Page 2 of 2
Re: Tesla SDU forward direction
Posted: Tue Aug 29, 2023 7:19 am
by mane2
Thanks for confirming.
Switching pins would still mean that motor runs reverse internally and hill hold etc won’t work
Posted: Tue Aug 29, 2023 10:30 am
Yeah hill hold still needs debugging in that case, same problem in Audi.
Posted: Thu May 23, 2024 11:38 pm
by alexbeatle
Another small note. Setting the dirmode to "SwitchReversed" also inverts the seldir.
Example: if din_forward = on, seldir shows Reversed. The motor spins forward correctly.
I was trying to use the seldir as the signal for the dashboard display, but need to invert it, I guess. rotordit only updates after actually spinning the motor, so cannot use that.
Posted: Thu Sep 26, 2024 5:22 pm
by Romale
EV_Builder wrote: ↑Wed Mar 31, 2021 7:18 pm
I advice people to switch internally the motor phases (in the software configuration), not the wiring of the inputs or the software logic etc.
Forward needs to be forward en reverse needs tobe reverse...
Hi!
what phases have you changed programmatically? 1 - 3 , 1 - 2 or 2 - 3 ?
Posted: Tue Aug 26, 2025 1:18 am
by gwguidi
Peter wrote: ↑Thu Mar 25, 2021 10:11 am
As I am about to install my SDU which will be running in reverse based on the normal Tesla layout should I be concerned ?? I have removed the mechanical oil pump and added an external electric oil pump so thats not the issue.
Peter,
What did you use for a pump? Is there a thread on this mod? Thanks
