Page 2 of 7
Re: Unlocking the power/torque of Prius gen 3 drive train?
Posted: Wed Nov 19, 2025 8:53 am
by Ghia66
Sorry Tom.
Went yesterday to the shed for a test run but the laptop decided that it wasn’t going to open until Windows 11 installed, so no joy!
Posted: Thu Nov 20, 2025 4:58 pm
by Ghia66
So here is the log and Parameters.
Would love to be able to add some regen to assist the brakes!
Posted: Thu Nov 20, 2025 5:16 pm
So your revlim is set to 8000, so yea bump that up for more motor speed.
Off pedal regen can ofcourse be added. try -15 for regenmax
https://openinverter.org/wiki/Zombiever ... pot_Values
Also not too sure why your potnom is so low.
Wait you are driving it with dirmode -1, so reverse selected
Does not affect too much, but you can bump available throttle with "throtmaxRev": 30 -> change this 100 and hold on tight.
If this works then we can add the ability to reverse "forward" for the prius gen3.
Posted: Thu Nov 20, 2025 5:35 pm
by Ghia66
Thanks again Tom, this is going to be exciting!
Yes, reverse is the new way forward…
Will try these new settings in a few days (am on grandchildren minding duties).
I cannot wait!
Posted: Sat Nov 22, 2025 1:28 pm
by Ghia66
I went out with my grandson (handling the logging) and we had a very good drive!
Accelerator is much more receptive.
Regen is brilliant!
Didn’t get above 104kph
Posted: Sat Nov 22, 2025 1:34 pm
Your 8000 revlim seems to still be present. Is that param increased correctly?
Small note on log, we need idc andnot INVudc
Posted: Sat Nov 22, 2025 2:19 pm
by Ghia66
Thanks Tom, revlim set to 13,000
Sorry was in a rush and didn’t have all of my notes with me!
Posted: Sat Nov 22, 2025 2:24 pm
Look from the data we indeed have reached some sort of Toyota internal Rev limit.
Potnom (throttle) flat and speed stays flat
Posted: Sat Nov 22, 2025 3:14 pm
by marcexec
Not suggesting to test it on the road, but could the "internal" limit only apply for reverse for some reason?
Probaly even too dangerous with wheels off the ground, though I probably hit 150+ with the motorbike wheel at Dublin Maker when some cheeky kid took it out of reverse
Posted: Sat Nov 22, 2025 4:36 pm
by Ghia66
tom91 wrote: ↑Sat Nov 22, 2025 2:24 pm
Is it similar situation to The Greg Rabbit?
Is there any hope of the Lexus 300 secret sauce knowledge helping?
Posted: Sat Nov 22, 2025 4:47 pm
I will review the prius info some more to figure out where we can make changes.
Posted: Sat Nov 22, 2025 6:21 pm
by Ghia66
Brilliant, thanks Tom.
I will charge up the battery pack and do some more runs with logs.
Anything that I can do to help?
Posted: Sun Nov 23, 2025 11:31 am
by Ghia66
Ghia66 wrote: ↑Sat Mar 08, 2025 3:09 pm
Just had to chance my arm with a revlim 13000 run before the teardown!
Just remembered hitting 13,000 rpm unloaded on the bench.
Probably in forward though!
Might be hope for Greg’s Rabbit
Posted: Sat Nov 29, 2025 6:12 pm
by Ghia66
Here are the parameters from the last drive
Battery pack is fully charged
Any changes required before next test drive?
Posted: Tue Dec 02, 2025 7:55 pm
by Ghia66
Drove the Ghia 18kms from the shed to home in light traffic
and still have 378volts… what fun
Enjoying the regen but noticed that I need to be wary of
snapping quickly off the accelerator as the back of the car wants to
step out of line with rapid deceleration!
Posted: Tue Dec 09, 2025 11:59 am
by Ghia66
Nice drive to the last Carz and Coffee for the year in Bray.
Here is the log
Posted: Thu Dec 11, 2025 7:56 pm
by Ghia66
Is there anything that can be done (I can do) to get the
Prius to be less juddery when going from reverse to drive and regen brake to drive?
Posted: Mon Dec 15, 2025 7:32 pm
The logs are not fine enough to see any judder as far as I can see.
Your regen ramp is already at 1. Wait you are on release 2.15A. Please go the latest release first
https://github.com/damienmaguire/Stm32- ... /tag/2.30a
Alot of throttle smoothing updates have happened.
Posted: Tue Dec 16, 2025 12:50 pm
by Ghia66
Thanks Tom
Posted: Wed Dec 24, 2025 7:29 pm
by Ghia66
Just updated to 2.30A and then uploaded my saved parameters.
Had to then change from ISA shunt to BMW safety.
I noticed that drive is now reverse and reverse is now drive on my gear stick.
Unfortunately the car now doesn’t move… what have I missed?
Posted: Mon Dec 29, 2025 12:40 pm
With a direction selected to you see the potnom param increase when plotting it?
Posted: Mon Dec 29, 2025 12:41 pm
You logs indicate that selection a direction generates a torque request. This is strange, did you fully power cycle (12V removed from everything) after the update?
Posted: Mon Dec 29, 2025 2:32 pm
by Ghia66
tom91 wrote: ↑Mon Dec 29, 2025 12:41 pm
Yes, I removed 12volt and then restarted.
I thought it strange!
Posted: Mon Dec 29, 2025 3:46 pm
Ghia66 wrote: ↑Mon Dec 29, 2025 2:32 pm
So even after a 12V power cycle it does not work.
Can you please try a release that is older? like V2.22A or 2.20A It is possible a change I made for the testing Greg was doing in his VW Rabbit causes issues for your setup.
Posted: Mon Dec 29, 2025 4:38 pm
by Ghia66
tom91 wrote: ↑Mon Dec 29, 2025 3:46 pm
Thanks Tom, will do. I’ll contact Greg and check what release he is using.
The only odd thing I noticed was that drive is now reverse and reverse is now drive on my gear stick.
