Page 17 of 48
Posted: Sat Oct 16, 2021 2:55 pm
by EV_Builder
JaniK wrote: Sat Oct 16, 2021 10:53 am I have an unmodified inverter sitting next to my PC..
Dammn you make me tempting togo after one my self too.... :D :D :D
I probably will because i still am in need of a front wheel drive motor. But i need tobe sure to have enough room for batteries so i better tackle that first...
Posted: Sat Oct 16, 2021 5:35 pm
by dsp1108
Hi guys!
I'm Dmitry from Russia.
It seems to me ... I was able to write a bootloder and foc program for tesla inverter 3.
Posted: Sat Oct 16, 2021 5:39 pm
Dmitry contacted me today and shared some videos of his work. He has an M3 inverter running custom firmware spinning a non Tesla motor! Fantastic work and welcome to the forum:)
Posted: Sat Oct 16, 2021 5:49 pm
by dsp1108
If the moderator posts a video, then that will be good.
I am also ready to answer questions about the program.
Posted: Sat Oct 16, 2021 5:51 pm
by dsp1108
Thanks Jack Bauer!
Posted: Sat Oct 16, 2021 6:26 pm
Here is one of the videos of Dmitry's work :
Posted: Sat Oct 16, 2021 9:42 pm
Keeps getting more interesting. Good job. What's the firmware based on? Is it on github?
Posted: Sat Oct 16, 2021 11:59 pm
by Isaac96
Phenomenal! Well done!
Posted: Sun Oct 17, 2021 1:30 am
by collin80
dsp1108 wrote: Sat Oct 16, 2021 5:49 pm If the moderator posts a video, then that will be good.
!!! Otlichna! Horoshaya rabota!
Really, that's awesome! I hope we can all work together to make Tesla parts a bit easier to work with. You said you wrote FOC code and we can see in the video that it's some sort of other motor. Does that other motor also use a resolver or is it possible to interface an encoder to the M3 inverter? And, is your bootloader CAN based? Does it use UDS for firmware updates like the inverter does with the OEM firmware?
Posted: Sun Oct 17, 2021 1:46 am
by dsp1108
I have been developing electronics for many years and got a Tesla inverter on occasion I have PMSM control projects, including for texas instrument processors.
I decided to transfer my code to a tesla inverter.
Posted: Sun Oct 17, 2021 1:55 am
by dsp1108
The resolver is used.
Bootloader is first loaded via jtag.
Then the main program and calibrations are loaded through can.
Private can is for debugging and oscilloscope.
There is support for uds download, but it has not been tested.
Posted: Sun Oct 17, 2021 5:02 am
by jetpax
You would be a total hero if you could share any of this with us mortals
I am especially interested in bootloader/CAN loader details, and how you use the private CAN for debugging and scope.
The M3 DU sitting in my garage would certainly appreciate it…
Posted: Sun Oct 17, 2021 7:02 am
by dsp1108
I will prepare a bootloader project and post it.
A little bit later.
Now, I'm debugging the main program.
Posted: Sun Oct 17, 2021 12:19 pm
by dsp1108
What do you think of the idea to hack the tesla plaid inverter?
The probability, is more than 95 cents ...)))
The biggest problem, as I see it, is the squib.
Posted: Sun Oct 17, 2021 12:31 pm
by EV_Builder
dsp1108 wrote: Sun Oct 17, 2021 12:19 pm The biggest problem, as I see it, is the squib.
What is a squib?
Posted: Sun Oct 17, 2021 12:39 pm
by dsp1108
Breaks two of the three output buses.
Posted: Sun Oct 17, 2021 1:52 pm
by dsp1108
There is a consideration:
Break the squib activation circuit with voltage OFF.
And debug tesla plaid inverter.
Posted: Mon Oct 18, 2021 9:17 am
by EV_Builder
How is it mounted / fixxed?
Can we emulate it's presence?
Who has this engine/inverter in the first place :)?
Posted: Mon Oct 18, 2021 10:44 am
by mikeselectricstuff
EV_Builder wrote: Sun Oct 17, 2021 12:31 pm
What is a squib?
Shown here - pyro device to blow the busbars in case of a catastrophic fault
Posted: Mon Oct 18, 2021 10:58 am
by EV_Builder
Yeah I remembered it. But again who has this engine / inverter?
Think we should first focus on the M3 engine it's more widely spread.
Posted: Mon Oct 18, 2021 2:52 pm
Good news : Harvested a FT2232 from a dev board, soldered to the jtag adapter, programmed and presto we are talking to Elon. Push fits perfectly into the horrible jtag socket.
Bad news : Design flaw! That 1k pull down resistor on ADBUS5? Should have been ACBUS5!! Gahhh. Anyway. Boards are fairly cheap from jlc without the ft2232 so I'll fix and order a fresh batch.
Posted: Mon Oct 18, 2021 3:10 pm
by dsp1108
Hello.
It seems to me, there is a simpler option:
Finished debugging 95 percent.
The loader will try to post on this week.
Posted: Mon Oct 18, 2021 5:41 pm
by davefiddes
Jack Bauer wrote: Mon Oct 18, 2021 2:52 pm Bad news : Design flaw! That 1k pull down resistor on ADBUS5? Should have been ACBUS5!! Gahhh. Anyway. Boards are fairly cheap from jlc without the ft2232 so I'll fix and order a fresh batch.
Sorry about missing that when I reviewed. That was my design fix too... :(
Posted: Mon Oct 18, 2021 6:05 pm
No worries Dave:) new boards ordered. At least we know it all works other than that.
Posted: Tue Oct 19, 2021 12:57 am
by collin80
dsp1108 wrote: Mon Oct 18, 2021 3:10 pm Hello.
That's only simpler if you can find the mating connector and successfully crimp the pins. Damien's board is a MUCH easier solution for everyone else. Since he's tested it to work (other than the one problem) I'd say he's in good shape and everyone is likely to want to go that route rather than crimping pins you need brain surgeon dexterity for.
I feel so lucky that the Model S board has 14 pin ARM JTAG headers right on it. No dinking around making things, just use a normal ARM JTAG cable and it works. Why couldn't they do that on the Model 3 as well?! XDS110 works great on a Model S controller too. It seems like they've went backward a bit in terms of accessibility. But, that doesn't really surprise me a whole lot.
