Finally some progress. Here are screenshots from osciloscope and new dump from pulseview. It seems I was having loads of signal glitches before. Crappy connections. Although used an option for 1us glitch filter this time. Picture 5 and 6 shows red and green wires. Capture files taken separately obviously. I didn't want to damage capture device. Will do more capturing tomorrow and acquire second probe for the scope. Also important thing - engine was off, so hv battery voltage readings should be kinda stable.
https://drive.google.com/file/d/1GC9-Vn ... sp=sharing
Given bit time asymmetry it seems i'd have to butcher battery ecu and tap between transceiver and the actual IC. Otherwise there's no way to to read this crap. Unless someone figures out which transceiver should be connected for sniffing.
Attached images are green wire first, then red. Red wire is lower voltage.
After powering up this little wireshare transceiver, no signal on any UART side pins. Perhaps it needs a wake up call from another device on UART side.
Funny thing is, After hooking up RS485 side to the car, both signals are shorted to ground (No matter polarity. Switched A and B and same result). If i unplug a single wire, either red or blue, then signal voltage range goes back to normal. There's still 200mv signal between red/green that i have captured. I guess that's enough for car to work since it did so. I have captured them without transcevier connected so +1,8/-1,8 v range.
below is my full folder. "differential 1 24mhz" and "differential 2 24mhz" files are captures with swapped GND/D0.
https://drive.google.com/file/d/1XbyO9z ... sp=sharing
NOW THE MAD PART!!!
- "differential 1 24mhz" 9600baud rate and invert RX gives frame errors... BUT "differential 2 24mhz" at 9600 baud works perfectly, as in not a single frame error across a hundred packets... BUT bit timing is off, like "50/50 kinda random" off. Like literally some bits are less than half of this baud rate. BUT I have compared 3 packets and they have the same amount of data AND a lot of values are the same for all of those 3 packets.
Why i think its mad? Because i have established that the baud rate must be 38400 or 28800 based on previous captures.
Edit: Scratch that boys. We're going places! You know the saying about placing an infinite number of monkeys and infinite number of typewriters in a room? Amazing things are bound to happen. 19200 baudrate with an odd parity bit fits like a glove! Turns out an oscilloscope was unnecessary after all. But I do not regret buying it all. Will be useful when shit hits the (Taiwanese) fan.
Edit: Added a screenshot of different decodings. Perhaps someone notices something at first glance.
Edit: Made proper data gathering. Samples + dr prius screenshots. If this doesn't work, then the next step is to mess physically with temp and voltage sensors to get boundary values. I don't really have a place for this
https://drive.google.com/file/d/1mwW_1t ... sp=sharing
Edit: Another idea - Someone could inject this data stream on a loop to the Hybrid Vehicle Control ECU while having obd dongle with dr. prius running on a phone. Would this show my battery parameters in the app? Or straight away look for CAN PIDs that dr. prius uses to gather data. Buy rs485 dongle for arduino and send data on loop through bth. Listen on can pins of HVC ECU. Although it seems kinda pointless when you don't know which bytes to change to change data.
Edit:
https://rs485.com/rs485spec.html This website rules out RS422 by its minimum of 2V signal level. But I don't think it changes anything. I had a talk with an IT guy who encouraged me to make my own UART/rs385 relay with arduino since, as he told, even a monkey could do it with the help of cyber monkey called ChatGPT, before paying someone to write the code for me.
#include <Arduino.h>
const byte data[] = {
0x28, 0xD7, 0xFF, 0x6B, 0x6C, 0x00, 0x68, 0x00, 0xFF, 0x00,
0x6C, 0x6E, 0x48, 0x00, 0x25, 0x7E, 0x29, 0xD6, 0xFF, 0x69,
0x6B, 0x5D, 0x6A, 0x00, 0xFF, 0x6A, 0x6B, 0x00, 0x68, 0xBF,
0x66, 0xF4, 0x2A, 0xD5, 0xFF, 0x6C, 0x69, 0x9A, 0x6A, 0x00,
0xFF, 0x6B, 0x6A, 0xA1, 0x6A, 0x9C, 0xA7, 0xF2, 0x2B, 0xD4,
0xFF, 0x6B, 0x6A, 0x8A, 0x6A, 0x00, 0xFF, 0x00, 0x6C, 0x00,
0x48, 0x00, 0x25, 0x9A
const int RSE_PIN = 10;
const unsigned long FRAME_DELAY_US = 1019; // 573 (frame) + 446 (desired delay)
const unsigned long LOOP_DELAY_MS = 9;
void setup() {
pinMode(RSE_PIN, OUTPUT);
digitalWrite(RSE_PIN, HIGH); // Always in transmit mode
Serial1.begin(19200, SERIAL_8O1); // 8 data bits, Odd parity, 1 stop bit
void loop() {
for (byte b : data) {
unsigned long t_start = micros();
Serial1.write(b);
// Wait until full frame duration (573 us) + 446 us inter-frame gap
while (micros() - t_start < FRAME_DELAY_US) {
// Busy wait to ensure spacing
delay(LOOP_DELAY_MS); // Wait before repeating the whole transmission
This code seems to work although timing between bytes varies way more than car's does. Loop delay is even worse as it can be timed only to milliseconds. When trying microseconds, DUE simply ignores loop delay. Voltages of my WaveShare SP3485 dont match car's too. Hope i won't fry anything.
Edit: now look at that. A screenshot from 15.05 data packet sent by Arduino. Sure I still got plenty of DTC errors on the dashboard but most values are legit spoofed. Charging amps sometimes changed for a second to 6.30amps, and voltage did flip sometimes too. I guess byte/bit timing again is to blame. But then other packets give rock solid values even when the engine is running.
Changing any byte makes most values go default. Apart from max chrg and max dchrg, soc, 12v bat. Have to find a checksum to progress.
Picture with 8.6v12 bat corresponds to 12.52 picture. Car even goes into ready with "check hybrid system" message. Engine running. All values stables and nothing changes. Although I'm afraid of damaging my car. Engine sounded odd. Perhaps something to do with real HV voltage being off from truth.
Edit: When exported to 8 column by 12 rows grid, data gives a lot of hints. It is useless for now until checksum is figured out.
Edit: Tried this data set.
38
217
255
105
107
255
105
0
255
107
108
0
104
255
103
215
39
216
255
107
108
87
106
0
255
107
108
213
106
255
232
138
40
215
255
107
108
0
104
0
255
0
108
110
72
0
37
126
41
214
255
105
107
93
106
0
255
106
107
0
104
191
102
244
42
213
255
108
105
154
106
0
255
107
106
161
106
156
167
242
43
212
255
107
106
138
106
0
255
0
108
0
72
0
37
154
11813 byte sum
95+96
lsb+lsb
37+154
value = (MSB * 256) + LSB
= (0x9A * 256) + 0x25
= (154 * 256) + 37
= 39424 + 37
= 39461
way off.
Now I am going to take a break from all of this. My brain is fried. But if you need aa single absurdly big data sniffing log, let me know so i can help.
Resuming the struggle (decimal):
byte 1: counter. rolling over 32, 38, 44, 50, 56
byte 6: always 255
byte 8: always 0
byte 12: always 0
byte 22: always 87
byte 28: always 213
byte 30: always 255
byte 38: always 0 (went 88 at 50%SOC)
byte 40: always 0
byte 42: always 0
byte 46: always 0
byte 56: always 0
byte 60: always 0
byte 72: always 0
byte 88: always 0
byte 92: always 0
byte 94: always 0
Last two bytes are not a checksum because there are packets with equal last 2 bytes but unequal sum of other bytes. There are bytes that were same at first 2 captures and went up in third. Bytes 7, 13, 15, 23, 29, 39, 45, 55, 61, 71, 77, 87. This doesn't make sense since none of the values at the screenshots correspond to this upward change.
To be honest values above might not be invariable since I didn't try making huge changes in real time. Will try to make chatgpt write a script for arduino with the rolling byte code and more strict timing of data stream to make DTC errors go away. But it all seems pointless without having battery on a workbench
If any of you have proprietary software that could write graphs from my captured data and would share it privately in exchange for NDA or something, then im up for it.
