Page 9 of 9
Re: MQB Chargers
Posted: Sat Feb 15, 2025 8:44 pm
by uhi22
Just to avoid confusion: part number 1EA ... ... is MEB, not MQB.
Re: MQB Chargers
Posted: Sat May 10, 2025 10:56 am
by m.art.y
Anybody had success making those chargers work? I'm particularly interested in 22kw versions or at least 11kw ones. Why do the 22 kwh versions have a second connector for what looks to be 3 phase charging?
Re: MEB Chargers
Posted: Sat May 10, 2025 8:20 pm
by m.art.y
modellfan wrote: Wed Oct 23, 2024 7:46 am I won't say how I found out. VW id.3 Chargers and the other chargers discussed here don't have the same AC plug. The id.3 and propably also id.4 / enyaq have small deviders bentween the horizontal pins. The others don't. CCS HARNESS NOT COMPATIBLE!
Did you try getting the pictured charger working? How did it go?
Re: MQB Chargers
Posted: Mon May 19, 2025 5:17 am
by RetroZero
The charge flap error has really been getting to me. I ordered a Porsche ref - 7P5915651 and openned it up. It is identicle to the charge flap actuator on the GTE looms, however it has a 4 pin connector, so cutting out the original actuator on GTE loom, & fitting a plug, the actuator can be replaced. Only modification is that the white "locking" arm must be swapped as they have different lengths. Inside resistances are identicle.
However, I still have the stupid actator fault present, and yes I can just code it out.
I can make it lock via VCDS, but it doesn't return the lock signal, so stays blocked. I have tried to put a spacer, as there is mention of a load return signal (from one of Damiens previous posts), but no luck yet.
