Page 1 of 4
Re: Leaf spline coupler
Posted: Fri May 08, 2020 4:46 pm
by celeron55
The ghetto Leaf coupler is a Blue Print ADC43101 clutch disc or similar. It fits a bunch of japanese and korean vehicles and is cheap.
It's a loose match and probably different spline profile, but I've been running it for almost 30 000 km in my minivan so far just fine. There is enough meat in the splines. I assume the quite soft motor shaft will adjust to the very hard clutch profile over time.
If anything, at least it's taking a whole lot of time for anyone to be able to tell me "I told you so". 8)
Posted: Sun May 10, 2020 3:01 am
by Bratitude
jerrykco wrote: Wed May 06, 2020 11:35 pm
Bratitude wrote: Wed Mar 25, 2020 4:06 am Coupler and assembly design is now finished.
in a few days I’ll be sending out an order for 10 couplers, hopefully.
As I’m sure for many others here, life is a bit chaotic at the moment. So things are taking longer than usual.
Hey, Bratitude,
Can you publish the finished design pictures?
I need to connect the leaf to a drive shaft.
I'm interested seeing if your design will work for me.
Currently away, but couplers are on order.
Ill try to dig out the specs. Spent a good amount of time setting the coupler up to be fairly universal for most people’s needs
What I currently access to.
was ether a 3in or 2.75 di plate with centring marks that match the rotex gs38 bolt pattern.
couple will nest in an angler bearing, with renting clip. For those wishing to run a clutch or drive shaft.
Posted: Sun May 10, 2020 8:11 am
celeron55 wrote: Fri May 08, 2020 4:46 pm The ghetto Leaf coupler is a Blue Print ADC43101 clutch disc or similar. It fits a bunch of japanese and korean vehicles and is cheap.
I smashed two blueprint Mazda center pieces couple of years back. It is not very hard too.
If I may suggest you put two center pieces in line and weld them in your coupler. That way it will definitely hold.
Torque is transfered along the shaft length...
Posted: Sun May 10, 2020 8:38 am
by Kevin Sharpe
Damien is using a Fiat Van clutch disc (watch from 2:35) :)
Posted: Sun May 10, 2020 1:02 pm
by jerrykco
Kevin Sharpe wrote: Sun May 10, 2020 8:38 am
Is this the clutch plate?
Clutch Plate Fiat Ducato 2500 Turbo Diesel MK1 85-93 Clutch Disk?
Posted: Sun May 10, 2020 5:35 pm
by doobedoobedo
jerrykco wrote: Sun May 10, 2020 1:02 pm
He mentions it being a Fiat Multipla.
Posted: Sun May 10, 2020 5:49 pm
by jerrykco
Thanks, I couldn't catch that. I listened several times too.
Posted: Sun May 10, 2020 6:09 pm
by zippy500
Think the Suzuki one fits too,
Think thats what this guy did
Posted: Sun May 10, 2020 7:32 pm
by Kevin Sharpe
jerrykco wrote: Sun May 10, 2020 5:49 pm Thanks, I couldn't catch that. I listened several times too.
Yeah, its the Fiat Multipla :)
https://en.wikipedia.org/wiki/Fiat_Multipla
Posted: Sun May 10, 2020 7:41 pm
by Kevin Sharpe
zippy500 wrote: Sun May 10, 2020 6:09 pm Think the Suzuki one fits too
Many thanks :)
Posted: Mon May 11, 2020 9:29 pm
by Cookie6000
Here is how the 1.6l Fiat Multipla centre spline fits the Leaf output shaft
Posted: Tue May 12, 2020 12:37 pm
While I don't have many miles on my Fiat clutch Leaf coupler I do have some experience with these things:)
My opinion is that having a perfect coupler would be perfect having one that works ...well, works. I have seen the most ridiculous couplers last for ages and those machined down to microns come flying out the side of a bellhousing. I've even done both myself. Don't let the pursuit of perfect keep you from getting on with a build.
Posted: Tue May 12, 2020 12:50 pm
Jack Bauer wrote: Tue May 12, 2020 12:37 pm While I don't have many miles on my Fiat clutch Leaf coupler I do have some experience with these things:)
I think the same. On my Mazda original clutch is rattling like old kettle. So finally i put two clutch center pieces in my coupler. Now i have peace of mind... It still rattles though.
Posted: Tue May 12, 2020 12:57 pm
by Kevin Sharpe
Jack Bauer wrote: Tue May 12, 2020 12:37 pm Don't let the pursuit of perfect keep you from getting on with a build.
This is a really important point :)
Posted: Fri May 22, 2020 12:40 pm
by KarmannLeafBlower
Bratitude wrote: Sun May 10, 2020 3:01 am
Hey, Bratitude,
You have another customer here in the UK! Need your solution to link to a Karmann Ghia gearbox....
Posted: Sat Jun 06, 2020 5:10 pm
by Bratitude
Some time later :)
fits like clockwork
Posted: Sat Jun 06, 2020 5:52 pm
by mdrobnak
Bratitude wrote: Sat Jun 06, 2020 5:10 pm Some time later :)
fits like clockwork
Wait. Are you putting a flywheel and clutch on this? If so...hmmmmmmm...How can I get one of these in the US?
Posted: Sun Jun 07, 2020 12:52 am
by mleebert
Looks great!
I'd love to purchase one of these from you. I have a CNC machine so I'm planning on making my own adapter plate and would integrate the same spec'd angular bearing.
Are you in a position to start selling the coupler?
Posted: Sun Jun 07, 2020 1:19 am
by Bratitude
mdrobnak wrote: Sat Jun 06, 2020 5:52 pm
fits like clockwork
designed the coupler to be as universal as possible, so yes with the angular contact bearing you should be able to mount a flywheel.
few more days and I’ll start taking orders
Posted: Sun Jun 07, 2020 1:39 am
by mdrobnak
Bratitude wrote: Sun Jun 07, 2020 1:19 am
fits like clockwork
Sorry, my mechanical knowledge is trash. Does that mean it has a contact bearing in it, or a shop should be able to easily put one in? This solves the concern everyone had about putting too much load on the shaft, correct? Because the bearing is supporting it now?
Do you have any firmer prices, or still $200-300 Canadian? I'm interested in one. The LEAF motor is probably the cheapest option out there with good power...
Thanks for doing this, it's awesome.
-Matt
Posted: Fri Jun 26, 2020 9:26 pm
by wwojciech
Hi everyone. This is my first post. I accidentally came across a clutch from suzuki samurai. What do you think about this? 20x20,1x23,1
Multipla has 20x20,2x23,2
[youtube][/youtube]
Posted: Sat Jun 27, 2020 8:07 am
by zippy500
That and the fiat clutch plate are your only choice unless you can get a custom one make.
Checkout Damien's video on making the coupler
Posted: Sat Jul 18, 2020 3:19 am
by Bratitude
***check first post for update ***
Posted: Sat Jul 18, 2020 6:17 am
by RetroZero
Looking great. Very nice piece of machinery.
Posted: Sat Jul 18, 2020 10:39 am
by mleebert
DM sent :)
