Page 2 of 2
Re: Chevrolet Bolt OBC and DC-DC Reverse Engineering
Posted: Sun Jul 06, 2025 10:52 pm
by licwn
Hello All,
I am wondering if this OBC can charge battery from DC ?
Posted: Thu Oct 23, 2025 3:51 pm
by pablo_mtl
Thanks OP for sharing your work!
It looks very similar to the well documented Chevy Volt Gen2 3.6 charger... and its 7.2 brother. (just different aluminum casting and different HV connector).
Posted: Thu Oct 23, 2025 4:16 pm
by pablo_mtl
P.S.Mangelsdorf wrote: ↑Thu Sep 05, 2024 12:53 am
I have begun work on reverse engineering the Chevrolet Bolt onboard charger and DC-DC converter.
In fact, I'm a little confused in the part numbering VS HV connectors... With the Chevy Bolt, how do you know if you have the 7.2kW or the 11kW version?
I found that:
24292668 / 24297322 / 24043892 (alt: 24045953, 24285717, 24286409, 24290152, 24293143, 24294943, 24295620) - seems early 7.2kW - has the same Aptiv AC connector found on the Volt Gen2 3.6 or 7.2 chargers. (like what
Persanity has posted in pictures) Looks like a Volt charger with different casting.
24045955 / 24063740 - has the new AC connector... (like what
P.S.Mangelsdorf has posted in pictures.) Has higher casting fingers on top. Is that 11kW?
Thanks.
Posted: Fri Oct 24, 2025 11:01 am
by P.S.Mangelsdorf
pablo_mtl wrote: ↑Thu Oct 23, 2025 3:51 pm
Yes, I'm fairly certain that it is exactly the same as the Volt Gen2 7kW charger, with the difference is the upper casing. From my understanding, the Volt Gen2 and Bolt were both on GM's BEV2 architecture.
pablo_mtl wrote: ↑Thu Oct 23, 2025 4:16 pm
I'm generally confused by GM's part numbering. It's proved difficult to determine which numbers on the part are actually the part number versus denoting something else. I need to dig through what I have to see if I can figure this out.
