Page 2 of 3
Re: WIP 1974 Ford Capri + GS450H
Posted: Mon Jul 01, 2024 4:35 pm
by CapriV
PatrcioEV-ATX wrote: Mon Jul 01, 2024 2:12 am Yes, this one is cable driven and I use it move the gear selector. Bonus, when I drop in L, it shifts the transmission into Low. I'm using the B position on the gear selector to power a relay that grounds SL1/2.
Nice! I'll go to pick n pul, see if I can get one.to play around with.
So you can change hi/low as you wish?
I think the zombie can be programmed to change at a certain rpm only. You find the low gear useful?
I see you are selling your car, good luck with the sale.!
Posted: Wed Jul 03, 2024 2:42 pm
by PatrcioEV-ATX
Yes, I change gear at will but it's a "dumb" shift so I don't do it under any real load. Low is helpful to show off really. MUCH more torque in low but only good (in my car) up to about 65 mph. Thanks!
Posted: Wed Jul 03, 2024 5:34 pm
by CapriV
Ha, nice one! What ratio is your rear end?
what gear selector cable did you use with the shifter?
The one from the same car?
Thanks!
Posted: Wed Jul 03, 2024 6:20 pm
by PatrcioEV-ATX
CapriV wrote: Wed Jul 03, 2024 5:34 pm Ha, nice one! What ratio is your rear end?
Thanks!
3.73 rear. I bought one with the cable attached, so OEM. I just had to fashion a small bracket to attach to the transmission to hold the other end of the cable.
Posted: Thu Jul 04, 2024 5:52 am
by CapriV
Mines a 3.73 too.
Driveline is complete, integrated slip thang.. more unforseen buckage though. 🤦‍♂️
This was another easy part. Nothing I haven't done before. . . .
Made a sorta box/shelf to aid with packaging stuff.
The first attempt was to mount the inverter in-between the motor mounts down low, but it was too tight, so it's probs gonna live on the upper floor, might put the DcDc underneath.
Bit more bracing and welding, then some paint.
Posted: Tue Jul 16, 2024 4:23 pm
by CapriV
Hi.
Has anyone ever modified this drawing to the zombieverter pinout?
This is a great drawing, It will be a great help.
Will be straightforward to assign the correct pins on the zombie.
Has anyone had any future issues following this diagram?
Posted: Tue Jul 16, 2024 10:17 pm
by robertwa
It's a good diagram, I've followed it with success on my build. Between that one, and the leaf to zombie diagram & zombie pinout tables on the wiki there is enough to figure it all out
Posted: Wed Jul 17, 2024 12:28 am
by CapriV
robertwa wrote: Tue Jul 16, 2024 10:17 pm It's a good diagram, I've followed it with success on my build. Between that one, and the leaf to zombie diagram & zombie pinout tables on the wiki there is enough to figure it all out
Thanks for the feedback!
I had it printed out using a 3x3' plotter printer at work..
Nice and big so i can see it all. :mrgreen:
All the others printed from the wiki too.
My batteries arrived yesterday.
I ended up.with the A123 batteries from Greentec under the supervision of Thunderstruck EV.
https://www.greentecauto.com/hybrid-bat ... -brand-new
Their bms can connect right to these.
Fingers crossed these will do the job.
Posted: Wed Jul 17, 2024 1:26 am
by CapriV
Found some other info on these batteries
https://www.buya123products.com/goodsdetail.php?i=22
Posted: Fri Sep 13, 2024 3:18 pm
by CapriV
Progress extremely slow unfortunately. The zombie connectivity over wifi is driving me insane.
I get about 20% connectivity. constantly losing connection then connecting for a bit then off again.
I posted about it in the general section, but is there a way to directly hard wire connect to the zombie?
I moved away from the zombie and started concentrating on the battery setup
I'm using the ThunderStruck MCU and so far it been pretty straight forward with the A123 batteries.
I'm now in the process of charging each individual pack up to the recommended voltage and balance using the MCU to control a power supply.
Here's the very first look I had at cell voltages. I was pretty chuffed to get to this point! :D
Posted: Fri Sep 13, 2024 6:31 pm
by chrskly
There are ESP32 modules with Ethernet which can be used. See this thread. That's only useful if you're using a laptop of course. No good for a phone/tablet.
Posted: Fri Sep 13, 2024 6:47 pm
by CapriV
chrskly wrote: Fri Sep 13, 2024 6:31 pm There are ESP32 modules with Ethernet which can be used. See this thread. That's only useful if you're using a laptop of course. No good for a phone/tablet.
Ok I shall have a wee juke at that.. Thanks!
Posted: Sun Sep 15, 2024 11:47 pm
by CapriV
Well. things definitely took a turn for the worse. :cry: :cry: :cry: :cry:
As meticulous as i was being i did something wrong.
Edit- pwm section of the board got fried.
Posted: Sat Oct 12, 2024 4:57 pm
by CapriV
Some progress.
Not sure what happened before, looks like I had a short through the pwm pins.. something happened at the oil pump that I haven't figured out yet.. oil pump doesn't work.
I got the motor to turn though, precharge initiates and it goes to run mode. Still have some gremlins though as it won't precharge if I turn to key off and try to precharge again, I only get 1.8v post prechg resistor instead of the full 60v from power supply.
Started welding up some battery boxes too.
Going to figure out the oil pump issue and get the batteries all connected up and get them charging.
Does anyone have a way to bench test a pump?
Thanks!
Posted: Sat Oct 12, 2024 7:01 pm
by nkiernan
CapriV wrote: Sat Oct 12, 2024 4:57 pm Still have some gremlins though as it won't precharge if I turn to key off and try to precharge again, I only get 1.8v post prechg resistor instead of the full 60v from power supply.
Sounds like something I've had in the past (see link below). Have you connected the HSDN line to the inverter?
viewtopic.php?p=51312&hilit=hsdn#p51312
CapriV wrote: Sat Oct 12, 2024 4:57 pm Going to figure out the oil pump issue
The controller casing is connected to ground yes?
Posted: Sat Oct 12, 2024 7:40 pm
by CapriV
nkiernan wrote: Sat Oct 12, 2024 7:01 pm
Yes, seems to be the same issue, I will go check it...
Just checked and it will precharge and go to run mode every time when in park. So the inverter actually turns off when in park, well the whine switches off... OMG if had of realized this from the outset, I would have avoided chasing my tail for weeks... haha. But this in fact seems wrong too? What if someone is using an external controller and don't have the ability to go into park mode.? When set to neutral it still won't precharge. I guess this is all predetermined when you select the hardware you want to control within the web browser interface. Maybe disconnecting the HSDN would allow precharging in any gear selection.
Thanks for this park selection info.!
Yes the oil pump is grounded as is the controller too.
The donar 450h car came with a second oil pump. I've also fitted that and it won't work either. But it does spin erratically when I connect the pwm wire to the battery negative.
I'm going to buy a pwm generator to see if my zombie has somehow been hurt with a messed up oil pump...
Thanks!!
Posted: Wed Oct 16, 2024 8:13 pm
by CapriV
Pump issue fixed. Both power sources didn't share a common ground, once the battery and power supply negatives were connected it worked as it should, could also explain why I previously fried the zombie. I guess people should just know this stuff. . . LOL
Posted: Mon Apr 21, 2025 6:45 pm
by CapriV
Finally able to get access to the car.
Winter is very long here.
De-iced the car completely.
Worked up my battery boxes a little more with a coolant path, worked on the shifter assembly and mocked up a little more stuff.
Excited to get back at it.
Posted: Thu Apr 24, 2025 9:52 pm
by ggeter
Awesome build! Feel free to read through my posts on my MG Midget GS450h. But looks like you have a great result so far.
viewtopic.php?p=64779#p64779
Posted: Fri Apr 25, 2025 2:53 pm
by CapriV
Thanks!!
My shifter works, but I don't have enough travel to access the momentary selection beyond drive.
Does this just select the other gearing option that's not set as "normal" in the zombie? If configured to do so?
Posted: Fri Jul 04, 2025 6:27 pm
by CapriV
Some progress
Pretty much all the physical items in place, final wire up in progress.
Posted: Sat Jul 05, 2025 6:45 am
Wow, that is a super clean installation!
Posted: Sat Jul 05, 2025 7:48 am
by chrskly
This looks really great. Any pics of how you mounted the gs450? I'm about to get into that part of my project quiet soon.
Posted: Sat Jul 05, 2025 7:50 am
by chrskly
Oh, duhhh, they're right there back up in the thread. Sorry!
Posted: Mon Jul 07, 2025 3:18 pm
by CapriV
johu wrote: Sat Jul 05, 2025 6:45 am Wow, that is a super clean installation!
Thanks!
I like to plan things out in my head when I'm running boring (not drilling) machines at work...
Fingers crossed when I plug it in it will charge, and when I turn the key it will precharge, and when I push the throttle it will move. . .
Don't matter much how tidy it is, if it doesn't work!
Wish me luck!!
