Page 14 of 40
Posted: Sat Sep 17, 2022 2:33 pm
by Ev8
Wow awesome work!
Posted: Sat Sep 17, 2022 2:41 pm
by Ev8
Any chance you have a build I can test later?
Posted: Sat Sep 17, 2022 2:45 pm
by Pete9008
Thanks, pretty happy with that result, it is the best result from the simulator so far
Not keen to generally release as I can't test it myself but if you are happy to take the chance I can pm you a load file?
Posted: Sat Sep 17, 2022 2:46 pm
by Ev8
Sounds good to me!
Posted: Sat Sep 17, 2022 2:48 pm
by Pete9008
Will get the build done this afternoon and send it through. Bin or hex best?
Posted: Sat Sep 17, 2022 2:55 pm
by Ev8
Bin please
Posted: Sat Sep 17, 2022 3:55 pm
by Pete9008
One final plot for completeness, a 100% run to around 3x base speed, a 2sec coast followed by 100% deceleration to zero:
So far it's looking promising. As long as the sync compensation value is kept sensible it seems to be more stable than the other builds tested on the simulator.
Edit - Just found what might be a slight bug in the OpenInverter code, not sure whether the vehicle control functions higher up the code (that the simulator doesn't call) will fix it but just in case they don't I'll mention it here. When coming to a stop under regen the Iq current drops to zero as soon as the vehicle is stationary due to the limits on the Iq PI controller, however, the -Id commanded by Mtpa continues for as long as the negative torque command continues (you can just see the effect at the right hand side of the above plot). As soon as the negative torque command is removed Id returns to zero.
Posted: Mon Sep 19, 2022 11:47 am
by Bigpie
Some findings from my playing around, I need to have quite a low curp of 30, I can get up to 540a on stall but as soon as the car is allowed to move it cuts out. At the lower values the min and max are much closer together. Need to do further debugging on why with the handbrake off it cannot get this high. This is with ldminusld of 0 but having 0.6 seems to behave the same.
- 540a.csv
- (1.34 KiB) Downloaded 322 times
Posted: Mon Sep 19, 2022 12:37 pm
by Ev8
Have you tried a p led tuning? For me it delivered the same or better drivability with less spikes, Im currently happy running kp=400 ki=350 I know mine is gen 2 but…. It could be with a low kp your control doesn’t have the authority to catch them
Posted: Mon Sep 19, 2022 12:45 pm
by Bigpie
p led tuning? With p above 50 the difference between the min and max values gets larger. I'm guessing my motor will have relatively low inductance compared to larger motors such as the Outlander rear or Leaf etc. Maybe that's a factor.
Posted: Mon Sep 19, 2022 1:05 pm
by Pete9008
Bigpie wrote: ↑Mon Sep 19, 2022 11:47 am
p-30-i-40.csv540a.csv
You're right that smaller motors will need lower kp but that does seem very low. Would expect some difference between min and max, say 20-30% (just not the 80-90% you had before) so might be worth increasing the values a bit.
Good to see that the Prius inverter looks happy at those currents, is it warming up much?
I'm becoming a little suspicious about the resolver measurement. Any idea what the motor position was doing in those plots?
Edit - just had a look at the csv files, the currents there do match surprisingly well which is good. I think you can get away with higher kp, maybe twice what you have, maybe even a bit more.
Very interested in seeing what the motor angle is doing while the motor is locked stationary.
Edit2 - Just to explain my reasoning on the above comment - the only explanations that I can see as to why integral led tuning could be an advantage is either if it was masking a bug (and there was the windup bug, now fixed, which it might have helped mask) of if there is a underlying noise problem. The integral term has a bit of a averaging effect which might help control noise. If this is the case then proportional led tuning could make things worse. There is no sign of noise being a problem on the current traces above which is what makes me wonder about the motor angle. Noise on the angle would also be more obvious when moving than when the rotor is locked.
Edit3 - out of interest did you take any plots using your original ki/kp values?
Posted: Mon Sep 19, 2022 2:42 pm
by Bigpie
This is with: curkp: 40, curki: 30, fwkp: 0, fwki:0, lqminusld: 0, throtramp: 100, throtcur:2
Posted: Mon Sep 19, 2022 2:47 pm
by Ev8
Have done some quick runs this afternoon, turns out with mtpa off I can use field weakening, but performance is pretty lacking (this is with synof centered) but everything behaves. With mtpa on I can’t go more than fwki=1 without getting unwanted throttle when f/w comes in. Regardless of where syncof is at. And also regardless of my mtpa settings I’ve tried between 0.5-3mH 90-150
Unfortunately it looks like In the chase for power it’s possible to gain positive torque by advancing syncof (at the cost of regen torque, a way of advancing syncof with throttle, (within confines) would work better than being linked to frequency.
Posted: Mon Sep 19, 2022 2:58 pm
by Pete9008
Bigpie wrote: ↑Mon Sep 19, 2022 2:42 pm
stationary.csv
moving.csv
There is something not quite right there. On the stationary plots first the current:
Was that spike a trip?
On the angle:
Now if it was trip then maybe that's to be expected, if not it shouldn't be there!
Edit - Just had a look at potnom:
Surely that shouldn't be there?
BTW - all the above are for the stationary test.
Edit2 - Apart from the occasional noise spikes that seem to be appearing on multiple channels I can't see anything wrong here. Could they be a plotting artefact or are they real? If real it looks like they are either caused by or causing the trips?
Posted: Mon Sep 19, 2022 3:06 pm
by Pete9008
Ev8 wrote: ↑Mon Sep 19, 2022 2:47 pm
Interesting! Need to think about the interaction of Mtpa and FW a bit more, not too sure what's going on there. Surprised that syncofs doesn't affect this, could it need a power off for the new value to take? - need to check the code to see.
Edit - does FW behave correctly without Mtpa? No unwanted regen/acceleration and stable (poor performance without Mtpa is to be expected)?
Not keen on adjusting syncofs to look for power (it can be used this way but will also have side effects), it really should be set to the middle of the deadband. What sync compensation (syncadv) value are you running (it's effect does scale with frequency in the build you have)?
Posted: Mon Sep 19, 2022 3:27 pm
by Ev8
Yes I always have to cycle power when changing syncof. F/W seems just fine with a range of syncofs
Some reading seems to suggest maybe advancing syncof at higher motor speeds could help gain power
The optimum angle to apply current for the magnet-flux component of torque is 90° (Equation 15.7); for Figure 15.26, the optimum angle of current (with respect to magnet flux) for the reluctance component of torque is 135°. The optimum angle for a hybrid motor at low speeds (that is, without field weakening) will be between 90° (magnet-flux optimized) and 135° (reluctance torque optimized). Since the reluctance component is usually a fraction of the magnet torque in PM motors, the optimal angle is much closer to 90° than it is to 135°. Still, some angle advance (perhaps 10° or 15°) will often increase the torque of a motor as much as 15%. This is one example of how to take advantage of reluctance torque; there are other motor structures that use reluctance torque differently.
https://www.sciencedirect.com/topics/en ... nce-torque
Posted: Mon Sep 19, 2022 3:29 pm
by Pete9008
Agree, that's what Mtpa does. If you take the vector sum of Id and Iq then that its the angle the article talks about. For a low saliency motor Id is low and the angle is near 90degrees, on a higher saliency motor Id increases and so does the angle.
Edit - see what you mean - bit more reading needed!
Edit2 - no think that agrees with the Mtpa algorithm we use. When the article uses the term low speed they mean outside FW. Above base speed extra Id is needed which has to reduce the angle (and reduce torque) but that's the compromise for running above base speed.
Edit3 - in fact I've seen that article before, it's the one that suggsets 10-15degrees advance and what made me wonder about the amounts of -Id that were being used. Our motors do seem to need a lot more than 15degrees based on the lqminusld that everyone seems to need to use (Iq and Id roughly the same size will put us near the 135degree maximum quoted there).
Posted: Mon Sep 19, 2022 3:34 pm
by Pete9008
What syncadv value are you running? It should be 5.
Edit - could really do with a plot of what happens when FW comes in, is there any chance that your wifi is up to it?
Posted: Mon Sep 19, 2022 3:37 pm
by Ev8
Ok that makes sense. Back to the thinking! When I run mtpa and f/w on your build I use a syncadv of 5
by Ev8
I will try to log when next out but man my Wi-Fi sucks
Posted: Mon Sep 19, 2022 3:41 pm
by Pete9008
Ev8 wrote: ↑Mon Sep 19, 2022 3:37 pm
You could try a little more but with the warning that the simulations showed stability dropping fast above 5. This would give you a little more advance at high speeds. Any value less than 5 should be fine and reduces the angle advance.
Any idea why it's so bad, is the ESP module inside the ECU case or outside?
Posted: Mon Sep 19, 2022 3:45 pm
by Pete9008
I'd use syncadv=5 all the time in my build. It's effect should be useful whether or not Mtpa and FW are enabled.
Posted: Mon Sep 19, 2022 3:46 pm
by Ev8
Yes I should have worded that differently it’s always on 5
Posted: Mon Sep 19, 2022 3:52 pm
by Bigpie
Pete9008 wrote: ↑Mon Sep 19, 2022 2:58 pm
No trips on this test
Posted: Mon Sep 19, 2022 3:55 pm
by Ev8
now I want to read this about mtpa
Abstract:Due to the nonlinearity of the flux-linkage profiles of the interior permanent magnet synchronous machine (IPMSM), the conventional motor model cannot be used for both maximum torque per ampere (MTPA) control and torque estimation. This paper proposes a nonlinear flux-linkage model for IPMSM with eight coefficients to fit the real d-axis flux-linkage, q-axis flux-linkage, MTPA, and torque. The corresponding torque equation and MTPA condition are presented. The factors in the proposed model can be obtained by solving an optimization problem with the limited information from the machine instead of the measurement throughout the map. The comparison of the characteristics between the proposed algorithm and FEA data is illustrated.View less
https://ieeexplore.ieee.org/document/7520215/
