I've still not sorted it. Distracted with new project
Re: [DRIVING] VW Beetle 2003
Posted: Sun Dec 17, 2023 5:39 pm
by Bigpie
With the beetle now being my only (was) working vehicle after getting rid of the diesel backup, I've got nothing to drive.
Posted: Sun Dec 17, 2023 11:19 pm
by Alibro
Eurocarparts.
Posted: Mon Dec 18, 2023 4:25 am
by Proton
Sorry for you.And it is not summer so you can uČe an electric bicicle.
Posted: Mon Dec 18, 2023 9:22 am
by andybpowell
I had a few MK1 Golf GTi's in the 80's and broke quite a few CV joints and it was always pulling away with the wheel on lock and this will be much worse on an EV with the high levels of torque I wonder if production EV's have stronger CV joints than ICE version's
Posted: Mon Dec 18, 2023 11:44 am
by Bigpie
This might be it. I pulled out of my street and was accelerating enthusiastically when it make a clunk.
Posted: Mon Dec 18, 2023 11:48 am
by andybpowell
Driving like a hooligan
Posted: Mon Dec 18, 2023 12:00 pm
by crasbe
Built in theft protection. When you drive it like you stole it, it will immobilize itself
Posted: Mon Dec 18, 2023 2:02 pm
by Bigpie
New inner CV didn't fix it
Posted: Mon Dec 18, 2023 2:38 pm
by Alibro
Bigpie wrote: āMon Dec 18, 2023 2:02 pm
What made you think it was the inner CV, any that failed on me it was the outer.
with the car on the ground if you grab the drive shaft and push it around is there movement?
There should be slight movement in and out of the cups to allow for the suspension going up and down but no lateral movement
Have you checked for an issue in the brake caliper or even something really silly like a wheel weight catching?
Posted: Mon Dec 18, 2023 3:21 pm
by jrbe
Is easy to drop a ball out of the cv joint while trying to get them in but it's not obvious. The cage can also explode. Do you see evidence of the boot twisting?
Did the thunk happen with the cv disconnected ā gearbox issue..?
Posted: Mon Dec 18, 2023 3:30 pm
by andybpowell
I agree in front wheel drives I've only ever had outer joints fail the greater angles they operate under stresses the joint and the gaiter but aint hindsight a wonderful thing
Posted: Mon Dec 18, 2023 7:33 pm
by Bigpie
A couple motor mounting bolts have snapped. Theory is, I'd not use thread lock and they've loosened and then the final impact snapped them. So motor is twisting entire engine/gearbox etc. It explains why slow turning by hand, or coasting was ok. It was immediately obvious when I had a helper to observe.
Posted: Mon Dec 18, 2023 8:30 pm
by andybpowell
Repairable?
Posted: Mon Dec 18, 2023 8:42 pm
by Bigpie
Got some left hand drill bits and extractors coming tomorrow to hopefully do the trick.
Posted: Mon Dec 18, 2023 9:28 pm
by andybpowell
all useful tools you'll use in the future young man I can say that because if your github name is any indication your the same age as my son, damn I,m old
Posted: Mon Dec 18, 2023 9:37 pm
by Bigpie
Young my knees says different. I'm not far off 40
Posted: Mon Dec 18, 2023 9:48 pm
by Alibro
Bigpie wrote: āMon Dec 18, 2023 7:33 pm
Bummer, good luck sorting it.
Posted: Mon Dec 18, 2023 9:52 pm
by andybpowell
Bigpie wrote: āMon Dec 18, 2023 9:37 pm
yea but it's better than nearly 60
Posted: Tue Dec 19, 2023 4:49 pm
by Bigpie
Well the left hand drill bits were great. Got the bolts out. Bad news the probably remains
Posted: Tue Dec 19, 2023 4:55 pm
by andybpowell
I'm assuming you meant problem remains ? Gotta love predictive text
Have you tried it with the driveshaft disconnected
Posted: Tue Dec 19, 2023 5:58 pm
by Bigpie
Yea, it's fine without the drive shaft connected. Next thought is outer CV or bent shaft?
Posted: Tue Dec 19, 2023 6:37 pm
by jrbe
Looks like something binding or catching. Brake rotor isn't destroyed?
If the brakes are OK that leaves wheel bearing (unlikely) or outer cv.
Can you turn it by hand and feel where it hits? If so get it close and hold the driveshaft while you rotate / bump nto it. Might be able to narrow it down.
My $ is on outer cv joint.
Posted: Tue Dec 19, 2023 6:52 pm
by Bigpie
Can't feel anything when turning by hand, turns smoothly
