Page 1 of 4
Re: Johannes in a Blue Pill
Posted: Fri Aug 16, 2019 8:19 pm
yaroslav wrote: ↑Fri Aug 16, 2019 7:24 pm
Good evening, is it possible to remove a few more functions from the blue board such as estop, mprot, tmpm a tmpm b ?
Those functions are prevention measures. I dont think it would be good to suppress them.
Hm.... Johannes maybe you could rewrite code for digital temperature sensor like this one.
https://www.maximintegrated.com/en/prod ... 18B20.html
A lot of sensor could be on a single pin.
That would clear at least one pin and then you could merge functions of Mprot and EMGCY stop pins?
Posted: Sat Aug 17, 2019 6:34 am
Yes giving the pins a think-over is certainly indicated. I'd also like to restore the over current reference that is usually produced by Timer 4. The C8 doesn't have TIM4 or maybe its pins are just not present. In that case I could use TIM4 for the task scheduling and TIM2 for the over current reference.
Posted: Sat Aug 17, 2019 8:53 am
johu wrote: ↑Sat Aug 17, 2019 6:34 am
If we use scavenged parts there is Fault output for everything connected with IGBTs. That is a single interrupt for like UVLO, Desat, overtemp and overcurrent protection. In case of DIY inverter we would have to add small IC to controller just to monitor those interrupts and signal through that Fault line. How much additional work is that?
Posted: Sat Aug 17, 2019 9:44 am
So you mean like an AND tree? The output of it could go straight to the BKIN pin as is done on the previous revisions anyway. The additional pins were just connected to the µC to find out what caused the fault. But that is certainly not a must-have.
The programmable over-current limit is useful during testing to take some stress off the power stage. E.g. the Leaf power stage only has desat. Too many desat events (like 100) will ultimately cause the power stage to fail.
Posted: Sat Aug 17, 2019 10:05 am
johu wrote: ↑Sat Aug 17, 2019 9:44 am
Hm... if you use a single digital input you can use the small IC (pic16F?) to sense fault on its pins and then send signal with on byte fault msg which will tell master which error we are dealing with. Then master can decide which level of error it is, shutdown, reset, master alert or caution. This would then correspondingly lit certain LED in the dash scheme.
I agree Desat fault should be HW connected (fast) and this fault logged and counted against repetitive events.
Posted: Wed Aug 21, 2019 4:45 pm
Got myself a blue pill
So the best way to figure out whether running on a blue pill is turning on GPIOC12 (Led port of Olimex and other HW revisions) and then read it back. Since the port does not exist on the C8 it reads back as 0.
I also checked the FLASH_SIZE register and its actually 0x80 = 128k flash
Finally I found out that TIM4 actually runs, it is just not connected to any pins. So theoretically it would be possible to restore the over current reference pins using TIM2 and doing the scheduling with TIM4.
Posted: Wed Aug 21, 2019 5:20 pm
So in order to restore the over current reference pins I'd have to delete ESTOP (quite unimportant) and remap DCSW to PC15.
Damien, what do you think?
Posted: Thu Aug 22, 2019 6:42 am
Well , the only pcb I have done so far for the blue pill is the little gen 2 prius board which i can just hack up my own version to run in a pinch. So i guess it makes sense to bring that feature back if possible.
Posted: Thu Aug 22, 2019 9:20 am
Alright, here is a new pin map and firmware
Posted: Thu Aug 22, 2019 10:16 am
Going to be such a laugh running Model 3 motor with a blue pill:)
Posted: Thu Aug 22, 2019 3:00 pm
Next up: the
36-pin part
Posted: Tue Aug 27, 2019 7:41 pm
by yaroslav
Good evening, I would like to ask if a single-channel encoder will work on it? What is the exciter pin used for?
Posted: Wed Aug 28, 2019 8:04 am
yaroslav wrote: ↑Tue Aug 27, 2019 7:41 pm
Single channel not yet but I think it can be restored.
Exciter pin generates a square wave in resolver mode that is turned into a sine wave by a 3-pole low pass filter and then amplified by an audio amplifier. With that the resolvers primary winding is excited, see wikipedia why this is needed.
Posted: Wed Aug 28, 2019 5:29 pm
by yaroslav
If it is not difficult you can make support for a single-channel encoder.
Posted: Thu Aug 29, 2019 5:15 pm
by JaniK
Is it actually possible to run a tesla motor with the blue pill?
A have a handfull of those here at home.
Posted: Fri Aug 30, 2019 7:43 am
JaniK wrote: ↑Thu Aug 29, 2019 5:15 pm
Yes of course.
Posted: Sat Aug 31, 2019 4:35 pm
by yaroslav
Good evening, I collected on such a Board inverter for the test, but there was a mistake DESAT what are the conditions for its appearance?
Posted: Sun Sep 01, 2019 9:39 pm
by Dilbert
yaroslav wrote: ↑Sat Aug 31, 2019 4:35 pm
Are you getting the desat error flagged every time you try start your dev board? You need to pull the fault line low, I believe the same line is used for a few different faults.
Posted: Sun Sep 01, 2019 9:43 pm
by Dilbert
A number of the Blue Pills for sale on eBay only have the 64k processor, so you won’t be able to save your parameters unless you change the start of the eeprom block.
0x8001fc00 -> 0x800fc00, basically replace the 1 with a zero.
The current firmware is about 38k, so will easily fit inside the smaller memory.
Posted: Mon Sep 02, 2019 4:44 pm
by yaroslav
Dilbert wrote: ↑Sun Sep 01, 2019 9:39 pm
I think I found the cause, you need to pin pb12 to apply logical unit, as in previous schemes was 0, as then to implement the current protection?
Posted: Wed Sep 11, 2019 10:46 am
by Bigpie
I'm having a little play with my newly arrived Blue Pill, I've moved the little jumper across and run ./stm32flash -r ~/open-inverter/tumanako-inverter-fw-bootloader/stm32_loader.hex /dev/tty.wchusbserial1410
Is there any way of checking this has flashed the inverter fw bootloader as expected?
Posted: Wed Sep 11, 2019 11:34 am
by doobedoobedo
if you don't get any errors reported it's almost certainly worked. You could add the -v argument for stm32flash to get it to verify.
Have you tried flashing a simple blink program that just blinks the LED on the board? that would also prove that flashing works.
I've used one of the cheap st-link clones and st-flash which works well and gives a whole heap of useful output when I've played with the blue pill in the past.
Posted: Wed Sep 11, 2019 12:33 pm
by Bigpie
I previously flashed a blink sketch from Arduino IDE using FTDI. I've now flashed both the bootloader and firmware.
~/Downloads/stm32flash/stm32flash -r ~/open-inverter/stm32-sine/stm32_sine.hex /dev/tty.wchusbserial1410
stm32flash 0.5
http://stm32flash.sourceforge.net/
Interface serial_posix: 57600 8E1
Version : 0x22
Option 1 : 0x00
Option 2 : 0x00
Device ID : 0x0410 (STM32F10xxx Medium-density)
- RAM : 20KiB (512b reserved by bootloader)
- Flash : 128KiB (size first sector: 4x1024)
- Option RAM : 16b
- System RAM : 2KiB
Memory read
Read address 0x08020000 (100.00%) Done.
I've moved the jumper back over and reset. The LED still blinks, so I'm not 100% convinced it has flashed over.
Posted: Wed Sep 11, 2019 1:01 pm
by doobedoobedo
According to
http://manpages.ubuntu.com/manpages/bio ... ash.1.html -r reads the flash, doesn't write it. You'd need -w to write it, probably best regenerate stm32_sine.hex as it's a blinky now then.
Posted: Wed Sep 11, 2019 1:29 pm
by Bigpie
Doh, thanks
