Page 3 of 3
Re: State of Rex hacking?
Posted: Fri Feb 23, 2024 11:09 am
by Woodfie
Posted: Thu Feb 29, 2024 8:17 pm
by Woodfie
:D Have now amassed enought parts to enable spark on firstly one cylinder of the REX'S engine .
A Bmw sensor for what is possibly tacho and timing to go on the speeduino track has now arrived, for after a more basic approach.
The magnet wheel, Hall sensor, Pre conditioning amp, Coil Driver kit, Ballast bulb, up to the Coil and plug.
Lots of bits to eliminate a set of Mr Ketterings Points.😃
Posted: Tue Mar 05, 2024 4:02 pm
by Woodfie
The spark set up, now delivers a slender, but firm mini bolt
On running the generator as a starter, the revs still oscillate maybe +/-500rpm, at around 1 Hz, bit like a teenager on a small scooter sound..
Setting up to check the ball park timing, and garden plumbing " throttle " butterfly
Only going to run ONE cylinder first, as have discovered the crank is 90 degree between pistons, or crossplane configured, which messes with my 180 degree timing wheel set up.. Also haven't figured yet if it's 270 degree lead, or follow (I e. 540 degree lead ), or had considered 90 degree lead or follow... Makes my head hurt thinking about it, as cannot rotate the engine slowly, with the 8mm nut on the resolver being only access at present.m
Posted: Tue Mar 05, 2024 6:51 pm
by jrbe
I'm kind of surprised it's an odd fire twin, but they do make good torque for their size.
Speeduino works with odd fire setups but it likely has some specific triggering requirements to do it.
1 magnet on the trigger wheel with 2 Hall sensors spaced 90° or whatever the offset is could work to rig it for now. 1 for each coil. It will be tricky to time / adjust though.
Posted: Tue Mar 05, 2024 7:52 pm
by Woodfie
Yes, I was surprised by it also, but that's the learning.
It would seem that it now is the trend in recent cycle engines, and although not necessarily required for a generator setup, I guess Bmw used what they had under their umbrella.
Posted: Thu Mar 07, 2024 3:33 am
by Woodfie
Another step, satisfactory single cylinder test run, second cylinder Inlet blanked off.
Observed power returning to the battery , brief run, as no coolant to lubricate the pump, and extract an expected 4 or 5 times waste heat portion of fuel use.
Also evident is an unloading to zero amps at around 3kw output... and over stressing of the lightweight phase test wires.. Work to do..
Posted: Sat Mar 09, 2024 5:45 am
by Woodfie
Water circulating system gor the Kymoco, twin cylinder now running as a single for test purposes., has been fashioned for short running.. No radiator or heat exchange yet, but coolant in pimp and block.
A stumbling block has appeared...Once a clamp meter indicated 14A into the 250V battery occurs, the charge drops to zero. Reducing the throttle, then initiates the charge, but again will cut out at 14A.
The Nissan leaf inverter which is being used with the Valeo motor generator from the REX unit, is controlled by a Thunderstruck V1.0 vcu.
Increasing values of
max Battery V for regen,
Idleregen,
and brakeregen settings has not made any difference.
Also have activated the Brake switch control input, and no improvement yet achieved.
The reason for the limit is not yet understood.
Posted: Sat Mar 09, 2024 3:20 pm
by jrbe
There are no errors or messages showing in the thunderstruck vcu?
Its likely that there is some limit at 14A or 3500watts that is triggering it to cut regen. Could be a missing / incorrect input like temp, voltage, amperage, etc. What can you see in the thunderstruck vcu that looks out of the ordinary?
Posted: Sat Mar 09, 2024 7:55 pm
by Woodfie
Thanks jrbe, the Thunderstruck V1.0 vcu is one of the very first releases, looking to re find the manual . Had used it before with Leaf inverter to drive a ED Smart car, which had done it's graveyard mode shutdown. Have not used the brake function, or more than mild regen, so had not seen this limit till Rexing.
Will see how to find/read errors, for clues.
Searching for the V1.0 manual
I know this V1.0 vcu will not operate a Gen 1 Leaf inverter, which was my first choice, A later V3.1 vcu which can run Gen 1 or Gen 2, has-been suggested, I believe it maybe better doc supported..
Posted: Wed Mar 13, 2024 9:19 am
by Woodfie
Have located the relevant manuals , and so far have not found , what may be missing.
Have also now tried the V3.1 vcu, with the same result, so pointing towards something the inverter, possibly an input not satisfied.
Posted: Mon Apr 01, 2024 6:55 am
by Woodfie
Activation of brake switch, Changes to regen config settings of brake, idleregen, and turning all off, seem to have no effect, still 3.5kw or 14A on clamp meter, and it unloads.
Finally some variation can be gained by retarding the resolve setting some degrees, and 7kw or 30amp on bus clamp meter observed. However there is then low starting torque to crank the engine at the present Nm settings, unless advanced to around the original selected resolver position.
Looking at trace info, you see of anything can be gleaned.. Wondering if this charging is somehow dictated by the inverter , perhaps some default setting... WIP
Posted: Mon Apr 01, 2024 9:48 am
by Scrappyjoe
I have no real knowledge, but am following with interest, so would like to throw in some possibly silly thoughts. Ignore at will.
1. Could this perhaps be some incompatibility between the inverter and motor? Something that is not noticeable at low loads but that kicks the inverter off at higher loads? Perhaps test by running the generator as a traction motor and see if you have the same problem in drive mode.
OR
2. Could this be some issue between the VCU and the inverter in regen mode? Test by swapping the BMW motor with a known working leaf motor, and see if regen still breaks at the same spot.
Basically I’m thinking it would be good to isolate if root cause is between VCU and inverter, or between inverter and motor.
Posted: Mon Apr 01, 2024 8:49 pm
by Woodfie
Yes thanks for the thoughts,
Had considered the 2 plan, leaf motor is not easy connect to present BMW engine , had a small water blast stationary motor, but figure not enough to get to the unloading limit, but would help figure out the regen not functioning.
Posted: Tue Apr 02, 2024 10:29 am
by Swing
Well, all I can say is keep up the good work.
The BMW REX might not be perfect, I think it is one of the only options around for DIYers looking for a compact range extender.
All the alternatives are much bigger engines integrated into a drivetrain.
Posted: Tue Apr 02, 2024 6:13 pm
by jrbe
The Hyundai HSG starter / generator could be another option for testing.
Posted: Fri Apr 12, 2024 5:10 am
by Woodfie
Contemplating putting a Leaf motor in the empty engine space of the Test Bmwagon. And use MG1 to rotate the splines shaft at up to the desired say 12kw,
This would check out the Thunderstruck, Leaf inverter , and Leaf motor and its regen operation, to see if the present anomalies experienced can be better understood
Posted: Wed Oct 23, 2024 9:37 am
by welshkid
Hi Woodfie, Love the work done so far, have you gotten any further with the experiments? Planning something similar for my self soon hopefully.
Posted: Tue Nov 12, 2024 12:36 pm
by Hectorx1999
Scrappyjoe wrote: ↑Mon Jun 19, 2023 8:46 am Hello,
An i3 Rex has appeared in a junk yard in my country (battery gone unfortunately). I have a goal to create a 'standalone' range extender that I can put in the back of my (not yet built) Outlander-driven EV conversion to be able to drive further now and then. I'm pretty sure I can take my pick of the i3 components.
So, I want to ask the community. What is the state of i3 Rex hacking? Is it at the point where I could pull the parts from an i3, mount it in a steel chassis along with a Zombieverter, and fire it up at will? I haven't figured out how it would interface with the HV bus on an EV, but a good starting point would be to try replicate how it works on the i3.
Cool project! Turning the i3 REx into a standalone range extender for your EV conversion is definitely possible, but it's tricky. The i3's REx is tightly integrated with its electronics, so pulling it off in a different setup would need some serious hacking, especially to get it to fire up on command without all the i3’s control systems.
You'd need to interface the REx with your EV’s high-voltage system somehow, and the best bet might be using a Zombieverter or similar controller to replicate the i3’s control signals. There isn't a ton of info on hacking the REx for standalone use, but people in EV conversion and i3 mod communities have looked into similar projects. It might be worth checking out those forums or finding someone who's worked with hybrid setups for more detailed guidance.
If you’re up for the challenge, it could be an awesome solution! Just be ready for some custom wiring, control programming, and fabrication work.
Posted: Mon Dec 30, 2024 8:35 pm
by itiuk
Just to throw another idea in the mix, what about the Transit Custom PHEV as a source for a rex? 1.0 ecoboost mated to a generator? I know they're not very common vehicles but could be an interesting study...?
Posted: Wed Feb 18, 2026 4:44 pm
by Scrappyjoe
A fellow member has an i3 Rex unit that I might be able to do some test hacking with.
I was thinking of coupling the i3 Rex motor to a Honda GX690 engine, sidestepping a lot of the EFI challenges.
That leaves the inverter side. The i3 Rex inverter is available, but it isn’t hacked. I can get hold of Prius inverters, and I have an outlander inverter.
Can somebody confirm: can I use a Prius inverter to control a non Toyota motor, such as this i3 motor? Can it be done with Damien’s dual motor (v1d) board? Can it be done with johu’s OI mini main board?
Basically the motor will need to be able to pulse start the ICE, and then go into regen. Would be nice if I can control regen level somehow - maybe a rotary encoder
I have a preference for the mini main board because I can buy a foccci board at the same time, but if Damien’s board is better documented I’ll go with that because I need all the help I can get.
Posted: Wed Feb 18, 2026 8:26 pm
by Jacobsmess
Yes but youll have to tune it. Lots of people have paired toyota inverters with non toyota motors with a replacement brain board from either Damien or Johu.
Posted: Tue Feb 24, 2026 3:55 pm
by Scrappyjoe
I managed to pick up a Rex generator today. As woodfie said, it's quite hard to separate from the ICE. Here's a bit more detail.
The generator is connected to the ICE by several no 17 bolts. Once those are all out, there is nothing else to loosen. I took off the resolver plate and even tried to take off the top plate of the generator to see if there was anything else to loosen but there was not.
Basically, once those #17 nuts are loose, you get some nice big crowbars and you lever it off. Be careful not to damage the casing, as it is aluminium and can chip off.
I think the reason that it was so hard to get off was because of a spring that winds around the coupler spline. But I'm not sure.
Anyway, now I have the motor along with HV cable and pigtails. Next up I'll try get hold of a Prius gen 3 motor with cables and install the dual motor board and then I'll try to drive the motor. Once that's working nicely, I'll couple it to a Honda GX690 and try use it as a redneck rex.
Posted: Tue Feb 24, 2026 3:59 pm
by Scrappyjoe
Incidentally, it's quite a big motor. A little lighter than my outlander, maybe, but larger diameter and quite flat. I would not be surprised if this motor can run 25kw continuous and something like 60kw peak. And if torque is correlated to diameter then it's probably got more torque than an Outlander motor.
