Re: prius gen2 mg1 + leaf invertor gen2 + honda ima
Posted: Sun Nov 05, 2023 8:22 pm
Interesting, do you have any before and after pics? Was it quite straight forward to cut it down? What would you recommend as a setup to have a 3rd motor controlling the input shaft on a lexus gearbox CVT?Romale wrote: ↑Sun Nov 05, 2023 10:23 am hi. this motor = generator from prius gen 2. there is no welding, only a grinder and a little patience. according to the inverter, I sawed off part of the board in vain, it does not work well with external DC / dc to power the drivers. look at my other topic, where the ima inverter is affected, there are pictures of how to use it. this is a wonderful inverter and it works even from 520 volts!!!
