Went back the latest everything. Not able to get settings or wifi settings to show anything even when I reload now, but I did enter the node id, left it alone for a bit and I still have nothing in parameters or spot values, but it DOES have a json that appears valid when checked online. I hope that's a good thing?
"UdcDivider": {"unit":"dig/V","id":1,"value":10.00,"isparam":true,"minimum":0.00,"maximum":100.00,"default":10.00,"category":"Hardware Config","i":0},
"EconomizerDuty": {"unit":"%","id":7,"value":100.00,"isparam":true,"minimum":0.00,"maximum":100.00,"default":100.00,"category":"Hardware Config","i":1},
"InletVtgSrc": {"unit":"0=ChargerOutput, 1=AnalogInput, 2=CAN","id":8,"value":0.00,"isparam":true,"minimum":0.00,"maximum":2.00,"default":0.00,"category":"Hardware Config","i":2},
"LockDuty": {"unit":"%","id":14,"value":30.00,"isparam":true,"minimum":-100.00,"maximum":100.00,"default":30.00,"category":"Hardware Config","i":3},
"LockRunTime": {"unit":"ms","id":13,"value":1500.00,"isparam":true,"minimum":0.00,"maximum":10000.00,"default":1500.00,"category":"Hardware Config","i":4},
"LockClosedThresh": {"unit":"dig","id":11,"value":0.00,"isparam":true,"minimum":0.00,"maximum":4095.00,"default":0.00,"category":"Hardware Config","i":5},
"LockOpenThresh": {"unit":"dig","id":12,"value":0.00,"isparam":true,"minimum":0.00,"maximum":4095.00,"default":0.00,"category":"Hardware Config","i":6},
"TempSensorNomRes": {"unit":"Ohm","id":26,"value":10000.00,"isparam":true,"minimum":1.00,"maximum":1000000.00,"default":10000.00,"category":"Hardware Config","i":7},
"TempSensorBeta": {"unit":"","id":27,"value":3900.00,"isparam":true,"minimum":1.00,"maximum":100000.00,"default":3900.00,"category":"Hardware Config","i":8},
"ppvariant": {"unit":"","id":28,"value":0.00,"isparam":true,"minimum":0.00,"maximum":9.00,"default":0.00,"category":"Hardware Config","i":9},
"WakeupPinFunc": {"unit":"0=Level, 1=Pulse, 2=LevelOnValidCp, 3=PulseOnValidCp, 4=LevelOnValidPP","id":30,"value":0.00,"isparam":true,"minimum":0.00,"maximum":4.00,"default":0.00,"category":"Hardware Config","i":10},
"NodeId": {"unit":"","id":21,"value":22.00,"isparam":true,"minimum":1.00,"maximum":63.00,"default":22.00,"category":"Communication","i":11},
"CanSpeed": {"unit":"0=125k, 1=250k, 2=500k, 3=800k, 4=1M","id":22,"value":2.00,"isparam":true,"minimum":0.00,"maximum":4.00,"default":2.00,"category":"Communication","i":12},
"MaxPower": {"unit":"kW","id":17,"value":100.00,"isparam":true,"minimum":0.00,"maximum":1000.00,"default":100.00,"category":"Charge parameters","i":13},
"MaxVoltage": {"unit":"V","id":18,"value":410.00,"isparam":true,"minimum":0.00,"maximum":1000.00,"default":410.00,"category":"Charge parameters","i":14},
"MaxCurrent": {"unit":"A","id":19,"value":125.00,"isparam":true,"minimum":0.00,"maximum":500.00,"default":125.00,"category":"Charge parameters","i":15},
"TargetVoltage": {"unit":"V","id":3,"value":0.00,"isparam":true,"minimum":0.00,"maximum":1000.00,"default":0.00,"category":"Charge parameters","i":16},
"ChargeCurrent": {"unit":"A","id":4,"value":0.00,"isparam":true,"minimum":0.00,"maximum":500.00,"default":0.00,"category":"Charge parameters","i":17},
"soc": {"unit":"%","id":5,"value":0.00,"isparam":true,"minimum":0.00,"maximum":100.00,"default":0.00,"category":"Charge parameters","i":18},
"BatteryVoltage": {"unit":"V","id":6,"value":0.00,"isparam":true,"minimum":0.00,"maximum":1000.00,"default":0.00,"category":"Charge parameters","i":19},
"enable": {"unit":"0=Off, 1=On","id":23,"value":1.00,"isparam":true,"minimum":0.00,"maximum":1.00,"default":1.00,"category":"Charge parameters","i":20},
"AcObcState": {"unit":"","id":29,"value":0.00,"isparam":true,"minimum":0.00,"maximum":15.00,"default":0.00,"category":"Charge parameters","i":21},
"DemoVoltage": {"unit":"V","id":20,"value":0.00,"isparam":true,"minimum":0.00,"maximum":500.00,"default":0.00,"category":"Testing","i":22},
"DemoControl": {"unit":"0=CAN, 234=StandAlone","id":25,"value":0.00,"isparam":true,"minimum":0.00,"maximum":511.00,"default":0.00,"category":"Testing","i":23},
"ActuatorTest": {"unit":"0=None, 1=OpenLock, 2=CloseLock, 3=Contactor, 4=LedRed, 5=LedGreen, 6=LedBlue, 7=StateC","id":9,"value":0.00,"isparam":true,"minimum":0.00,"maximum":7.00,"default":0.00,"category":"Testing","i":24},
"logging": {"unit":"0=None, 1=ConnMgr, 2=HwInterface, 4=Homeplug, 8=StateMachine, 16=QCA, 32=Tcp, 64=TcpTraffic, 128=IPV6, 256=ModemFinder, 512=SDP, 1024=EthTraffic, 2047=All, 959=AllButTraffic","id":15,"value":1645.00,"isparam":true,"minimum":0.00,"maximum":2047.00,"default":1645.00,"category":"Testing","i":25},
"opmode": {"unit":"0=Off, 1=Connecting, 2=Connected, 3=NegotiateProtocol, 4=SessionSetup, 5=ServiceDiscovery, 6=PaymentSelection, 7=ContractAuthentication, 8=ChargeParameterDiscovery, 9=ConnectorLock, 10=CableCheck, 11=PreCharge, 12=ContactorsClosed, 13=PowerDelivery, 14=CurrentDemand, 15=WaitCurrentDown, 16=WeldingDetection, 17=SessionStop, 18=Error, 19=Timeout, 20=WaitForChargerShutdown, 21=WaitForContactorsOpen, 22=End,","id":2000,"value":0.00,"isparam":false},
"version": {"unit":"4=0.38.B","id":2001,"value":4.00,"isparam":false},
"githubRunNumber": {"unit":"","id":2026,"value":14.00,"isparam":false},
"lasterr": {"unit":"0=NONE, 1=CANTIMEOUT, 2=PLCTIMEOUT, 3=PRECTIMEOUT, 4=LOCKTIMEOUT, 5=EVSEFAULT, 6=RELAYWELDED,","id":2002,"value":1.00,"isparam":false},
"EvseVoltage": {"unit":"V","id":2006,"value":0.00,"isparam":false},
"EvseCurrent": {"unit":"A","id":2010,"value":0.00,"isparam":false},
"InletVoltage": {"unit":"V","id":2007,"value":0.00,"isparam":false},
"EvseMaxCurrent": {"unit":"A","id":2008,"value":0.00,"isparam":false},
"EvseMaxVoltage": {"unit":"V","id":2009,"value":0.00,"isparam":false},
"ControlPilotDuty": {"unit":"%","id":2012,"value":0.00,"isparam":false},
"temp1": {"unit":"°C","id":2003,"value":-45.87,"isparam":false},
"temp2": {"unit":"°C","id":2004,"value":-52.18,"isparam":false},
"temp3": {"unit":"°C","id":2005,"value":-51.87,"isparam":false},
"MaxTemp": {"unit":"°C","id":2024,"value":-45.87,"isparam":false},
"ContactorDuty": {"unit":"%","id":2013,"value":0.00,"isparam":false},
"AdcLockFeedback": {"unit":"dig","id":2011,"value":4033.00,"isparam":false},
"AdcProximityPilot": {"unit":"dig","id":2018,"value":3023.00,"isparam":false},
"ResistanceProxPilot": {"unit":"ohm","id":2019,"value":2819.93,"isparam":false},
"CableCurrentLimit": {"unit":"A","id":2020,"value":0.00,"isparam":false},
"EvseAcCurrentLimit": {"unit":"A","id":2021,"value":0.00,"isparam":false},
"AdcHwVariant": {"unit":"","id":2022,"value":1137.00,"isparam":false},
"HardwareVariant": {"unit":"","id":2025,"value":4005.00,"isparam":false},
"AdcIpropi": {"unit":"","id":2023,"value":73.00,"isparam":false},
"LockState": {"unit":"0=None, 1=Open, 2=Closed, 3=Opening, 4=Closing","id":2014,"value":0.00,"isparam":false},
"StopReason": {"unit":"0=None, 1=Button, 2=MissingEnable, 3=CANTimeout, 4=ChargerShutdown, 5=AccuFull, 6=ChargerEmergency","id":2017,"value":0.00,"isparam":false},
"checkpoint": {"unit":"dig","id":2015,"value":6.00,"isparam":false},
"CanWatchdog": {"unit":"dig","id":2016,"value":30.00,"isparam":false},
"cpuload": {"unit":"%","id":2094,"value":0.28,"isparam":false},
"serial": {"unit":"","value":"57197004","isparam":false}
