Page 3 of 3
Re: [FIRST DRIVE] Project Rising Sun: Suzuki SJ410k meets Leaf full stack
Posted: Tue Feb 04, 2025 4:47 pm
by Mhs
J0hannes wrote: Mon Feb 03, 2025 5:25 pm Fabricobbled a mount for the Audi/VAG vag vas pump and Volvo vac switch...
Very nice built, which volvo vac switch are you using? Could you please share the part number?
Posted: Wed Feb 05, 2025 11:07 pm
by J0hannes
Sorry, can't tell the part number sice I don't have one. I just browsed online wreckers with Volvo vacuum hose as search word and bought the one that had the part and connector.
The wreckers don't seem to know either what this is or to which category to put it as I didn't see a pattern while browsing the listings.
But here's one listing to demonstrate that at least this part isn't expensive to source :D
https://rrr.lt/en/used-part/dev383977-v ... -pipe-hose
Posted: Wed Feb 19, 2025 8:54 pm
by J0hannes
Cleaned up the main fuse box and pulled out a few meters of copper. Then made some mounts (brackets).
Yet another scrap piece of metal found a new life as a sparse comb :lol:
Wip on the spaghetti, but hey it's cleaning up :)
Installed quite nicely to Suzuki air box mounts
Been hunting terminals
The single mini fuse terminal seems to be Sumitomo 8100-1233 (-1236, -1237) / Yazaki 7126-8850 (-8851, -8852)
Two-way Yazaki 7126-8822
The terminals used in relay sockets I have not identified yet
Possibly Yazaki F250-M-LC-M, See Rakuten
Posted: Wed Feb 19, 2025 9:58 pm
by tom91
Looks alot like the things MTA would also use in their products https://www.12voltplanet.co.uk/mta.html
Or the TE terminals https://www.te.com/commerce/DocumentDel ... t=880398-2
https://www.te.com/en/product-881572-3.html
Then again its a Suzuki so likey uses Japanese terminals.
Posted: Thu Feb 20, 2025 6:57 am
by J0hannes
tom91 wrote: Wed Feb 19, 2025 9:58 pm Then again its a Suzuki so likey uses Japanese terminals.
Oh, key piece of information left out in my post, I was working on the Leaf main harness (or what's left of it)
But yes, Japanese connectors/terminals are the usual suspects anyways :)
Most of the connectors on the Suzuki harness look like they are Sumitomo 250 series sealed and unsealed
DS 250, MT 090 and some others, luckily these are well available :)
I suspect that my parts donor Leaf was made in the UK, wire harnesses are made in France as they have French labels when you peel away all the sheathing and tape. For reference, I'll try to remember to get a picture next time around.
Posted: Sun Mar 02, 2025 10:40 pm
by J0hannes
Today I got all the pumps running and updated to latest Zombieverter FW to make a test drive outside. Well, no test drive yet as there is some hiccup in reversing
The TRW pump needed just the alternator signal switched to inverter on and it was screaming again like there's no tomorrow. Water pumps are getting quieter, there must have been some air in the lines regardless of the fancy vacuum filling. Wired up the VW heater, but it did not seem to want to heat. Didn't do much diagnosing on that yet.
Heater params were VW, control enable, power 6500W and HeatPercent 100. I also used PB3IN as Heat request and that didn't seem to change things either. Tips are welcome :) I have the R50 and C45 changed as per the note mentioned in Zombieverter hardware NOTE : R50 will need to be changed to 1k and C45 to 1n in order for LIN to work properly. This will be amended on further builds. So if you have a board ordered before 14/03/24 this change is required.
Taming the spaghetti has proceeded as expected and there are very few on the "get back to this later" -list
Zombieverter will find its new home under the glovebox, similarly to the ICE ECU I had mounted there. That way I don't have to "recalibrate" my max water level :D
Had ordered a new LV connector for battery, crimped and pinned that. Reused the blind plugs from old connector. I'll save that for any and all possible future use scenarios :)
Since I have now tried 3 different FW releases and none of them had any torque in reverse, I started to look into this and did some CAN logging. Maybe my 2017 30kWh Leaf driveline (stack and battery) is a snowflake, or is it possible that this is a bug left unexposed? I don't know, but I will find out :geek:
Alishit, found the perfect high voltage warning sticker :twisted:
Posted: Sun Mar 02, 2025 11:00 pm
by tom91
J0hannes wrote: Sun Mar 02, 2025 10:40 pm eater params were VW, control enable, power 6500W and HeatPercent 100. I also used PB3IN as Heat request
Please post your params. You know PB3 is a pull to ground. Did you see the Heat request spot value go to ON?
Posted: Tue Mar 04, 2025 5:22 pm
by J0hannes
tom91 wrote: Sun Mar 02, 2025 11:00 pm Please post your params. You know PB3 is a pull to ground. Did you see the Heat request spot value go to ON?
Yes, heat request spot value changes to ON.
Params are same as I'm using now to test the 2.31 TH (with fw version this the heater works!)
Posted: Tue Mar 04, 2025 5:38 pm
by tom91
J0hannes wrote: Tue Mar 04, 2025 5:22 pm he 2.31 TH (with fw version this the heater works!)
So the latest code from the Vehicle Testing branch has the heaters working?
Which FW version were you testing with before?
Posted: Tue Mar 04, 2025 6:03 pm
by J0hannes
tom91 wrote: Tue Mar 04, 2025 5:38 pm So the latest code from the Vehicle Testing branch has the heaters working?
2.20A official release
by tom91
J0hannes wrote: Tue Mar 04, 2025 6:03 pm 2.20A official release
Yes that had a LIN bug, the main branch has fix and is being tested by Damien to release.
Posted: Sun Mar 09, 2025 7:00 pm
by J0hannes
Well, in the meanwhile...
I've been sorting out the spaghetti and did a little test spin :D
Posted: Mon Mar 10, 2025 10:12 am
by marcexec
Congrats! One EV grin at a time :P
Posted: Sun Mar 16, 2025 8:15 pm
by J0hannes
marcexec wrote: Mon Mar 10, 2025 10:12 am Congrats! One EV grin at a time :P
Yes! Feeling like a winner :D
Also
Tested today the quick fix by Tom91 for Zombieverter Leaf CAN messages and boy does it feel good to have torque in reverse!
Gave a shot on redoing the intermediate driveshaft. Been wanting to try out oil fill for balancing, so here goes nothing!
Posted: Mon Apr 07, 2025 6:44 am
by J0hannes
Had found a suitable cable feed through for HV battery cable from the boat section of local auto parts shop
As I have route it through the cockpit. Also had some interface plates cut, so I have something more rigid to mount the feed through to
I'll try to remember to snap a pic of the end result too
The hood closes now :)
Coolant reservoir would have had enough clearance
Leaf PDM doesn't really clear it, but damn that's close :roll:
It looked like it was close and so it is, but still the original bed sides fit.
Its still a WIP, but I figured that I can use the Leaf battery mounts also to build an interface to mount the bed sides :)
Posted: Fri May 02, 2025 10:41 pm
by J0hannes
Nobody will know that this is electric when I'll pull a tarp over the bed and cover that battery :P
Also, remembered that I had one of these collecting dust. Its a plastic fender for trucks and truck trailers. For smaller wheeled vehicles easily makes two out of one :)
Some sheetmetal profile for mounts
Those should work just fine and I hear they take a beating too :P
Got some OEM new Jimny wheels, these are light. Should look good also when I get the weight of the car
Spliced the VW heater interlock to Leaf engine harness interlock circuit. The plan is to connect this as part the Inverter pover relay control circuit. So circuit open --> no inverter power.
One of the vehicle modification requirements in Finland for a car this old is that the vehicle indicated to the driver if it is in an active driving state when the drivers' door is ajar. I was first adding a signal lamp, but then I figured a buzzer is actually useful for me too.
I didn't have cardboard, but is brown paper ok? This is what I figured that needs to be done before MOT. (Already reserved a time slot for that for next week :lol: )
An idea to cover the gaping hole I made on the hood. We'll see what it'll actually be :lol:
With this I'm close to declare the project DRIVING
Posted: Tue May 06, 2025 10:43 am
by marcexec
J0hannes wrote: Fri May 02, 2025 10:41 pm For smaller wheeled vehicles easily makes two out of one
Big fan of scrap engineering :) Milk jug PE can be heat formed quite nicely...
Posted: Thu May 08, 2025 7:54 pm
by J0hannes
Well I've been working on my brown list until all got struck over :)
The hood scoop is now really made from a snow scoop I picked up from for free. It was probably run over with a car or something and didn't work for snow scooping. For hood scooping there was enough material to work with :D
Added a shield over the battery connectors, theres also a nice ISO 7001-W12 sticker on it now
Sealed the PDM, didn't have the Nissan spec stuff, but the grey is probably good enough
Added the "warning" sticker
Did some insulation resistance measurements with my Kaise SK-3100, which I got on Facebook for freebie. 500V rated Yellow condom gloves for safety, you know ;)
Prodded the HV connectors on main harness and VW heater as well as the charge ports. The analog gauge is not the most precise, but got tha ball park numbers that I could use for the report for initial inspection I'm writing for MOT.
Changed these lighter wheels as D-day is nigh
First charge at home
Today I drove to work and back. Remembered to check soc before and after only on my way to work, that was about 29km. Consumption was roughly 19kWh/100km. No heater used and max 70km/h (my subpar driveshaft adapter give heavy vibrations, so I need to drive nice until a better one emerges :D). Will have to do more logbook work on getting a better understanding on the possible consumption.
[DRIVING] Project Rising Sun: Suzuki SJ410k meets Leaf full stack
Posted: Fri May 09, 2025 6:25 pm
by J0hannes
Today I went and had this bucket MOT'd
So with this, I declare this DRIVING.
This concludes phase I of my project 8-)
Next I'll take some time driving around on and off road, getting a better understanding on the range I'm going to have and fix some minor things.
Stay tuned :twisted:
[OFF ROAD DRIVING] Project Rising Sun: Suzuki SJ410k meets Leaf full stack
Posted: Tue Jun 10, 2025 5:20 pm
by J0hannes
The real first drive 8-)
Oh boy this is more than insane!
Don't really have the words to describe how it feels, other than brutally and awesome!
What I have identified as needs for improvement / development during the drive or earlier:
-This needs creep, adjustable preferrably
-Pressing the brake pedal and throttle is uninevitable, torque request being cut by touching the brake pedal makes driving difficult in situations where physics wants to move the car opposite direction to what the driver wants... Some finer system, maybe based on brake pressure or something to limit max toque request, but not kill it completely
-Air compressor is noisy :D
-I really need to upgrade the rear springs to slightly higher load range, now they sag and rear end feels too soft
Re: [DRIVING] Project Rising Sun: Suzuki SJ410k meets Leaf full stack
Posted: Tue Jun 10, 2025 7:29 pm
by johu
Great watch :) imagine having to do this with a clutch!
Do you have some metrics for us? Like how much energy did you use that day vs. a fossil burner? How was the car perceived?
Not sure if creep mode from the inverter made it into Zombie... Hill hold will just work with replacement board as it needs direct access to resolver
Posted: Tue Jun 10, 2025 9:01 pm
by J0hannes
johu wrote: Tue Jun 10, 2025 7:29 pm Great watch :) imagine having to do this with a clutch!
I've been doing this with a clutch for over 20 years, so this two pedal driving actually feels somewhat awkward. Especially since driving an ICE Suzuki means lots of clutch slipping needed
I've been quite bad at following fuel consumption as usually every drop of fuel put in to tank has been burnt up :twisted:
Also, forgot to check SOC before heading in for the drive :?
But maybe some guesstimation can be made:
Left home at approx 69% --> drive to Off Road park
Drive for about 3h, lunch break and then another 2h driving with less wheels spinning freely, SOC~32%
So that's approx 9kWh out of which maybe 2kWh went to the drive from home to Off Road park
Compared to a day with gas burner typically maybe a quarter of tank at max, so approx 10l of gas.
I'd say in general the car was greeted with curiousity and interest. The instant torque from standstill got probably most comments.
I haven't found creep in Zombieverter, but thanks for the tip, I'll check the inverter side implementation :)
Hill hold sounds heavenly for this use, but I'll have to put that thought on the back burner for a while.
Still I need to make the improved motor side driveshaft adapter and add the Hyundai VESS first for people to hear this thing coming behind them in the woods :lol:
