Page 3 of 7
Re: Unlocking the power/torque of Prius gen 3 drive train?
Posted: Mon Dec 29, 2025 4:58 pm
Please provide the param file for V2.3
What gearstick are you using?
Posted: Mon Dec 29, 2025 6:00 pm
by Landsi
Posted: Mon Dec 29, 2025 8:30 pm
by Ghia66
tom91 wrote: ↑Mon Dec 29, 2025 4:58 pm
Will do
Simple 3 way switch
Posted: Mon Dec 29, 2025 8:33 pm
by Ghia66
I didn’t re select the Prius as it came across when I updated the parameters from my saved 2.15A parameters.
The only thing that I could tell that didn’t come over was the BMW S box.
Posted: Tue Dec 30, 2025 9:41 am
Post your v2.30A param download.
Posted: Tue Dec 30, 2025 11:31 am
by Ghia66
tom91 wrote: ↑Tue Dec 30, 2025 9:41 am
Couldn’t find MG1 or MG2 available for selection
Posted: Tue Dec 30, 2025 12:47 pm
by Ghia66
tom91 wrote: ↑Mon Dec 29, 2025 3:46 pm
So even after a 12V power cycle it does not work.
Can you please try a release that is older? like V2.22A or 2.20A It is possible a change I made for the testing Greg was doing in his VW Rabbit causes issues for your setup.
I installed 2.20A and sadly it still doesn't move.
Attached is the log and 2.20A parameters
[attachment=1]
Posted: Tue Dec 30, 2025 1:04 pm
If you flash it back to V2.15A you get drive again? Surprised it just refuses to work.
Your V2.20a log does not show Potnom or Torque, this stop it from driving.
Will need to work out what is different if it works on V2.15A makes it work again.
Posted: Tue Dec 30, 2025 1:10 pm
by Ghia66
Thanks Tom, I will go to 2.15A and see what happens
Posted: Tue Dec 30, 2025 5:27 pm
by Ghia66
tom91 wrote: ↑Tue Dec 30, 2025 1:04 pm
Sorry Tom, how do I flash it back to 2.15A?
I tried “updating” it to 2.15A and it remained on 2.20A
Posted: Wed Dec 31, 2025 10:14 am
Posted: Wed Dec 31, 2025 11:27 am
by Ghia66
Thanks so much.
This file then
Posted: Wed Dec 31, 2025 6:13 pm
by Ghia66
Okay, so I downloaded the 2.15A bin file as linked and upgraded the Zombie.
Unfortunately the file seems to be 2.20A on spot values even after numerous Zombie reboots and refreshes… is it possible to be the wrong file?
Posted: Sat Jan 03, 2026 8:15 pm
by Ghia66
So back to 2.15A with the help of Hakan and his soldering/ ST link magic. The car is back up and running after loading up the previous parameters.
Keen to try whatever is required to progress the Prius 3 experience
Posted: Sun Jan 04, 2026 9:31 pm
There must be something on your setup causing problems. Damien utilizes a Gen 3 Prius on the bench for zombie release testing.
Not the best to just go at it if it means risking not being able to move the car though.
Posted: Mon Jan 05, 2026 10:12 am
by Ghia66
Thanks Tom and Damien.
I really would like to try 2.20A again and see if we can get the car rolling with all the great features.
I rewatched Damien’s video on 2.20A and also Greg’s latest one and think that maybe I could have the wrong dirmode setting
The Ghia isn’t a daily just an exciting rolling experiment so I am going for a 2.15A drive with logs and then upgrade to 2.20A
Posted: Mon Jan 05, 2026 5:35 pm
by Ghia66
Well just back from an enjoyable drive.
The car is such fun!
Posted: Tue Jan 06, 2026 5:21 pm
by Ghia66
Well 2.20A software is loaded and I have uploaded my 2.15A parameters.
Changed;
Transmission to manual
Shunt type to Sbox
Dir mode to switch
Looks promising but car is not moving!
I am sure that there is something obvious that I am missing!
Posted: Tue Jan 06, 2026 6:13 pm
Change inverter and change it back again. Can you also please post your inverter serial number/part number
Posted: Tue Jan 06, 2026 6:34 pm
by Ghia66
Thanks Tom, will do tomorrow
Posted: Wed Jan 07, 2026 1:50 pm
by Ghia66
tom91 wrote: ↑Tue Jan 06, 2026 6:13 pm
Changed the inverter from Prius 3 to none and back to Prius 3 and powered down/up the Zombie, unfortunately the car didn’t move.
Posted: Wed Jan 07, 2026 4:35 pm
Did you provide an over view of your wiring? Just want to check its all been done right. Mainly interested in the grounds and 12V supplies and relays.
Posted: Wed Jan 07, 2026 5:56 pm
by Ghia66
tom91 wrote: ↑Wed Jan 07, 2026 4:35 pm
I don’t have a wiring diagram but I will take some detailed photos tomorrow to show the setup.
I slavishly followed Greg’s Rabbit wiring etc and because of having worked on quite a lot of VWs and Subarus I made sure that there is an abundance of grounds.
Posted: Thu Jan 08, 2026 4:08 pm
by Ghia66
12volt wiring layout and grounds
Posted: Thu Jan 08, 2026 6:43 pm
Is all the 12V to the inverter via that relay?
If the issues remains like it does need to confirm what inverter Greg has in his rabbit and what firmware was used as a base for testing on it (yes I did write it but its a while ago).
