Nissan Leaf BMS
maiks
Has thanked: 7 times
Re: Nissan Leaf BMS
Post by maiks »
Marat wrote: Fri May 31, 2024 7:20 pm I modified the firmware of the BMS unit of all generations of Liaf, chip 70F3236 70F3382, in order to expand the range of their operation to the required battery parameters, the most popular CATL 115Ah 120Ah 180Ah..., there is an example of standard BMS30 firmware adapted for BMS24 (3NR4C_BLINK-OFF.kwp).
hello ,
Thanks for sharing . Am kindly requesting for 63kw firmware or a link where l can download it
Marat
Been thanked: 12 times
Re: Nissan Leaf BMS
Post by Marat »
You can only purchase a pre-programmed LBC module of all Leaf(Gen1-Gen3), with a pre-agreed battery power, the price is the average price of LBC + $150.
maiks
Re: Nissan Leaf BMS
Post by maiks »
Marat wrote: Mon Feb 17, 2025 7:45 am You can only purchase a pre-programmed LBC module of all Leaf(Gen1-Gen3), with a pre-agreed battery power, the price is the average price of LBC + $150.
I have a 30kW BMS. Would it be possible for me to send it to you for an upgrade to 64kW?
Marat
Re: Nissan Leaf BMS
Post by Marat »
send PM
ginetto
Has thanked: 13 times
Been thanked: 9 times
Re: Nissan Leaf BMS
Post by ginetto »
FYI current sensor pinout for 62kWh nissan leaf BMS is different from that used for 40kWh.
I measured the continuity directly from current sensor harness to the bms harness. Note. in the middle there is another harness entering in the junction box where the current sensor is located.
the result pinout is:
1->10
2->9
3->15
4->11
ginetto
Re: Nissan Leaf BMS
Post by ginetto »
Hi, I'm interested in this firmware, how to proceed? I've a 63kWh catl setup and different BMS . the idea is to run it in ZE1 model.
let me know
regards,
Luigi
