Page 16 of 40
Posted: Wed Sep 21, 2022 10:39 am
by Bigpie
Not sure, not sure it's possible to plot the currents of each phase, with the current software, nor differentiate between controller position and motor position?
According to my shunt, I'm getting about 32kw from the motor, so half what Mitsubishi rate it at. I can setoff is 2nd slowly.
Posted: Wed Sep 21, 2022 10:45 am
by Pete9008
Bigpie wrote: ↑Wed Sep 21, 2022 10:39 am
I think you can get il1 and il2 which would be enough and only need the controller angle (the others are just there as standard on my plots and not easy to remove).
If you try to set of quickly in 2nd, or slowly in any higher gears, what happens?
Edit - does it ever stutter a little when starting off?
Posted: Wed Sep 21, 2022 10:59 am
by Bigpie
If I bring throttle in I can move off in 5th, if a little juddery and very slow. Full throttle results in a cutout.
Attached is backwards and forwards on the drive as slow as I could with datapoints reduced to 100 to see if that improves things.
Posted: Wed Sep 21, 2022 11:29 am
by Pete9008
The time resolution on that has improved to 0.3sec so the 100 points does help. It's still only the first few seconds that have good enough resolution though:
That looks pretty good, the angle plot is a nice sawtooth with very little noise. The min, max and ave currents track each other and are a nice sinusoid. No obvious problems there at all which is great - but I'm now at a loss as to why you get the cut-outs and are only running at around half power!
Edit - calculating the 3rd phase and plotting gives this - again all good.
Edit2 - do the cut-outs tend to be low speed, high speed, low load, high load or fairly random?
Posted: Wed Sep 21, 2022 11:40 am
by Pete9008
This is the current plot for the complete run:
It's very intermittent, was this you coming on and off the throttle or was this the juddering?
Edit, looking at the time axis guessing the former.
Posted: Wed Sep 21, 2022 11:46 am
by Bigpie
The cutouts can occur in 2 situations from what I can tell, is accelerating from standstill at high throttle, i.e. trying to setoff more quickly than usual. It starts moving very briefly then cuts. The other situation is when for example merging to motorway and trying to gain speed quickly and so at pretty high RPM, very much over 10k.
I can only think it's overshooting causing the problem?
On and off the throttle, going forward a little, putting it in reverse going backwards and repeat.
Posted: Wed Sep 21, 2022 11:54 am
by Pete9008
Another plot showing a section in the middle, nothing wrong with that at all!
From standstill will give some pretty fast motor movement/rates of change as all the slack in the drivetrain is taken up. Does it still do it if you use a little bit of throttle to take up the slack and then accelerate hard?
On the high speed one it might be worth trying the build of code that I did for Ev8 which has a bit of sync compensation which will help at high speeds, let me know if so.
Posted: Wed Sep 21, 2022 1:57 pm
by Bigpie
Taking up the slack first still has the issue even rolling at a couple of mph the same. Not a big issue day to day, but would be nice to understand why and irradicate. I've not played with curkifrqgain as the higher speed cutouts are even less of an issue daily as I don't tend to need to accelerate to higher speed quickly often.
I'll try plot with even fewer points see if that highlights anything
Posted: Wed Sep 21, 2022 10:00 pm
by Ev8
Pete9008 wrote: ↑Mon Sep 19, 2022 4:16 pm
The unwanted throttle on fw suggests that either the Mtpa parameters are wrong (it needs more -Id which means a larger value for lqminusld) or syncofs is still out. Might be worth upping lqminusld a bit more (I think Bexander did use 6 at one point), it shouldn't do any harm. Keep increasing it till it stops improving performance (although I'd be getting pretty suspicious above 10mH)
I got a chance to do a few runs with mtpa settings up to 10mH no difference in the unwanted acceleration, will try a few more things
Posted: Thu Sep 22, 2022 6:59 am
by Pete9008
Did the higher lqminusld make any noticable difference to performance below base freq? How much unwanted acceleration are you getting?
Also do you know what kind of power you are getting from the inverter? I'm hoping to put 100kW through mine but starting to wonder how realistic that is.
Posted: Thu Sep 22, 2022 3:36 pm
by Pete9008
Bigpie wrote: ↑Thu Sep 22, 2022 2:50 pm
Edit, with my new PI values I'm able to get to 40kw before cutout
Getting better
How does it drive with the new values?
Re. the cutouts I'm pretty much out of ideas. All I can think is it's either a desat event or and IGBT die temperature cutout (if the Prius has them??). I doubt the web plotting is going to be quick enough to catch enough detail to see any more unless you are very lucky. I've been pondering on whether a data logger board, that could be plugged in in place of the ESP module, would be useful (based on something like this
https://shop.pimoroni.com/products/adaf ... 1892212935) . If it worked in conjunction with custom inverter code it would be possible to capture pretty much every input and output in the control loop on every pass through. Trouble is it is quite a bit of work, would need the inverter dissembling to fit/remove and would only help if it was a control/firmware problem. On balance I don't think it is worth doing at the moment.
Edit - Have you paralleled up the MG1/MG2 outputs on the inverter or are you just using MG2?
Posted: Thu Sep 22, 2022 4:48 pm
by Bigpie
It drives mostly well, except at 40kw it does cut out. Damien says it doesn't cutout for temperature just derates automatically. Cutouts are desat only.
I have my wifi module mounted externally so swapping it out for something else is easy
Posted: Thu Sep 22, 2022 5:02 pm
by Pete9008
Bigpie wrote: ↑Thu Sep 22, 2022 4:48 pm
Need to have a good look at the board. In the pictures there seem to be more connections to the IGBTs than I would expect and I wondered whether one of them might be a temperature sensor. The Toyota engineers do seem to have done a pretty good job of the protection so it wouldn't surprise me if there is something hidden away.
Edit - this is where the logger would work well, it would probably be able to tell the difference. If the current increases prior to the trip it's likely desat if not it isn't
That might be an option then. Would you be interested in trying it?
Posted: Thu Sep 22, 2022 5:11 pm
by Bigpie
of course
Since the starting to use it I've wanted a log to SD card option, just haven't got round to it yet. An ESP32 with SDCard would be best of both worlds.
Posted: Thu Sep 22, 2022 5:21 pm
by Pete9008
Bigpie wrote: ↑Thu Sep 22, 2022 5:11 pm
of course
I've only played with the ESP modules a little bit but didn't find them that good at time critical stuff (could be wrong but seem to remember the OS shares the processor between the WiFi stack and the app to there can be latency issues) might be worth a try though.
I've also got lazy with coding and can't manage without good in system debug anymore so tend to stick with the arm cores whenever possible!
Edit - just had a look and there is a debugger for the ESP, i also have a few modules here already. Time for a bit of reading up!
Posted: Thu Sep 22, 2022 5:26 pm
by SciroccoEV
Isn't the ESP32 a dual core?
Posted: Thu Sep 22, 2022 5:39 pm
by Pete9008
SciroccoEV wrote: ↑Thu Sep 22, 2022 5:26 pm
You're right. I was thinking of the older esp8266. The esp32 would be a much better choice!
I've just had a look at what's involved with the IDE and debugger and its not something I'm going to be looking at,. Too much of a project on top of everything else. It would be a nice solution though.
Posted: Thu Sep 22, 2022 6:09 pm
by Ev8
Pete9008 wrote: ↑Thu Sep 22, 2022 6:59 am
I can’t remember the change of Lqminusld making much difference in performance, unwanted acceleration is like basically whatever the throttle was last at before lifting off.
As for power, on the way home in 4th gear from 30mph to 70mph the battery monitor showed 295amps Soc was 80ish so 312v so nearly 100kw through a Prius gen2
Posted: Thu Sep 22, 2022 6:23 pm
by Pete9008
Ev8 wrote: ↑Thu Sep 22, 2022 6:09 pm
The unwanted acceleration sounds quite severe, not sure what could be the cause. If your wifi module is inside the ECU case it might be worth considering relocating it to get a better signal and do some plots?
Now that's encouraging
I was starting to wonder whether the Prius inverter could do that. Is that just the MG2 output?
Posted: Thu Sep 22, 2022 6:56 pm
by Bigpie
What was you thinking? Using the existing stream command with a low number of indexes and write.to sdcard or something more involved?
Posted: Thu Sep 22, 2022 7:09 pm
by Ev8
That’s mg1 and mg2 driving the 2 motors independently,
I previously used a gen2 inverter to drive a dc motor with mg1 and mg2 power stages paralleled at was able to push over 160kw through it with 80s battery. So the gen2 Prius is definitely capable of handling much more than the 50kw Toyota rate it at,
Posted: Thu Sep 22, 2022 7:14 pm
by Pete9008
Not looked at the streaming command in detail but I don't think anything ascii based would be fast enough to capture everything.
I was thinking something along the lines of a command that would stop all normal terminal activity and instead start sending binary data out at the end of each run of the control loop. Only did some very rough calcs but it looked to need a couple of Mbps to capture everything. If the esp can handle this kind of data rate (not managed to find any definative data on max rates) then it could stream it over wifi otherwise it could be copied to the SDcard. A separate app would be used to decode the saved files. Possibly over the top but it would capture everything.
Posted: Thu Sep 22, 2022 7:17 pm
by Pete9008
Ev8 wrote: ↑Thu Sep 22, 2022 7:09 pm
Wow! Ok I take it all back! Wonder why the Toyota engineers built so much spare capacity into it?
Posted: Thu Sep 22, 2022 8:18 pm
by Bigpie
https://github.com/Noltari/pico-uart-bridge raspberry pi pico uart to usb bridge should be good to cover the capture side of the task
Posted: Fri Sep 23, 2022 5:28 pm
by Pete9008
I think your first idea of an ESP32 could be the way to go. There's already a port of the web interface and that would make a good starting point.
viewtopic.php?t=1447.
Add a SD card (and possibly a real time clock to allow file time stamping) and you would have a very flexible platform. It could provide the current web page functionality. When there were no connections to the web server it could automatically switch to high speed logging to the SD card. The web page or a ftp server could then provide access to logged files over wifi (would be slow to download but faster than disassembling the inverter!). The wifi would probably also be quick enough to stream live high speed data.
