Page 8 of 31
Posted: Wed May 13, 2020 1:45 am
by RE3Rotor
Fits perfectly. Thanks Filip. If you don't mind, we should add this to the wiki.
Posted: Wed May 13, 2020 5:05 pm
by Filip
Great to see! You´re welcome ;-)
I don´t mind at all, if I can contribute I'm just happy.
Posted: Wed May 13, 2020 6:37 pm
by Robbertjanzen
I have updated the drawing after some remarks and updates found in the software.
Hope this helps
Posted: Wed May 13, 2020 7:42 pm
by jcwright45
Robbertjanzen wrote: Wed May 13, 2020 6:37 pm I have updated the drawing after some remarks and updates found in the software.
Hope this helps
Amazing, helps to see the whole picture. Thanks again.
Posted: Wed May 13, 2020 8:19 pm
by Kevin Sharpe
Hope this helps
Very cool :)
The HV- contactor would normally use the key switch to ensure it's closed when ever the precharge or HV+contactors are closed.
I would also recommend adding an inertia switch in the 12V supply to the HV- contactor to cut power after a collision.
Posted: Thu May 14, 2020 5:56 am
by arturk
Hope this helps
Attached is pinout for Generator Resolver connector (E81)
GS450H Oil Pump Controller Part No. ?
Posted: Sat May 16, 2020 4:34 pm
by Bassmobile
Anybody help a guy with the part number for this Oil Pump Controller?
Can somebody add this part No. to the Wiki possibly
Posted: Sat May 16, 2020 6:05 pm
by arturk
Here it is
Posted: Sat May 16, 2020 10:12 pm
by xp677
Pretty sure the oil pump controller needs its own thread by now :D.
Posted: Sun May 17, 2020 9:31 am
I for one welcome our new oil pump controller overlords.
Posted: Sun May 17, 2020 11:11 am
GS450H kit build video coming soon.
Posted: Fri May 22, 2020 8:07 pm
Posted: Fri May 22, 2020 9:16 pm
by xp677
Good to know that the JLCPCB rolls of electrical tape come in different colours!
Programming the VCU with Arduino Studio
Posted: Sun May 31, 2020 5:01 am
by Bassmobile
Before I go making videos or writing up How-TO's wanted to make sure that there wasn't already a play-by-play for programming firmware to the VCU over USB with Arduino Studio that I wasn't aware of.
Posted: Sun May 31, 2020 10:24 am
I certainly have'nt made any. Would be much appreciated.
Posted: Sun May 31, 2020 11:20 am
CNC machined HV terminal posts now available:
https://www.evbmw.com/index.php/evbmw-w ... term-posts
Posted: Mon Jun 01, 2020 7:07 am
by RE3Rotor
Jack Bauer wrote: Sun May 31, 2020 11:20 am CNC machined HV terminal posts now available:
Can I use the original connection if I have the wiring+connector? I see they are connected to the same two terminals inside the inverter.
Posted: Mon Jun 01, 2020 8:04 pm
by Bassmobile
Bassmobile wrote: Sun May 31, 2020 5:01 am Before I go making videos or writing up How-TO's wanted to make sure that there wasn't already a play-by-play for programming firmware to the VCU over USB with Arduino Studio that I wasn't aware of.
Jack Bauer wrote: Sun May 31, 2020 10:24 am I certainly have'nt made any. Would be much appreciated.
As soon as I can get it to work on my own unit I will do so.
Currently, I'm struggling to get both wifi & VCU main firmware to compile. Trouble is with external libraries that the code requires to compile. Without a package manifest it's hard to know what other libs need to be made available to the IDE.
Made an issue on GitHub here -> https://github.com/damienmaguire/Lexus- ... r/issues/2
If anyone could jump on and help out with that, would be much appreciated.
I'm keen on Platform IO https://platformio.org/platformio-ide. It's quite a bit more intuitive than the Arduino IDE. Anyone else using it?
Posted: Mon Jun 01, 2020 8:09 pm
by Bassmobile
RE3Rotor wrote: Mon Jun 01, 2020 7:07 am Can I use the original connection if I have the wiring+connector? I see they are connected to the same two terminals inside the inverter.
There should be no issue doing so. So long as the connectors are in good condition, and you can feel confident that they will conduct with no resistance. If it was my project, I would clean the connectors and terminals really well, and use MG 846 high carbon conductive grease on the terminals before connecting them.
Get that grease here: https://www.mgchemicals.com/products/gr ... grease-846
Posted: Tue Jun 02, 2020 3:36 am
by Eflyers
Can you measure the dimensions of the connector blades of the receptacle for the battery power in (the bottom one in your photo)? That would be the thickness of the blade, the width, and the length. You might be able to use calipers to do the measurements, or to estimate the dimensions. I'm working with another inverter that has a similar receptacle for battery power in. The connector blades seem to be undersized for the max current they are reported as carrying. This would be 100-200 amps in my case. The blades on my inverter receptacle appear to be silver plated near their ends.
Also, could you include a photo(s) of the connector area of the plug that you have that goes into this receptacle?
Thank you
Posted: Tue Jun 02, 2020 4:35 am
by celeron55
Aren't those the outputs for an AC compressor and a heater? Definitely not enough for supplying the current needed for driving the actual motors, unless you're limiting your GS450H system to something like 30A...
If you mean using those for their orginal purpose, then of course why not.
Posted: Tue Jun 02, 2020 6:46 am
by RE3Rotor
celeron55 wrote: Tue Jun 02, 2020 4:35 am
One of the connector comes from the traction battery of the GS450h. If you open up the inverter, the connections actually ties to the two posts behind the block-off plate.
Posted: Tue Jun 02, 2020 7:49 am
by celeron55
RE3Rotor wrote: Tue Jun 02, 2020 6:46 am One of the connector comes from the traction battery of the GS450h. If you open up the inverter, the connections actually ties to the two posts behind the block-off plate.
Wait you're right, there's no other connector for the battery. So one is for original battery on the boost lower voltage side, other one is something on the boost higher voltage side?
So as this inverter has a 30kW boost converter, those are going to be rated for about 100 amps by Toyota. So if you take up all the safety margin, it just might be enough to power the entire system...
EDIT: I wouldn't do it though. I think if you're going to use the GS450H stuff, you want to feed it 400 A, at least sometimes. And you don't want your battery connection to sometimes violently burn up and explode.
Posted: Tue Jun 02, 2020 10:07 am
The reason I went out and had those brass terminals made is that to use the full power of the inverter you need to feed HV directly into its main cap thus bypassing the boost converter.
Posted: Tue Jun 02, 2020 2:54 pm
by Eflyers
This is what Mauswerkz, on his now dormant Blog, did with his GS450H inverter: https://cdn.hackaday.io/images/4500861487049316359.jpg
