Posted: Tue May 12, 2020 12:54 pm
openinverter Community
https://openinverter.org:443/forum/
That's great
Kevin - Thank you. It looks like the topic you quoted is related to the V5 board. Is that software compatible with the V4 board?Kevin Sharpe wrote: ↑Tue May 12, 2020 1:27 pmThat's great![]()
If you're putting time into this can you also try and verify (with others on the forum) whether we have a compatibility issue with some charging stations?
viewtopic.php?f=10&t=489&p=10161#p10161
AFAIK the issue relates to all versions of the hardware/software (I checked software versions V2, V4, and V5).
Excellent. Are all backlog and future orders getting this version? Excited to contribute to this one.Jack Bauer wrote: ↑Mon May 18, 2020 3:44 pm New rev of the V5 board now with usb onboard for configuration and monitoring.
Also ditched the ULN2003 in favor of the NCV8402 for contactor/relay driving so no more silly 12v feedback through the coils issue.
Damien often uses small oil coolers in his Tesla charger builds. I don't have any direct experience (my Gen 2 chargers are currently not installed) but suspect they need very little cooling.
Keep in mind these chargers are NOT water proof, the AC in and HV in are just normal unseal able connectors and the lid has no seal on it.Boxster EV wrote: ↑Thu May 21, 2020 3:59 pm I'm thinking of upgrading to a Tesla gen 2 charger, but note there are several different iterations. Any particular model number that I should be aiming for?
I have 3 phase capability at home.
We don't have a definitive list today.Boxster EV wrote: ↑Thu May 21, 2020 3:59 pm Any particular model number that I should be aiming for?
It can probably live in the boot. European non slave variant best one to go for?tom91 wrote: ↑Thu May 21, 2020 4:45 pmKeep in mind these chargers are NOT water proof, the AC in and HV in are just normal unseal able connectors and the lid has no seal on it.Boxster EV wrote: ↑Thu May 21, 2020 3:59 pm I'm thinking of upgrading to a Tesla gen 2 charger, but note there are several different iterations. Any particular model number that I should be aiming for?
I don't think anyone has published data after testing the various versions. I'd simply select one from a vendor that has a good returns policy and test the charger as soon as it arrives.
Hi Bulletbug,bulletbug wrote: ↑Mon May 11, 2020 5:35 pm
I went back into the software and changed this same multiplier on line 827 (for phase 2) and line 832 (for phase 3).
Upload that and it WORKED! Using my AMP Clamp meter, I was able to see the amps going into the battery pack climb up to 5 amps.
Now I'm seeing that the serial monitor DC Amps (reported by the variable dccur) is inaccurate. When my Amp clamp meter is over the battery packs most negative terminal shows 5 amps the serial monitor is showing less than 0.03 on any single phase.
I'm bumping into temperature shut downs so I'll need to get my water cooling loop in place before I can figure out how to get the displayed dccur sorted out. Not sure it's even important other than on the serial monitor display.
Ryan,Cyco90 wrote: ↑Fri May 22, 2020 5:15 am
Hi Bulletbug,
In your earlier post you referenced my post where I was experiencing much the same problem as you with mis-scaled DC readings. Glad to hear you got it working!
Unfortunately, I haven't had the same luck with ours. I adjusted the scaling factors on the same lines you've mentioned, such that the serial monitor now correctly displays the pack voltage, but still no charge! I also verified with a clamp meter. Did you make any other changes to the software? Any adjustments to the output voltage scaling perhaps?
I noticed in your pasted read-outs that you were also reading a positive AC current in when in fact none should exist. I also have this symptom but I'm not sure what to make of it. I do know that some amount of power is flowing as the charger gets slightly warm after everything has been plugged in for a while. Let me know if you can think of anything else that would have made a difference to your charger now operating.
Has anyone else found solutions to this problem?
With regards to cooling, we've been able to run 2 of these chargers @ 18kW total with only a small radiator that you might find on a motorcycle and a fan to pull air through.
Cheers,
-Ryan
Ryan - One more thing. I found a mistake in my scaling post as recently as yesterday afternoon. I have since corrected the scaling number mentioned in my post for making my chargers voltage report correctly.
