Re: OpenInverter Mainboard in a Siemens Simotion?
Posted: Thu Jun 25, 2020 9:39 pm
Hej,
It has been a while, so sorry for my late reply, but I have made some progress. I have now run the motor in manual mode for the first time, that was a very cool thing to see!
There are still a few things I would like to work on:
- The PWM outputs (inverted logic) are clean when coming out of the main board. However, when connected to the opto-couplers on the driver board, their amplitude decreases drastically (on both ends: the signal does not decrease to 0V and is only slowly reaching 5V, see oscilloscope screenshot attached).
- I don't really understand why there are two opto-couplers per channel, but I think they are part of the low-amplitude problem. If I do understand that circuit, I might be able to make a cleaner PWM signal to the drivers.
- Joromy: Unfortunately, I cannot find the desat fault signal, I have looked for it by forcing a short circuit in an IGBT pair (with a resistor in series with a battery) and trying to observe a change in any of the pins. Joromy: I do not really follow what you describe about your board, I have indeed two opto-couplers per driver channel (so for L1,2,3 Low,High), but I cannot see where the High and Low channels would communicate with each other in some AND gate or so to form the desat output signal? I am suspecting the desat signal might be formed on the control board instead?
- The IGBT on- and off switching times might be a bit long (4 microseconds), and with some irregularity. I have no experience with this, so it is hard to judge whether this is a real problem. The entire voltage difference between on and off is about 18 Volt. At about halfway closing, the driver voltage reaches a 'plateau' where the voltage is constant for a while, before slowly increasing to a fully 'closed' state. All in all, the switching takes about 4 microseconds. Is that particularly slow, or a common switching time? The opening of the IGBT takes about as much time, but occurs in one smooth line. This behaviour is similar in all transistors.
- There is also some 'ringing' in the transistors during closing, which is also observed in the PWM driver signals (see picture attached). Does anyone recognize this behavior?
- It seems that I can read out the current sensors, they come in two pairs, that run in anti-phase, such that their difference is quite a high-amplitude signal and the traces are quite clean. I hope I can reshape that signal to something that the OpenInverter board can read.
Joromy: I do recognize some components on that board, indeed.. However, I think I have much older components on it, like big (red) transformer boxes instead of DCDC converters
. They are both built at around the same time, but I guess my controller has been designed earlier.
- board with connectors
