Page 3 of 48
Posted: Thu Apr 30, 2020 9:04 pm
by JaniK
so tiny :) looks like you are getting it finalized. So I ask many questions:
How is the JLCPCB doing with deliveries at the moment?
Have you tested minimum voltages running the model3 inverter?
Can we see it on evbmw shop soon for preorder ;) ?
Just suggesting:
"Support for a product, arrives when done, or a nice postcard from lanzarote" ;)
Posted: Fri May 01, 2020 8:19 am
JLCPCB are doing fine. No problems that I have encountered.
The rdu inverter seems to need about 75v on the hv side but I have no idea about the motor characteristics as yet.
Soooo...you want me to start selling a completely untested and unproven board? What could go wrong? :)
On a serious note I am happy to do that as long as the community accepts responsibility. This may take many versions and many iterations before it works properly. If the greater openinverter populus want to help this happen by means of buying alpha hardware then that's cool but that means accepting that things like blown inverters , build errors, etc will happen.
Posted: Fri May 01, 2020 1:56 pm
by Kevin Sharpe
Jack Bauer wrote: Fri May 01, 2020 8:19 am that means accepting that things like blown inverters , build errors, etc will happen.
This is an important point... please DO NOT buy this board unless you are willing to trash your motor/inverter, work with little/no documentation and NO PRODUCT SUPPORT.
The 'community' is not ready to hand hold people who are out of their depth and this is very much the bleeding edge of product development :twisted:
Posted: Fri May 01, 2020 2:37 pm
Now that's what I call a product endorsement:)
Posted: Fri May 01, 2020 3:00 pm
by Kevin Sharpe
Jack Bauer wrote: Fri May 01, 2020 2:37 pm Now that's what I call a product endorsement:)
Yeah, 45 years in the electronics industry helps ;)
Unfortunately, we all know the NEWB's won't listen and will be trashing hardware and asking for help... at least we get to say "I told you so" :roll:
Posted: Fri May 01, 2020 8:56 pm
by JaniK
OK, I understand, There are good points.
There is still much other things to do so I will patiently wait for something that is tested working. Since I am proud to say I am new on this stuff. I can solder trough hole stuff, but cannot design PCBs or program much.
Thanks for the info, happy hacking!
Posted: Mon May 04, 2020 8:38 am
Now in production at JLCPCB. Changed the wifi header to smd type to avoid through hole pins poking down onto the oem pcb. Also added a 3v3 reg to allow for single 5v supply operation. May be deleted subject to testing.
Given recent developments the design files will not be released at this time.
Posted: Mon May 04, 2020 9:07 am
by PacEmaker
Respect :twisted:
Posted: Tue May 05, 2020 8:37 pm
by cloudy
8-) 8-) Awesome, top work!
Posted: Wed May 06, 2020 12:33 pm
by JaniK
Great work Damien!
Posted: Sat May 09, 2020 6:51 am
by JaniK
About the drive unit itself, can it be driven in reverse full time?
Or is there lubrication issues or something like the model S units?
Posted: Tue May 12, 2020 11:12 am
Given that it uses an external electric oil pump I would see no problem with reverse. Of course we won't know until somone does it and shares the information.
Posted: Tue May 12, 2020 11:13 am
In other news JLC have dispatched the prototype boards. Due into me this week with luck.
Posted: Tue May 12, 2020 6:17 pm
by JaniK
Thank you for the answer, I will look into it some more.
I could run it in reverse in a car later if no issues arise.
Posted: Thu May 14, 2020 2:40 pm
Boards have arrived from JLC. First powerup test on the bench is a success:) Next up fitting one to the inverter and hopefully spin the motor. Lots to do.
Posted: Thu May 14, 2020 2:54 pm
by cloudy
Looking good!
Posted: Thu May 14, 2020 2:58 pm
by JaniK
It is a cute little board :)
JLC delivers quite fast? Do they come to you without the connectors?
Posted: Tue May 19, 2020 5:22 pm
Posted: Wed May 20, 2020 5:14 pm
Some info on the M3 rear du temp sensor and resolver wiring.
Posted: Thu May 21, 2020 10:24 am
First attempt running the drive unit using FOC firmware in the prius inverter today. No luck as I think I have my current sensors mixed up. Going to do some investigation on this over in the Gen 3 prius thread then back here to see what happens:)
Posted: Sat May 23, 2020 7:39 am
Posted: Sat May 23, 2020 7:28 pm
Posted: Sat May 23, 2020 9:25 pm
Damien just try giving it 10 poles and the same resolver. I suspect 10 poles should be much for such a small motor. It gives higher torque at lower rpm and good max RPM count regarding 360Vdc bus.
If it still doesnt work then try 8pole. I am sure they wont use odd pole numbers :). I will look for some dissassembly videos.
Posted: Sat May 23, 2020 9:31 pm
by Kevin Sharpe
arber333 wrote: Sat May 23, 2020 9:25 pm Damien just try giving it 10 poles and the same resolver. I suspect 10 poles should be much for such a small motor. It gives higher torque at lower rpm and good max RPM count regarding 360Vdc bus.
Two comments on the YouTube video;
"The prius gen2 motor is a 4 pole pair motor. It would pay to check the resolver too, pretty sure it is 4 pole pairs also. The inverter will not run properly if these parameters are wrong since FOC depends on correct rotor angle information to function correctly."
"Actual resolver may only have 2 pole pairs. In any case if you plot rotor angle you should get 4 0-360 degree transitions for every 1 turn of the rotor. Adjust resolver pole pairs until that occurs."
Posted: Sun May 24, 2020 9:48 am
Thanks to everyones help I have now got the prius gen 2 mg2 spinning beautifully with foc using the V1c board in a gen3 inverter.
Some things I learned :
1)I wasnt pumping in enough manual Id to find the right syncofs value. ie i put in a syncofs, tried 5a then if the motor didnt spin I figured this was the point of no spin. I just needed to man up and pump in some real Id:)
2)Once I had found the point of no spin I tried run mode but got runaway condition. A brain cell fired up and I added 32768 to the no spin syncofs value. Result perfect throttle control but running in the opposite direction.
Hope that helps someone.
In regards the M3 motor I have trawled some of the "Masked Maraduers" videos and think what we have is a 3 pole pair motor and a 3 pole resolver.
