Page 3 of 3
Re: Hyundai IoniQ 2020 HV battery pack
Posted: Fri Nov 17, 2023 11:01 am
by projectgus
cgalpin wrote: ↑Thu Nov 16, 2023 10:02 pm
Sorry @projectgus for the continued derailment of this thread
No need to apologise! I think at the beginning it wasn't clear how different they would be, but now it seems like they're quite different. The moderators should have a function to actually split the thread, but maybe they won't have the time to do this.
Posted: Tue Feb 13, 2024 12:36 pm
by JoeSe68
This *might* be interesting for DIY battery with g-EMP battery pack :
https://github.com/dalathegreat/Battery-Emulator
Posted: Tue Feb 13, 2024 10:41 pm
by cgalpin
If you are talking about the 800V e-GMP battery like in a hyundai ioniq 5 or Kia ev6, yes, but only if you live somewhere you get 3 phase service.
I was initially interested in this, but ran into a couple of hurdles. First, you need hardware that supports CAN-FD to talk to the battery natively, which the current hardware the project is using (LilyGo ESP32 T-CAN485 devboard) does not support. Then the software needs to support it (this can be fixed). But the last straw for me was that I can't find any inverter that can handle this high voltage of a battery on single phase service. I believe there are options with three phase service (like in Europe).
Posted: Wed Feb 14, 2024 5:55 am
by JoeSe68
Guess I was just hopeful as they note that the support for e-GMP is in progress.
The Solax X1-HYBRID-G4 is single phased, and so should do the trick for you
But overall I have found it hard to find hybrid inverters w. support for HV batteries - and a lot of those only support up to 400-600 - not 800 (or more).
Anyway I'm walking around the christemastree waiting for my e-GMP (77kWh) and a Solax X3. Getting very impatient here *G*
Posted: Wed Feb 14, 2024 1:53 pm
by cgalpin
Looking at their website,
https://www.solaxpower.com/x1-hybrid-g4/ , the Solax X1-HYBRID-G4 only supports a battery in the 80-480V range.
Posted: Thu Feb 15, 2024 1:00 am
by projectgus
cgalpin wrote: ↑Tue Feb 13, 2024 10:41 pm
I don't have data either way, but are you certain about this requirement? CAN-FD is backwards compatible with CAN 2.0, and most automotive applications that I've seen only use the "bitrate switch" high speed CAN-FD frames for certain operations like firmware updates where they need to send a lot of data quickly. So it might be possible to do normal BMS operations over "CAN classic"?
The classic controller in the ESP32 will put an error on the bus if it sees a "bitrate switch" frame, but if there aren't any during normal operation then it will interact normally.
Posted: Thu Feb 15, 2024 5:46 pm
by cgalpin
You know what, let me try again. Originally I had problems and could get no messages at all until I switched to CAN-FD, but in retrospect I did have some bad hardware. Maybe that was it. Will try test later today.
Thinking about it, i wasn't the only one not able to communicate with it until using CAN-FD, but will test again anyway.
Posted: Fri Feb 23, 2024 6:11 am
by JoeSe68
cgalpin wrote: ↑Thu Feb 15, 2024 5:46 pm
Quite looking forward to the result - thou I have a feeling it will be negative ....
Posted: Fri Feb 23, 2024 4:38 pm
by cgalpin
Yeah I couldn't get it to work. I don't have the exact same setup as before, and have not had time to try methodically verify, although so far the only thing that gets me any CAN messages at all, is using a canable v2 which supports CAN-FD, and a recent version of SavvyCAN which has mods to support CAN-FD on a Lawicel device
Posted: Mon Feb 26, 2024 11:04 am
by JoeSe68
cgalpin wrote: ↑Fri Feb 23, 2024 4:38 pm
Roger that - thank you for checkking Cgalpin
