Page 13 of 14
Re: ESP32 Based Web Interface & Data Logger
Posted: Sat Jan 27, 2024 7:32 am
by Leo M
The interface is working... but there is a problem with downloading the parameters file! when uploading, the transmission fails at the end of the parameter list. Have you tried uploading a parameter file via the interface?
Posted: Sat Jan 27, 2024 8:54 am
by Leo M
It is necessary to fix something in the code ((( according to the test results, this gadget cannot be considered fully functional.
Posted: Sat Jan 27, 2024 9:54 pm
by johu
I have to test parameter upload. What other issues did you find?
Posted: Sun Jan 28, 2024 7:50 am
by Leo M
I was assembling this interface for use with your 16-channel bms. the delivery turned out to be long and I decided to connect the interface to the version 3 board. the general conclusion is unstable operation, hanging, breaking of messages. …
Posted: Sun Jan 28, 2024 9:59 am
by uhi22
From some experiences I learned that the ESP is picky regarding the power supply. Wifi causes supply current peaks, and if this leads to certain voltage drops, it causes random effects. The other issue is CAN bus load. The ESPs CAN controller is crap (they even avoid to call it CAN), it seems to be fine with single messages and low bus load, but I do not trust it for more. I'm a little bit tired to analyse and workaround espressifs crap. Maybe better to use an external real CAN controller, to have a solid reliable piece of hardware.
Posted: Sun Jan 28, 2024 10:42 am
by Leo M
maybe it's worth trying to implement can on stm32 and the interface on esp8266 in the likeness of the version 3 board?
Posted: Tue Jan 30, 2024 11:19 am
by johu
Either that or some dedicated CAN chip the JLCPCB stocks like MCP2515. Some say that chip is problematic, too but I don't know details.
Also I now remember something strange: when I had the interface connected via the CHAdeMO port I noticed it had flawlessly downloaded the inverter json file (because that is on the same bus and had node id 1). So apparently if it is first powered up and then connected to the bus it works. Have to try that again...
Posted: Wed Feb 07, 2024 7:40 am
by Yahha777
johu wrote: Sat Jan 27, 2024 9:54 pm I have to test parameter upload. What other issues did you find?
I am loading parameters
I tried it on both controllers. But the "CAN MAPPING" tab does not display anything. But I also noticed this on the old ESP 8266 interface connected to the controller via UART.
Posted: Wed Feb 14, 2024 4:11 pm
by johu
I have used the gadget some more. I found that R6 is way to high at 100k! That disturbs CAN comms. Either bridge it completely or replace with 10k. This must have been the reason why it disturbed the bus in my car.
Also it only downloaded the parameter json partly and that led to errors in displaying the CAN map. Please retry.
Posted: Wed Feb 14, 2024 6:56 pm
by Yahha777
johu wrote: Wed Feb 14, 2024 4:11 pm R6 is way to high at 100k! That disturbs CAN comms. Either bridge it completely or replace with 10k
Is this what you mean?
Posted: Wed Feb 14, 2024 7:33 pm
by johu
Exactly! On the CANLite that I based the board on that you can buy in the shop it is 100k
Posted: Fri Feb 16, 2024 8:37 am
by uhi22
Just to summarize my experiences:
1. From other ESP32 projects I know, that the ESP32 is picky regarding the power supply. I had an application, running wifi, and randomly after days of perfect working, it crashed and needed a power-on-reset to work again. After using a different power supply and a short, direct soldered power cable instead of the USB cable, the issue was gone.
2. The ESPs "CAN" controller is buggy. After debugging my own software for a longer time, it became clear, that a hardware issue causes hang-up. Found descriptions from other people, and the conclusion is, that it needs fast interrupt reaction to avoid running into unrecoverable hardware buffer overflow.
3. Different versions of the espressif driver seem to have different issues with the queue handling in the software. In my wifican project (https://github.com/uhi22/wifican) I found and worked-around some strange things. So the overall impression is: not reliable.
4. On the other hand, there are examples, where the ESP32 perfectly runs over years, with Wifi, web interface, MQTT, with no hang-ups or resets at all. I had an Sonoff PowR2 running Tasmota, four years running perfectly fine.
5. The web interface for parametrization and spot values works on my side 90%. Sometimes it needs a restart of the ESP and/or control unit, and reload in browser, to work. But in most cases it is fine.
6. The software update using the web interface usually works perfect the first time a day. But the second or third often fails, software is erased, and I need to use the STLink to flash again.
7. There are wrongly labeled or defective CAN transceiver on the market. If strange things happen, it is worth a try to use a different transceiver, and/or make some scope measurement of the CAN TX, CAN RX, CANH, CANL.
What I propose as improvements:
- short-term: check the currently used "bad" devices regarding power-supply (big elcap?), transceiver and transceiver resistor(s).
- mid-term: using a real CAN controller and transceiver. The MCP2515 controller with MCP2551 transceiver has been working here since 10 years perfectly (on AVRs)
- Improve the verbosity of the web interface regarding connection status. At the moment it is sometimes not clear, whether the shown spot values are "live" or just a left-over. There is an ongoing improvement activity here: https://github.com/jsphuebner/esp8266-w ... /issues/23
Posted: Fri Feb 16, 2024 4:18 pm
by asavage
No. 7 (counterfeit/non-working CAN transceivers) has bit a lot of people I know. When you're lucky, they work not-at-all: easy to locate, curse at, replace.
Unlucky ones fail intermittently :(
Posted: Fri Feb 16, 2024 4:30 pm
by johu
uhi22 wrote: Fri Feb 16, 2024 8:37 am From other ESP32 projects I know, that the ESP32 is picky regarding the power supply
Oh yes, same goes for ESP8266
uhi22 wrote: Fri Feb 16, 2024 8:37 am Different versions of the espressif driver seem to have different issues with the queue handling in the software
It doesn't seem to affect the SDO protocol as that
a) uses message filters to only receive the expected SDO reply
b) is request-reply
uhi22 wrote: Fri Feb 16, 2024 8:37 am The web interface for parametrization and spot values works on my side 90%
I found once the json is downloaded it is 100% reliable (have you had hickups in that case?). But when you do an update that requires re-downloading the json you can run into troubles where the json download is incomplete. This needs to be implemented more robustly, i.e automatic re-download of incomplete files.
uhi22 wrote: Fri Feb 16, 2024 8:37 am The software update using the web interface usually works perfect the first time a day
I don't have a 100% success rate on that either. It sometimes works 5 times in a row and then fails. The boot loader, as intended, is then in the boot loop where it keeps sending the welcome message but the ESP doesn't really seem to pick that up. If I then run the firmware update via CAN from my PC it runs just fine. I think this can also be fixed in the ESP firmware.
Posted: Fri Feb 16, 2024 5:12 pm
by royhen99
I am having problem with get <param> on command line via CAN/WIFI interface. Set works ok and both work with the on board ESP8266. Get probably isn't used very much but I am using it with a python script for testing.
Posted: Fri Feb 16, 2024 5:26 pm
by johu
royhen99 wrote: Fri Feb 16, 2024 5:12 pm I am having problem with get <param> on command line via CAN/WIFI interface
Yes, get is not implemented. Basically the esp32 firmware translates the legacy string commands to CAN commands (whereas the esp8266 just forwarded them to UART).
You'd have to do "stream 1 <name>" for now
Posted: Fri Mar 01, 2024 5:36 pm
by johu
I ran the ESP32 module in Touran again and at least now it no longer disturbs the bus. That was the 100k resistor indeed.
It did also download the json from inverter and VCU but VCU needed a few attempts.
Strange thing was with the CAN mapping which wasn't always fully received and also the parameters and values were not received in the correct order. So e.g. "opmode" would receive the value of "version". That could be down to the way libopeninv queues CAN messages or down to retries. It is especially pronounced on the busy CAN bus, with just 1 or 2 devices it doesn't happen.
The fix is easy as the reply contains the addressing information. So rather than assuming the reply matching the last request I should read what the reply actually contains. Likewise with the CAN map as I assume it's the same issue.
Posted: Wed May 01, 2024 8:39 am
by smithloo
I was thinking more of ditching the separate decoder and trying to import the bin file directly into pulseview. The documentation mentions a python api for adding decoders, any idea whether that can add importers too? I've used the native qt graphing in the simulator and it isn't as quick as pulseview sounds. It can cope with tens of seconds of simulator data but it would choke on a 10min log. Its also a fair chunk of work to get nice synced scrolling, zooming, hover over, etc. Using the pulseview display routines makes a lot of sense. Its tricky to log more parameters using this scheme as its using all the serial bandwidth as it is. If we want other parameters the Johannes binary parameter streaming is the way to go. A custom pulseview based app talking over tcp could work for that though? For the time being Ill add to the standalone decoder to scale uq and ud, calculate i3, iq and id, scale angle to degrees and provide a real time stamp which will give something usable now but longer term having a single app to decode and display would be nice.
Posted: Thu May 02, 2024 1:18 pm
by johu
I have fixed another issue that sometimes caused a strange download of the json: https://github.com/jsphuebner/libopenin ... 533e18e999
It was basically a buffer overflow caused by buffer pointers being not declared volatile and the compiler therefor optimizing out the wait loop.
Posted: Tue May 28, 2024 4:47 pm
by Mitchy
A few more suggestions... I'd roll these into a pull request, but rather than risk messing up the pull, I'd post here:
Line 343 Add: DBG_OUTPUT_PORT.println(result.c_str()); into the JSON Error handling, to give some more details on the JSON parse.
  if (result != DeserializationError::Ok) {
    SPIFFS.remove(jsonFileName); //if json file is invalid, remove it and trigger re-download
    updstate == REQUEST_JSON;
    retries = 50;
    DBG_OUTPUT_PORT.println("JSON file invalid, re-downloading");
    return false;
In my case, After adding some items to the Param Database for Zombie, I apparently exceed the size reservation.
Afterwards I increased the JSON size limit from 30000 to 40000:
Line 331 - DynamicJsonDocument doc(40000);
Posted: Wed May 29, 2024 8:33 pm
by johu
Oh that is indeed possible with that host of parameters. Will add the size change, maybe the output (quite long)
Posted: Tue Jun 11, 2024 1:04 pm
by grgumxlm
uhi22 wrote: Sun Jan 28, 2024 9:59 am From some experiences I learned that the ESP is picky regarding the power supply. Wifi causes supply current peaks, and if this leads to certain voltage drops, it causes random effects.
I can confirm this.ESP32 cant run on 3.3Volt in the same style like the esp8266 can. The current peaks on esp32 looks like they are bigger then esp8266 and crash the esp32.
In conclusion:
If it have to run on 3.3Volt: If you have already some esp8266 you can make it work. If you have to buy something, take the olimex MOD-WIFI-ESP8266 like johu did on the openinverter mainboard for years. https://www.olimex.com/Products/IoT/ESP ... e-hardware
If it have to run on 5Volt: Take any esp32 (not S-something, the regular esp32) and connect it to its 5Volt pins. The esp32-pcb itself have the dcdc conversion to deliver enough power for the esp32 to work without crashing.
Posted: Mon Jun 24, 2024 9:06 pm
by johu
I have increased the json buffer to 50k and added baud rate selection in the CAN variant https://github.com/jsphuebner/esp32-web ... 84fe9f68b6
Posted: Tue Jun 25, 2024 3:10 pm
by PoloLbricolo
Hello,
I just installed the latest version on my esp 32 can lite module so now i have the button to change the CAN speed just under the node ID, amazing.
Problem is that it seems to not work, as in the can speed doesn't change when i change it on the button.
regardless of the can spee displayed here the web interface remains with what it was initialised with ie 500kbps.
so i can't change the can speed of the focci box to 250kbps and then change the can speed of the web interface to 250kbps. I've tried to change the default speed in the code of the web interface to 250kbps only to discover that it still doesn't work.
by it doesn't work i mean that the web interface isn't comunicating with the focci box.
HW V4.5a
What am i doing wrong ?
Posted: Tue Jun 25, 2024 4:04 pm
by johu
Have you also updated the ESP firmware or only the web files?
When you open dev tools (F12 in good browsers) you should see the request going out and when selecting it and viewing the response should see something like this
So two comma separated values, not just one
