Page 3 of 3
Re: Leaf powered RX8
Posted: Tue Sep 29, 2020 11:07 am
by rooster
The I3 and its gearbox could also replace the dif, just like when it was in the I3 car originally, and you just need to attachit to the subframe, cut a hole in the body near the tank and its done.. But then I fear you are a just getting an I3 with a different body at the end of the process.
So maybe retaining the manual transmission will give the extra power and torque performance worthy of the RX8 , and I should mate the I3 engine (50kg) directly to that gearbox. Only problem is that rx8 gearbox has a funny conical shaft and is problematic to mate the I3 motor directly without some sort of universal adaptor...
