Page 14 of 16
Re: Outlander rear motor and inverter
Posted: Sun Jun 23, 2024 1:39 pm
evMacGyver wrote: ↑Fri Jun 21, 2024 6:25 am
I ordered seals for spare Payen NJ452. Looks the same, dimensions seems to match, not needed to replace yet.
Well be carefull when inserting driveshafts. I replaced my RH seal and it looks like i just nicked the edge of it with sharp edge of the shaft snap ring. That steel wire at the end of the shaft will rattle and jump around when inserting the shaft. To stop it from damaging the second seal i put some nonacid grease on it which heped to stick it to its groove...
Posted: Sun Aug 04, 2024 7:06 pm
by snelly1
Hi
I have inverter with the socket missing does any one know the wire colour i should use ?
Posted: Sun Aug 04, 2024 8:10 pm
by Romale
snelly1 wrote: ↑Sun Aug 04, 2024 7:06 pm
Hi
Could you explain the essence of your question? what exactly is not clear to you- where are the +/- high-voltage batteries or thin wires and the desire to control over the can bus?
For example, I control these inverters only with OI v3 johu boards and in my opinion this is the best solution!
Posted: Sun Aug 04, 2024 9:30 pm
Hi
The rule is to connect positive to the side of fuses. That is the HV+ side.
You can see my build
https://mazdamx3ev.wordpress.com/2023/1 ... -assembly/
Notice the purple printed socket, that is the positive line.
Posted: Sun Aug 04, 2024 9:32 pm
Romale wrote: ↑Sun Aug 04, 2024 8:10 pm
How does that work? So you use the small board V3 with its I/O interface as VCU directly wired INSIDE inverter casing?
Or do you build your own VCU case? Some photos please.
Posted: Mon Aug 05, 2024 12:23 pm
by Romale
Posted: Mon Aug 05, 2024 12:25 pm
by Romale
pay attention to the 0.1 uf condenser mounted on the shutter and the GND . this gives a delay in switching on the contactor and it OVERCAME the problem of arbitrarily turning on the contactor for a fraction of a second when 12 volts are supplied.
Posted: Mon Aug 05, 2024 12:27 pm
by Romale
Romale wrote: ↑Mon Aug 05, 2024 12:23 pm
Oh... you need to load those photos as attachments.
Otherwise good point i was annoyed by relay chatter myself and i simply had to pull 12V for running contactors from a different source.
edit: Maybe you can post link to your webpage? It is just my curiosity as i was thinking of using the STM chip for a simple VCU and i see V3 has everything there already.
Posted: Mon Aug 05, 2024 12:31 pm
by Romale
I removed the wrong messages by cleaning this page))
Posted: Mon Aug 05, 2024 12:32 pm
by Romale
Posted: Mon Aug 05, 2024 12:33 pm
by Romale
Posted: Mon Aug 05, 2024 12:34 pm
by Romale
if there is no text, then everything worked out. strange.
Posted: Mon Aug 05, 2024 12:35 pm
Romale wrote: ↑Mon Aug 05, 2024 12:32 pm
Ok, now you surprised me.
So you are using OI V3 board as control brain? Do you have a wiring how to connect to Outlander power section on the inside?
EDIT: This would mean you can get 100kW from the motor for sure!!!
tnx
Posted: Mon Aug 05, 2024 12:40 pm
by Romale
arber333 wrote: ↑Mon Aug 05, 2024 12:35 pm
tnx
Even more! I have recorded 127 kW on the wattmeter!
Posted: Mon Aug 05, 2024 12:46 pm
Romale wrote: ↑Mon Aug 05, 2024 12:40 pm
WoW really nice! So that white connector is drivers...
Some questions:
1. are the transistor signals positive or open collector?
2. Do you use transistor fault signal for anything?
3. Do you use resolver with OI or do you leave it connected to outlander control board?
4. How is HV signal read? Is it 5V analog signal or do you require any special signal?
tnx for data
Posted: Mon Aug 05, 2024 1:01 pm
by Romale
1) The control signal is negative
2) no, I have not found how to use desat
3) I connect the resolver to the johu board
4) high voltage is one wire, it can be seen in the photo (connected to the yellow wire) and it is signed by me on the diagram.
Posted: Mon Aug 05, 2024 4:50 pm
by marcexec
Wow, you really love pushing stuff to the limits!
Fair play mate - I'd appreciate if you could put a more detailed instruction into the Wiki and/or post a video of this?
How is the accelaration from a dead stop vs OEM?
You made my day with this - in my mind the Outlander rear including diff is now a safe option for medium sized conversions as a "performance unlock" is possible
Posted: Mon Aug 05, 2024 7:14 pm
by snelly1
hi
The Can Bus and low voltage I have the following wire colours green,black,white,grey,violet,blue,yellow,brown,orange?
Posted: Mon Aug 05, 2024 8:36 pm
marcexec wrote: ↑Mon Aug 05, 2024 4:50 pm
Slow down guys. I expect some vibrations at the slow end of RPM as usual from OI. Also you need to do a good resolver zeroing as OI has its own interface.
OEM interface is really smooth and for comfortable ride i suspect OEM control will be better. But for sporty conversion...127kW seems too much for that small motor
And also dont forget you can drive ANY PMSM with outlander inverter and that OI board. This just makes my spare parts stock larger
Posted: Tue Aug 06, 2024 5:21 am
by Leo M
Posted: Tue Aug 06, 2024 5:23 am
by Leo M
I went to learn English, or someone forgot Russian.
Posted: Tue Aug 06, 2024 8:04 am
by Romale
Leo M wrote: ↑Tue Aug 06, 2024 5:23 am
сокращенный вариант )
A culture of behavior (writing in a common language) has not appeared. no respect for the community.
Posted: Tue Aug 13, 2024 7:45 am
by rstevens81
Romale wrote: ↑Mon Aug 05, 2024 1:01 pm
Hi just want to clarify point (2)... As I'm aware we can get confused when we all try to write in our non native language...
You have either:
(a) not found any signal yet that goes high/low during desat and your essentially running the inverter blind (from a desat point of view).
(B) The drivers self shutdown on a de sat occurance.
Posted: Tue Aug 13, 2024 10:04 am
by Romale
item "a".
