Page 2 of 2
Re: STANDARD WINDOWS IDE FOR STM32
Posted: Sun Jul 25, 2021 9:29 am
by zilion
EV_Builder wrote: ↑Sat Jul 24, 2021 7:10 pm
I'm still on windows 7 will it work on that?
Your question is not obvious what you mean.
Python is required in "make deps" which uses python script to download libs.
You have to have python in your system and pointed in your system PATH.
To check if it's visible, run CMD and put "python --version"
Or you can download Johannes libopencm3 manually from his repo and put in place. See .py script in editor.
If you talking about Chocolatey
Know the Requirements:
Windows 7+ / Windows Server 2003+
PowerShell v2+ (minimum is v3 for install from this website due to TLS 1.2 requirement)
.NET Framework 4+ (the installation will attempt to install .NET 4.0 if you do not have it installed)(minimum is 4.5 for install from this website due to TLS 1.2 requirement)
install python 3.9.3 in chocolatey:
"choco install python"
Posted: Wed Jul 28, 2021 9:48 pm
by EV_Builder
Yes indeed! From Johannes is a new tip.
Will try that!
Posted: Sat Jul 31, 2021 7:32 pm
by EV_Builder
Ok i build opencm3 with msys unther windows. Single threaded but atleast it works!
Next step is make it all work in vscode (the stm32_vcu doesn't need python) so i hope the compiler is enough.
Posted: Sun Aug 01, 2021 12:29 am
by EV_Builder
it works i can compile with VSCode...next step debugging...
Posted: Sun Aug 01, 2021 11:01 pm
by EV_Builder
arturk wrote: ↑Mon Jul 12, 2021 10:27 pm
Also to allow debugging additional information has to be included in .elf files. This information is generated by adding additional compiler flag "-d". In my attached Makefile for ZombieVerter project (I had to add .txt) look at lines 33 and 36. This is really the only change I found necessary in the Makefile.
Make a note of SVD file which is very handy for debugging:
Those can be downloaded directly from ST website. I have attached zip for F1 family.
you say "-d" but your makefile has "-g"
i get it to jump directly in the reset_handler and then it stops.. so a breakpoint in main isn't triggered and i doubt if its reached...
Posted: Mon Aug 02, 2021 1:10 am
by arturk
EV_Builder wrote: ↑Sun Aug 01, 2021 11:01 pm
Right, I meant "-g", my bad. Makefile is correct as you may have guessed.
I observed similar behaviour without "-g" switch, adding it fixed problem.
Also, what interface are you using to connect to board? I was using cheapo Chinese ST-Link stick.
Posted: Mon Aug 02, 2021 3:34 pm
by EV_Builder
arturk wrote: ↑Mon Aug 02, 2021 1:10 am
yupsz St Link cheapo with latest firmware in it. mhh i will need to re-check.
Posted: Mon Aug 02, 2021 11:41 pm
by jon volk
Was the bootloader flashed first?
Posted: Tue Aug 03, 2021 1:26 pm
by arturk
jon volk wrote: ↑Mon Aug 02, 2021 11:41 pm
It was in my case.
Posted: Thu Oct 07, 2021 10:00 am
by EV_Builder
arturk wrote: ↑Tue Aug 03, 2021 1:26 pm
It was in my case.
Mhhhhh that might be the issue what i had left then.
I will check soon and report.
I didn't start with code generation yet so that's perfect/lucky.
Posted: Sat Oct 09, 2021 5:50 pm
by EV_Builder
Posted: Thu Jan 20, 2022 1:19 pm
by dkmorb
Hi all,
following the instructions given above, I was able to compile by Visual Studio Code the project for stm32f103 on my windows 10 client.
I would like to understand if the files size is normal (see attached image).
Posted: Fri Jan 21, 2022 10:57 am
My bin is 49k, elf 382k
Posted: Fri Jan 21, 2022 12:44 pm
by dkmorb
I'm completely wrong
Sorry guys, i would like to know where i can find the source code for stm32f103 ... Is it still in
https://github.com/jsphuebner/stm32-sin ... epill-test repo?
Thanks!
Posted: Sat Jan 22, 2022 10:12 am
by dkmorb
Fantastic, I'm able to build stm32-sine firmware using msys2 and mingw toolkit.
Now i've to check if it works on bluepill
