Page 2 of 2
Re: 330e Hybrid Transmission
Posted: Mon Dec 05, 2022 7:08 am
by Ev8
It’s possible I’m wrong here because I’m not fully read up on the zombieverter but I was under the impression it could only run Toyota/Lexus motors that were matched with their appropriate motor (gearbox transaxle) as it works but sending or torque commands over a serial connection, the chances of your motor being a match for what the Prius inverter is expecting to drive isn’t good and you can’t change parameters to make it suit, your only option is to run the replacement logic board with foc firmware that you have currently, and I’d let it do the contactor contol, if you are dead set on using the zombie for its other vcu features then link the 2 with can mapping
Hopefully someone with real zombie experience will chime in here
Posted: Mon Dec 05, 2022 7:38 pm
by andrewjenkins34
No worries about the Zombie. I'll just use it for other VCU things.
Main concern now is this HICUROFS1/2 error I'm getting. Measured the resistors in the voltage dividers and they're all good but there's definitely a problem somewhere else and I'm not 100% how to track it down. When I measure voltage going into C57 and C59 I get 0.01v. Voltage into C47 and C46 is 5.7v.
Posted: Mon Dec 05, 2022 10:57 pm
by Ev8
may be worth asking a specific question n the toyota subforum... i dont have any experience with the prius gen3 inverter
Posted: Sat Jan 28, 2023 2:32 pm
by timboness1
Hello Andrew, keenly following this; any update?
Posted: Mon Feb 13, 2023 12:39 am
by andrewjenkins34
No real updates. Had our 4th daughter in October and work has been very busy so haven't had much time for the project.
Still need to diagnose the incorrect voltage at the divider for the current sensors. I did, however, get canbus messages sent to the GCU so I can start mapping them. Once I get RPM, throttle/pedal position mapped I can start initialization so the GCU can control shifting. It uses a closed loop setting so it will continue to learn as i go. I'll also need to send a calculated torque but I'm not sure how. Open to suggestions.
Posted: Tue Feb 21, 2023 11:22 pm
by andrewjenkins34
Well... tested all the resistors in the current sensors. R62, 63, 71, 72, 41, 45, 42, and 46 all measured what they're supposed to. No continuity issues at CONN2 or CONN7, everything doing what it's supposed to.
That's when I decided to take another look at the actual current sensor and I noticed a bulge at the base by the connector. Disassemble and voila, pretty sure I found the reason why this particular Prius was in the junkyard.
Time for another inverter.
Posted: Thu Feb 23, 2023 8:56 am
by timboness1
I assume you can't source that connector board only from somewhere?
Posted: Thu Feb 23, 2023 10:35 am
by andrewjenkins34
It looks like I can get the current sensor by itself but I think I'd rather get another inverter. Just need to find the time to get to the junkyard.
Posted: Sat Feb 25, 2023 8:06 pm
by andrewjenkins34
Trying to figure out how to send CAN messages from OI board to my GCU. I've been trying to learn but it's just not clicking. I'm out of my depth here and hoping someone could help.
The GCU has a built-in sniffer so I can see that it's transmitting information and being received, just not sure how to send it in a way that makes sense.
Posted: Thu Mar 23, 2023 1:01 pm
by andrewjenkins34
Just received the new current sensor and I have a working setup with no errors! Could not be happier.
Went ahead an purchased a CAN shield for my Arduino so now maybe I can teach myself how to read what's being sent and get it mapped appropriately. Once that's done, I can finally move on to initializing the gearbox to get that running on closed loop.
Posted: Thu May 04, 2023 4:00 pm
by andrewjenkins34
Alright, I've been playing with ChatGPT-4 and having a lot of fun. Since I'm not a programmer and don't want to damage anything, I asked the chat for help. As I've stated before, I need to send torque, rpm, pot, pot2, and tmpm to the GCU and I'm having some challenges. The first is that torque isn't a viewable spot value so I asked it how to add torque as a spot value and this is what it came up with:
I apologize for the confusion. After reviewing the OpenInverter documentation, I understand the context better. Let's revise the steps to add the calculated torque as a spot value.
1. First, create a new parameter for torque in `param.h`:
```c
enum PARAM_NUM
torque, // Add this line
PARAM_LAST
2. Next, add a default value for the new parameter in `param.c`:
```c
static const Param::Default DEFAULTS[Param::PARAM_LAST] =
{ Param::torque, 0, 0, 1000, 0 }, // Add this line
3. To calculate the torque, you should edit the `inverter.cpp` file. Locate the `Run()` function, and after the lines where `id` and `iq` currents are computed, calculate the torque using the motor's power equation. The torque equation is as follows:
Torque = 3/2 * Poles * (Id * Ld * Iq + (Ld - Lq) * Iq * Iq)
4. First, we need to retrieve the motor's Ld, Lq, and pole pairs. Add these lines before the torque calculation:
```c
float ld = Param::GetFloat(Param::ld);
float lq = Param::GetFloat(Param::lq);
int pole_pairs = Param::GetInt(Param::polepairs);
5. Next, calculate the torque and store it in the `torque` parameter:
```c
float torque = 1.5f * pole_pairs * (id * ld * iq + (ld - lq) * iq * iq);
Param::SetFloat(Param::torque, torque); // Set the calculated torque as a spot value
Now, the calculated torque will be available as a spot value and can be accessed using the `torque` parameter.
If anyone wants to review and make suggestions, it would be greatly appreciated. Or suggest a way to test without causing permanent damage...
Posted: Thu May 04, 2023 4:17 pm
by andrewjenkins34
Here's what it came up with in order to transmit over CAN to the GCU:
To transmit the torque, rpm, pot, pot2, and tmpm spot values from the OpenInverter to the HTG GCU, you should follow the CAN communication protocol for both devices.
The OpenInverter's CAN communication documentation suggests that the default CAN base ID is 0x400. For the HTG GCU, the documentation suggests that you should use a custom CAN profile with a 0x600 base ID. You can configure the CAN messages and IDs according to the HTG GCU User Guide, specifically the CAN BUS guide section.
Let's create CAN messages for torque, rpm, pot, pot2, and tmpm with unique IDs by following a pattern:
1. Torque - CAN ID: 0x600, Position: 0, Bits: 16, Gain: 0.1
2. RPM - CAN ID: 0x601, Position: 0, Bits: 16, Gain: 1
3. Pot - CAN ID: 0x602, Position: 0, Bits: 8, Gain: 1
4. Pot2 - CAN ID: 0x603, Position: 0, Bits: 8, Gain: 1
5. Tmpm - CAN ID: 0x604, Position: 0, Bits: 8, Gain: 1
With the above configuration, you can transmit the desired spot values from the OpenInverter to the HTG GCU. Make sure that you configure both devices to use the same CAN bit rate for communication. The OpenInverter wiki suggests that the default bit rate is 500 kbit/s.
Now, to implement this in the OpenInverter software, you should modify the `can.cpp` file to add the custom CAN messages. Locate the `Can::SendAll()` function and add the following lines:
```c
Send(0x600, (uint32_t)(Param::GetFloat(Param::torque) * 10.0f), -1); // Torque, multiply by 10 for a 0.1 gain
Send(0x601, (uint32_t)Param::GetInt(Param::rpm), -1); // RPM
Send(0x602, (uint32_t)Param::GetInt(Param::pot), -1); // Pot
Send(0x603, (uint32_t)Param::GetInt(Param::pot2), -1); // Pot2
Send(0x604, (uint32_t)Param::GetInt(Param::tmpm), -1); // Tmpm
These lines will transmit the torque, rpm, pot, pot2, and tmpm spot values with the configured CAN IDs, positions, bits, and gains. Make sure the HTG GCU is set up to receive these messages according to the custom CAN profile.
Posted: Sat Aug 26, 2023 8:22 pm
by andrewjenkins34
Just wanted to share this because it's fun to watch. No real updates at this point. I'm kind of stuck on a few things.
I can't get any new FOC firmware beyond 5.0 to load successfully but that's ok for now since 5.0 works.
I'm not sure how to add an .ods file to the library so that the motor temp sensor will read correctly.
I'm still struggling to get the Prius and the GCU to talk to each other. I've confirmed the GCU is receiving data, I just can't get it into the right format.
In the meantime, I'm going to work on cleaning up the wiring as well as setting up a coolant reservoir and pump for the inverter.
Anybody in Florida want to come over and offer a hand? I'm open to suggestions.
Posted: Thu Jan 11, 2024 2:04 pm
by 330eBMW
Hi Andrew, great project you have, ill be watching progress thanks for sharing.
Posted: Tue Nov 12, 2024 3:13 pm
by pekoge7244
Hello Andrew, any updates on the project? did you get it up and running, or are you still having difficulties?
Posted: Tue Nov 12, 2024 3:52 pm
by andrewjenkins34
Thanks for reaching out! I have the motor turning under my control with no problem but I'm still having difficulty with the communication between the transmission controller and the inverter. Admitedly, life has gotten in the way of this project and I've not had the opportunity to work on it in quite some time but I certainly haven't given up.
Posted: Wed Nov 13, 2024 1:10 pm
by pekoge7244
how are you controlling the motor? using a Prius inverter or what exactly?.
the GCU gave a bunch of people using non hybrid Zf8hp trans tuning problems for all those who did not buy tuning service from the company.
check this man destroying his after 3 years of time and effort :
TurboLamik for racing application and CAN TCU for a street application have much better success rate with DIYers
and what are you trying to achieve with the communication between the inverter and transmission? can't you just tune the transmission independently and then control the electric motor with the throttle along with a switch to engage and disengage the clutch pack in the electric motor/ Clutch unit?
thanks for sharing details btw you are the only one in the world doing this
Posted: Sun Jul 27, 2025 9:08 am
by antimyx
andrewjenkins34 wrote: Thu Dec 09, 2021 7:02 pm Another challenge down the road is going to be the auxiliary oil pump that is unique to the hybrid transmissions. It gets power and ground from a connection on the case and there is 1 wire going into the pump for communication. Not sure if it's 1-wire CAN but that seems to be the most likely scenario. I found the pad on the mechatronics that has continuity but it is not included in the PCB used for the GCU. Fortunately it's an auxiliary pump and the main pump is chain driven by the electric motor so I should be able to push that problem down the road.
Hello, thank you for the interesting solution. I need your help. I’ve purchased an external oil pump from ZF (the same one as in your post). These pumps are most likely controlled via the LIN protocol. Do you still have any possibility to measure the LIN control signals from this pump? I would really appreciate your help.
I’m building my own hybrid setup based on the Audi Q5 B8 platform (the standard non-hybrid version). I plan to integrate an electric motor in place of the rear driveshaft. However, when driving purely on electric power, my ZF 8HP55 transmission will require proper lubrication. Fortunately, all the mounting points for the external electric oil pump are present on my gearbox. Now I just need this final push — figuring out the activation signals for the pump. 8-)
