Re: Turbine powered cart
Posted: Sun Apr 26, 2026 4:19 am
Finished the upper motor mounts this morning. Had some errands to run this afternoon and after I got back I managed to get the engine installed. It's actually pretty much perfectly balanced with the generators attached to the back. Used the engine hoist to set it in place and hold it in position while I made the turnbuckles that attach to the top mount and control the level of the engine.
Planning electrical now. I need a box to hold stuff like the rectifiers, tachometer, relays, etc. I was planning on putting it on the opposite side of the inverter but I think I am going to mount it to the top of the inverter since it has some mounting bosses. I'll put the water pump, fuel pump, and other stuff on the other side. Also trying to figure out where to put the pedals. I have a good idea where, I just need to make the mounts.
IMG_8842 by Jerry Biehler, on Flickr
IMG_8845 by Jerry Biehler, on Flickr
IMG_8846 by Jerry Biehler, on Flickr
IMG_8847 by Jerry Biehler, on Flickr
IMG_8848 by Jerry Biehler, on Flickr
