the need for 600v? Under what conditions is dc bus voltage important to a motor? Why would it care?
Sorry if that sounds like I'm an a$$hole but this mantra that Toyota motors absolutely must have xxx volts to run is pure bs. As long as sufficient voltage exists in the inverter to create an AC amplitude that can drive current into the windings to create the requested torque... In the case of the E65 I was still accelerating over 70mph, now when I had only 200v acceleration tapers off around 40mph because as the motor accelerates it becomes a generator and produces a back emf. Once the back emf equals the available bus voltage you cant push any more current and thus the torque flatlines.
I've ran motors at all sorts of voltages, there are a bunch of Tesla LDUs running in drift cars at 200v! But Damien! A tesla motor must have 360v! Really? Why?
Posted: Thu Feb 13, 2020 9:45 am
by Kevin Sharpe
RE3Rotor wrote: ↑Wed Feb 12, 2020 11:14 pm
