Re: GS450H Discussion
Posted: Fri Feb 17, 2023 7:34 am
My VCU software is based on Catphish code and its great. You might like to check this out: viewtopic.php?p=45775nkiernan wrote: ↑Thu Feb 16, 2023 9:01 pm Wondering if anyone is running Catphish's GS450H_v8 code in their setup? Does the wifi module need to be programmed specifically to work with this version? Or would a wifi module from something like the Zombieverter already be set up for it's OI web interface?
"uses Johannes's standard openinverter ESP8266 web interface"
I re-programmed ESP8266 using RasPi, not sure is module possible to re-program over wifi.
