Page 2 of 2
Re: BMW E61 2006 LDU-sport Model 3 battery
Posted: Mon Jan 11, 2021 9:15 pm
by Ruudi S
Excellent work! What will you fit to the engine bay? Will there be a front trunk? Do you know other swedish builder who was building tesla vito?
Posted: Tue Jan 12, 2021 8:32 am
by fredd90
Ruudi S wrote: βMon Jan 11, 2021 9:15 pm
Thank you
In the engine bay there will be: 12v attery, 3x circ-pump, ac unit, compressor to airsuspension, hydraulic motor to steering and some vent-ducts.
I want to use bmw f1x EPS(electric power Steering) But I don't know if I can solve it, so at first i should use 12v power Steering pump from minicooper and original steering rack
I've seen that build, really nice
Posted: Sun Jan 31, 2021 12:07 am
by fredd90
Now its time for a small update.
Front subframe is now firmly mounted to the chassie and battery,
My plan is to use the two standard hvdc connectors on the tesla m3 battery(650Ax2), unfortunally there was aluminium cable,
So off to the dealer and got aluminium to copper pressconnectors. 2 tesla m3 connectors paralell to LDU
Finally ive got all the bearing and sealings, from my local SKF agent, in the weekend there will be time to put together the engine/gearbox.
Also got new brake calipers, still waiting for new front disks, old e61 is a bit small
Everything going acording to plan exept the rear shock absorbers, i have planned to use these from "Air lift performance":
Unfortunaly the were not capable to handle the weight.... and the larger damper will be hard to fit....they are 7inch/17cm wide,
My plan was to use original level control, not a big fan of coilovers due to the extreme stiffness.
Things that are on the agenda: sketch cooling systems, pull pipes for cooling and brakes, assemble the engine.
// Thanks for now
Posted: Sun Jan 31, 2021 2:20 pm
by sheselectric
fredd90 wrote: βTue Jan 12, 2021 8:32 am
Thank you
Hi Fredd,
Excellent build, impressive work
. Did you get the mini cooper power steering pump fitted? I'm considering this for my E60 build. I'm curious about the wiring, does it require the mini pump control module?
I've been planning to use an Opel Zafira power steering pump but they can be loud so wondering if the Mini pump will be quieter.
Posted: Tue Feb 02, 2021 1:26 pm
by fredd90
sheselectric wrote: βSun Jan 31, 2021 2:20 pm
Thank you
Hi Fredd,
Thank you =)
I have not fitted it yet, maybe 1-2month away... I am planning to use the original e61 steering rack(for now)
But it has gone 29k so it's maybe worn out, if there is any internal leak the hydraulic pump won't stop.
So to get power efficiency I maybe need to replace or overhaul the rack.
I bought my pump unit newly refurbished from Poland,
https://www.ebay.com/itm/ELECTRIC-POWER ... 2749.l2649
Their instructions :
GROUND (-) - a 5,5mm wire with a BLACK tip end of 8mm
POWER (+) - a 5,5mm wire with a RED tip end of 8mm
POWER (ignition on) (+) - a 1,5mm wire with a BLACK tip end of 6mm (to ignition)
POWER (auxiliary) (pump active)(+) - a 1,5mm wire with a GREEN tip end of 6mm (to button)
/Best regards Fredrik
Posted: Tue Feb 02, 2021 8:08 pm
by Bratitude
If your not a fan of the classic βcoiloversβ why not just get some coilover shocks from fox,king, or foa? You just pick your spring rates, valving and stroke!
Posted: Wed Feb 03, 2021 5:01 pm
by fredd90
Bratitude wrote: βTue Feb 02, 2021 8:08 pm
It is actually a good idea that I may be considering choosing, Today I have talked to an e-supplier of coilovers where you can choose properties completely as needed. D2 coilover,
They will get i touch tomorrow about the price/setup.
Have left some info: Valves, cornerweight, stroke ,angle of struts and a little what I should have the car for.
Perhaps a smoother solution for suspension, instead of reinventing the wheel
Posted: Thu May 06, 2021 11:46 am
by jon volk
Holy crap. That is by far the worst inverter damage Iβve seen on an LDU.
Posted: Thu May 06, 2021 6:46 pm
by paaa
Don't know how I missed this project. This is outstanding work! It is what I hoped to do with my Subaru but thought removing the floor pan might be a bit much for my first conversion. Following with great interest.
Posted: Fri May 07, 2021 6:09 am
by Boxster EV
This project is phenomenal. Given me loads of ideas for the next build.
Posted: Sun Feb 18, 2024 7:46 am
by Evkiwi
Are you still working on this Frederick? I see your still active on the forum.
It's an amazing project to follow by the way,
Posted: Sun Feb 18, 2024 12:01 pm
by barracuda816
Sounds like a great build. Not sure if its just me but I can't see any pictures though.
Posted: Sun Feb 18, 2024 12:07 pm
by crasbe
barracuda816 wrote: βSun Feb 18, 2024 12:01 pm
Well that's the reason why it's not a good idea to use external image hosters. At somepoint all of them delete images and then the forums are just plastered with dead links
