Page 2 of 2
Re: Emergency Stop Wiring
Posted: Sun Sep 10, 2023 2:12 pm
by modellfan
Just do be clear, that I understood you correctly.
- Unbenannt3.PNG (10.44 KiB) Viewed 5966 times
- Unbenannt2.PNG (9.18 KiB) Viewed 5966 times
Wouldn't be it better to have a poll down e.g. 2kohms mounted inside the inverter , so that I externaly just need to interrupt the line?
Further more I am a bit worried, as it is the 5V supply line of the micor , then running in parallel to the HV cables, to get disturbance.
Posted: Mon Sep 11, 2023 3:43 am
You could pull it up internally with 1k or so and pull it down externally for emergency stop
Posted: Mon Oct 09, 2023 10:43 pm
by modellfan
Like shown in the picture? What do you think of cutting the rs232 traces of and connecting the HVIL emergency stop except?
Posted: Sun Oct 22, 2023 5:59 pm
by modellfan
I know chances are quite small , but how can I still protect the motor from a loose cable potentially destroying the sdu ?
Posted: Sun Oct 22, 2023 6:03 pm
by EV_Builder
Which cable? and if the chance is small why do it if the result is acceptable to the relationship of the occurrence?
