Re: GS450H Solenoids SL1 SL2
Posted: Wed Jul 26, 2023 9:14 pm
If all four combinations leave you in high gear, then you likely have a problem with your oil pressure. Is the oil pump running okay?PatrcioEV-ATX wrote: ↑Wed Jul 26, 2023 3:51 pm I can't get the transmission to change to Low gear under any combination of these. Anyone have any thoughts?? I think SL2 always being HIGH no matter what I tell it is ok, but I don't understand why changing between TransSP HIGH and LOW has a different impact on PB1.
As far as I know, everyone else has been able to achieve low gear by setting both solenoids high with good oil pressure.
