Page 2 of 3
Re: '63 VW Transporter - EM57 Powered.
Posted: Sun Jun 29, 2025 12:11 pm
by jerrykco
ianlighting wrote: ↑Sun Jun 29, 2025 7:06 am
You might want to take a look at your gearbox before you start getting too far into the build. .
Hi Ian,
I have a newly rebuilt freeway flyer transmission and a new set of higher geared transaxles. So what you see in the picture will be replaced.
Above in previous posts in this thread, I mentioned that I would be reviewing how others mounted their Leaf motor, I was thinking of your project.
I'll be looking it over in great detail and may be asking you some questions if you don't mind.
Posted: Sun Jun 29, 2025 12:26 pm
by ianlighting
jerrykco wrote: ↑Sun Jun 29, 2025 12:11 pm
Hi Ian,
Sounds good. Happy to answer anything. I should add, I’m not going to be the right person to help on Zombie VCU stuff, and I do consider myself to still be very much a learner on the whole world of EV conversion, but if there’s any insight I can share I’ll be happy to.
Posted: Sun Jun 29, 2025 12:43 pm
by jerrykco
Bratitude wrote: ↑Sat Jun 28, 2025 5:40 pm
that sucks, you could possibly harvest the good cells from the module for other purposes. But I would just slowly drain that cell to 0, and do it in an isolated area. Just reduces the chance of anything happening
Yeah, it does. All 32 Modules are currently sitting at 21.7V including the damaged one. I'll isolate it outside and use a big ass ceramic resister to drain it. Once drained I know there is a facility that recycles the lithium batteries in the USA. I'll see if they want it.
https://li-cycle.com/
Posted: Sun Jun 29, 2025 1:19 pm
by jerrykco
ianlighting wrote: ↑Sun Jun 29, 2025 12:26 pm
There is significant difference between your transmission and mine. And also how they are mounted to the frame I see. I've been examining them from yours and my pictures. I also included a pic of the gear reduction axle transmission.
Not insurmountable "problems" yet to be solved. Ha!
Posted: Sun Jun 29, 2025 1:44 pm
by ianlighting
I’m not surprised there are differences given the 70’s bay window was the next generation on from your split screen type.
In case you’re not familiar, The Samba is a great place to get all the expert VW knowledge if you need it.
Posted: Mon Jun 30, 2025 8:31 am
by J0hannes
jerrykco wrote: ↑Sun Jun 29, 2025 1:19 pm
It is so cool, that you actually have
portal axle gearing on that!
I suppose the gear reduction axle transmission you refer to is the gearbox on the wheel hub?
A benefit is increase in ground clearance under the axle, but downside additional possible failure point and transmission losses.
You may want to open those boxes and see how beefy gears they have in before giving full chooch of the Leaf motor
Posted: Mon Jun 30, 2025 12:35 pm
by jerrykco
J0hannes wrote: ↑Mon Jun 30, 2025 8:31 am
Thanks for the link, JOhannes. Very Interesting read. I was told that it was a 1T transporter and the Wiki Confirms that!
"In 1962, a heavy-duty Transporter was introduced as a factory option. It featured a cargo capacity of 1,000 kg (2,205 lb) instead of the previous 750 kg (1,653 lb), smaller but wider 14" roadwheels, and a 1.5 L, 31 kW (42 PS; 42 bhp) DIN engine. This was so successful that only a year later, the 750 kg, 1.2 L Transporter was discontinued. The 1963 model year introduced the 1500 engine – 1,493 cc (91.1 cu in) as standard equipment to the US market at 38 kW (52 PS; 51 bhp) DIN with an 83 mm (3.27 in) bore, 69 mm (2.72 in) stroke, and 7.8:1 compression ratio.
I'll check the gears in the portal axles soon and post pics,
Posted: Thu Aug 21, 2025 11:15 pm
by jerrykco
I have been working on my CAN_BUS display. This is my Prototype.
I am programming it on a Stone HMI Display I purchased from stoneitech.com in China. I bought it with the stm32 option so I can use the Leaf motor and Orion BMS CAN Messages to update values for the widgit items on the display in real time. I haven't
looked into the Orion BMS Messages yet.
One question is will the Zombiverter have additional CAN Messages I might need and is there a list?
From the Leaf logfile I got from a friend I see:
0X1DA message updates the RPM and HV Battery Voltage.
0x55A message updates the Inverter and Motor Temps.
I am still looking for AMPS [ +/- ]
Help always appreciated.
Posted: Fri Aug 22, 2025 1:55 am
by T1Terry
jerrykco wrote: ↑Sun Mar 16, 2025 1:51 pm
Now for some Pictures:
Rescuing the Transporter:
The Battery
The EM57
Wow, I've only just stumbled across this build thread and the second post made my eyes water .... an early model Doca they are known as over here, (dual cab ute) I'll get back into the ready now, but I just had to congratulate you on your find .... and having the spirit to turn it into an EV ..... I'm concerned about converting my '74 bay Kombi to electric because they are such nostalgic vehicles, a '63 Doca, that is a whole new world of nostalgic $$ value
T1 Terry
Posted: Fri Aug 22, 2025 2:07 am
by T1Terry
If you are really thinking about using the early reduction hub gearbox, you will need to find a VW transmission specialist who knows these early gearboxes to build it strong enough to handle the torque.
If you go with the floating axle gearbox, count the number of ribs in the gearbox body, you are looking for a 6 rib box or even one of the later boxes, or a special built performance gearbox they use in the open wheeler race cars with the big power motors.
After spreading one of the reduction hub gearboxes across a highway when I bolted a 6 cyl 2850 Holden motor to it, simply accelerating to keep up with traffic, no side stepping the clutch in first gear stuff, I was in 3rd gear at the time, those early gearboxes were about maxed out with the 1500 single carb flat four VW engine.
T1 Terry
Posted: Sat Aug 23, 2025 12:19 am
by Bratitude
T1Terry wrote: ↑Fri Aug 22, 2025 2:07 am
T1 Terry
Sorta.
in this application there won’t be much of any shifting, or rapid, sharp changes in torque. The shear strength is more of a concern.
the comparing a high hp engine swap on a stock gearbox vs an equal power electric motor dosnt work. How the torque is applied through the drive line is very different.
Also how much throttle ramp is setup. Can make the throttle response very smooth and gradual instead of just dumping everything through the gearbox.
But yes a vanagon 6 rib would be a good bet. But I don’t think that’s an issue in this case.
Posted: Sat Aug 23, 2025 12:54 am
by jerrykco
This restoration will not be for racing. I'm thinking of Sunday coffee with the wife, or Ice-cream runs with the grandkids or an EV Show and tell in a park or meet-up.
Posted: Sat Aug 23, 2025 1:23 am
by T1Terry
jerrykco wrote: ↑Sat Aug 23, 2025 12:54 am
While you are at this stage of the build, I'd seriously look at either changing the gearbox or doing away with it all together and running the whole leaf motor and gearbox, then you can eliminate having to change gears at all.
There is a lot of room under a Doka rear tray to mount batteries ...... and that was where the load was designed to be carried.
Finding the metal sides that fit on the rear to change it from a flatbed into a ute might be a challenge ..... although, I don't think there are many parts that haven't been recreated somewhere in the world, for every VW model ever made ..... while they were still VW's ..... Brazilian stuff maybe not, they were a real Frankenstein affair .....
T1 Terry
Posted: Sat Aug 23, 2025 2:16 am
by Bratitude
T1Terry wrote: ↑Sat Aug 23, 2025 1:23 am
T1 Terry
his stock gearbox is completely fine for the application. KISS, and he has a working doka. Having the multiple gears can be handy when hauling different loads or for city vs hwy.
Posted: Sat Aug 23, 2025 2:53 am
by jerrykco
While you are at this stage of the build, I'd seriously look at either changing the gearbox.....
There is a lot of room under a Doka rear tray to mount batteries.....
T1 Terry
I have a new transmission. Just not a six rib.
The batteries will be going under the rear seat and where the gas tank I removed was.
I have a set of fold down sides and the rear tailgate too.
Posted: Wed Aug 27, 2025 10:27 pm
by jerrykco
I decided I needed another widget on my display:
Re: '63 VW Transporter - EM57 Powered. (HELP - CAN Messages
Posted: Wed Aug 27, 2025 11:13 pm
by jerrykco
Regarding the Display I am programming (see post above) that has the ability to receive and filter CAN Messages, I am trying to get a handle on CAN messages I would like to process and display appropriately. I will not have a VCU. Only the ZV + Leaf Inverter-Charger-Motor stack and the Orion BMS.
I have searched the forum for Zombieverter or "CAN Messages" but am unable to find a list of the CAN messages it will produce.
I also looked/searched in the
https://openinverter.org/wiki/Special:SpecialPages thinking that would be a good place to look. No Cigar!
If I am using the Zombieverter in a leaf stack without another VCU, is it just the messages from the Leaf Inverter-Charger-Motor stack and if using an Orion BMS the Orion CAN Messages that are the source of the the CAN Messages?
Posted: Thu Aug 28, 2025 12:11 am
by T1Terry
I wonder if your display could be used on the Lexus GS450h drive unit and inverter with the Zombi inverter board fitted, and with the Gen 2 Prius and inverter with a Zombi board fitted ..... Hope so, that looks neat .....
T1 Terry
Posted: Thu Aug 28, 2025 2:27 am
by jerrykco
T1Terry wrote: ↑Thu Aug 28, 2025 12:11 am
T1 Terry
Well with the limited knowledge I have so far, I can't see why any combo with ZV wouldn't work.
The product is simple:
Create the widgets using their graphical user interface (each widget has a unique name
Then filter the can messages you want to act on
If you get a message you want to act on do any calculations you need to update the pointer position for the particular widget.
Posted: Thu Aug 28, 2025 4:01 am
by T1Terry
That all looked like a language I should understand
I'm sure once I start actually looking at it, it will all become obvious ..... that I can figure it out or I should run for the hills ..... Getting old seems to have that affect I've been noticing lately
T1 Terry
Posted: Thu Aug 28, 2025 4:21 am
by Bratitude
Zombie supports obd-ii so any generic gauge interface works.
For example an elm dongle and torq pro gauges on a tablet will display data.
Or real dash, etc
And you can also map to what ever ids you like.
So you can ju
Posted: Thu Aug 28, 2025 11:42 am
by jerrykco
Bratitude wrote: ↑Thu Aug 28, 2025 4:21 am
Or real dash, etc
So you can ju
Hey Bratitude, looks like you sent before you finished typing. "So you can ju" ........ I waiting with anticipation.
Also can you look at the I need help understanding message I left here (above)
viewtopic.php?p=85587#p85587
Posted: Mon Oct 27, 2025 3:19 am
by jerrykco
It's been a while for my updates. But I have been working on the VW on two fronts.
First, I am continuing to strip the Transporter of any attachments albeit slowly. I now have the three doors off. and next I'll be taking all the windows off. After everything is removed I'll build my purchased rotisserie kit to mount it and getting w metal fabricator to help attach it to the VW frame so its balanced in the center so it wont fall over when we start to rotate it to strip it down to the bare metal by media blasting it.
Second, I have continued to learn about how to get the Stone Display to capture the CAN Bus Messages and update the Display Gauges in real time. Today I got it working. Finally! My friend Dan J. helped me debug the last hurdle to get it working. I will be glad to share the code and help anyone trying to do this with the Stone Display. I'll post a video soon.
Today was a huge step forward.
Posted: Sun Dec 21, 2025 7:36 pm
by jerrykco
'm in the final stages of getting ready to have it stripped. I have the rotisserie ready to install. Been waiting on welder to come over and help plan the attachments to the frame. Everything is off the body now (windows, suspension, doors etc.) except the master cylinder & brake lines and the last few feet of the wire harness that goes through the frame on the right side in up and over the rear suspension mount in the frame. It won't pull out. I may just cut it at the entry and exit in that section of the frame.
When the welder comes the first time we will plan a cut and attachment plan. I'll be doing the cutting and drilling of all the steel. Then he will come back and weld the pieces.
I
Posted: Sun Dec 21, 2025 7:39 pm
by jerrykco
I'm in the final stages of getting ready to have it stripped. I have the rotisserie ready to install. Been waiting on welder to come over and help plan the attachments to the frame. Everything is off the body now (windows, suspension, doors etc.) except the master cylinder & brake lines and the last few feet of the wire harness that goes through the frame on the right side in up and over the rear suspension mount in the frame. It won't pull out. I may just cut it at the entry and exit in that section of the frame.
