Page 2 of 2
Re: Inverter Firmware v4.94.R
Posted: Mon Nov 02, 2020 1:38 pm
by ZooKeeper
bexander wrote: Mon Nov 02, 2020 8:42 am R21 should be 1k2, not 1k1.
How is your temp sensor connected? Should be connected from either pin 13 or 14 and then to GND.
You should be able to read normal room temperature when motor is at room temperature. 100 degree at room temperature means something is not correct.
Thanks, yes wired exactly like you describe. From my Toyota MG2 temp chart, it appears the resistance is off by hundreds of ohms. Since I could not get close with the sensor plugged in, I substituted known resistances across the sensor terminals and compared to the chart (attached).
I will make R21 1k2 and retest.
Posted: Mon Nov 02, 2020 5:23 pm
by bexander
BTW, are you shure that the temp reading is 101 degrees, not -101degrees?
Setting R21 to 1k1 should result in a large negative value if my math is correct.
Posted: Mon Nov 02, 2020 8:27 pm
by ZooKeeper
bexander wrote: Mon Nov 02, 2020 5:23 pm BTW, are you shure that the temp reading is 101 degrees, not -101degrees?
It's -450 with the sensor plugged into the MGR, but much closer to expected with a 14k7, 4k7 and 2k2 resistor respectively.
Posted: Tue Nov 03, 2020 4:05 pm
by bexander
-450 seem resonable. Change R21 to 1k2 and you should be good.
Posted: Tue Nov 03, 2020 11:18 pm
by ZooKeeper
Much better, maybe some tweaking with sensor ground resistance ;)
4k7 = 75*C (low by 15*)
2k2 = 108*C (nearly dead-on :) )
1k0 = 145*C (high by 15*)
470 = 183*C (high by 17*)
047 = 200*C+ (saturated)
010 = 200*C++ (saturated)
Posted: Wed Nov 04, 2020 5:47 pm
by bexander
This is getting far of topic so I will answer in this thread instead.
viewtopic.php?f=14&t=1087
Posted: Mon Nov 09, 2020 6:16 pm
by EV_Builder
Tesla SMALL Drive unit.
In manual mode the il1 and il2 values are broken.
(atleast) didn't start the inverter, went back to 4.90.R-sine
Now i got 0.65Amps and -1.31Amp in manual mode.
Posted: Thu Nov 12, 2020 8:51 pm
Here is version 4.95.R, it did the offset calibration ok on my test board. If some people test it as good I will release.
Posted: Fri Nov 13, 2020 3:09 pm
by ZooKeeper
Am I reading that right, "stm32_sine"??
Posted: Fri Nov 13, 2020 10:44 pm
yes, that had the major bug in it
