Page 8 of 9
Re: MEB Chargers
Posted: Thu Oct 03, 2024 9:44 am
by jrbe
So what's different from Damien's setup? Different territory / firmware maybe?
RetroZero wrote: ↑Mon Sep 23, 2024 5:32 am
Regarding ID 5EA, I can get the value to toggle, but never keep it happy in REQUEST state. I assume it does some kind of check and that there's other parameters that are required for it to remain in Request State.....
I hope that theres an ID or 2 that is needed to complete Damiens code (as it apparently doesn't work anymore). Then we can move on to polishing up a working solution...
Is this specific id or group something you are sending repeatedly? Might / likely needs consistent request(s) to keep charging / checking other imperative info so it knows it's safe to continue.
Or to think of it a bit differently, If the can bus was cut / damaged the charger would need to stop. It very likely needs repeating messages to keep going.
Re: MEB Chargers
Posted: Thu Oct 03, 2024 11:09 am
by RetroZero
I have been sending it repeatedly at 100ms, 200ms and 500ms, but it seems to need to change value/bit on order to validate Request Status. The id is one listed in the 6A log of Damien.
Re: MEB Chargers
Posted: Thu Oct 03, 2024 11:11 am
by RetroZero
There might be a second parameter that is compared repeatedly. I'll play with the ID list tomorrow and see if I get any further values.
Re: MEB Chargers
Posted: Fri Oct 04, 2024 4:34 pm
by RetroZero
I've added @Mitchy's additional message for central locking to Damiens Code. No change.
Going through the ID list from the 6A log, I tried spoofing each one via SavvyCan and checking values in VCDS - I don't get other values to change, but quite a few times the charger goes into shut down mode (gets blocked) by part of a message.
jrbe wrote: ↑Thu Oct 03, 2024 9:44 am
He is in Ireland, I'm in France - could that make adifference?
Different firmware in relation to the actual charger or Arduino? I suppose it could be a possible blockage, but there must be a way to tackle such an issue no?
This is the advanced Info for my unit. I don't think it's possible to update the firmware....
Friday,04,October,2024,18:30:58:18218
VCDS Version: Release 24.7.0 (x64)
Address C6: Batt. Chrg.
Control Module Part Number: 5QE 915 682 AF
Component and/or Version: OBC KOSTAL H40 4013
Software Coding: 115000003000
Advanced Identification/FAZIT
Serial number: 2302170BK000KB
Identification: KO1-ABY
Revision: --------
Date: 23.02.17
Manufacturer number: 0BK0
Test stand number: 00KB
Flash Status
Programming Attempts(application): 1/1
Programming Attempts(data): 1
Successful Attempts(data): 1
Flash Date: 17.02.23
Flash Tool Code(data): 00021 790 06314
Misc.
Hardware number: 5QE 915 682 AF
Workshop System Name: J1050
Equipment/PR Code: 00000000000000000000000D
Dataset Number: 8V0909811F
Dataset Version: 0022
ASAM Dataset: EV_OBCSinglPhaseKLOMQB12P
ASAM Dataset Revision: 001001
VCDS Info:
Labels: None
ROD: EV_OBCSinglPhaseKLOMQB12P.rod
Re: MEB Chargers
Posted: Fri Oct 04, 2024 8:21 pm
by jrbe
RetroZero wrote: ↑Fri Oct 04, 2024 4:34 pm
The Tesla chargers hacking efforts ran into different can messages in different firmwares. Damien found 3 different ones last I saw. I mention it because there might be a similar issue going on here.
Re: MEB Chargers
Posted: Fri Oct 04, 2024 8:45 pm
by RetroZero
How to make things more interesting..... I'll start by playing back what my charger spits out and compare it to damiens and Doms logs. Going to be lots of time in front of a screen...
Re: MEB Chargers
Posted: Thu Oct 10, 2024 5:33 am
by RetroZero
Tomorrow will be a day of staring at the charger again. Could ID 5EA require the magic byte cracker of @crasbe ? I have my vcds, savvycan with wifican along with an arduino due running Damien's code all waiting. I admit, this is not my area of "expertise" and groogle and yootoob can only go so far, so pointers to wheres I can learn to fish would be great
Re: MEB Chargers
Posted: Sat Oct 12, 2024 6:47 am
by RetroZero
Did some playing about with SavvyCan and VCDS. When I have the Arduino with Damiens sketch connected, the battery SOC is 127%
Could it be that the charger thinks the batttery doesn't need charging, so just sits there? If so, how to change this to a more plausable value using the code?
Re: MEB Chargers
Posted: Fri Oct 18, 2024 11:04 am
by RetroZero
Some hours of SavvyCan and VCDS this morning got me a few more ID's. Hope this helps
IDE_97 - (From damiens code - HCAN from BMS. 10ms - BMS reported current 0xc7f=0A)
From my SavvyCan & VCDS
IDE08719-IDE08720 - Values from battery mngmt-Current condition of battery BYTE_4, Bits 36,37,38 - STANDBY = 80, DC Main Charge = E0,
External Charging = C0, HV mains activ. = 90
IDE08719-MAS07396 - Values from battery mngmt-Act. voltage HV battery BYTES_3 & 4, Bits 24,25,26,27,28,29,30,31,32,33,34,35 (BYTE_3 = 00
& BYTE_4 = 90 equates to 0 Volts) (BYTE_3 = A0 and BYTE_4 = 93 equates to 232 volts)
IDE08719-MAS07397 - Values from battery mngmt-Act. current HV battery BYTEs_1 & 2, Bits 12,13,14,15,16,17,18,19,20,21,22,23 (BYTE_1 = F
& BYTE_2 = 80 equates to 1.0A)
ID_124 = IDE08719-MAS01420 - Values from battery mgmt-Limit for charge current BYTES_5 & 6, Bits 42,43,44,45,46,47,48,49,50,51 HIGH equates to 0Amps (BYTE_5=03 & BYTE_6=F0) (BYTE_5=0F & BYTE_6=F0 equates to 3 Amps)
I have yet to groogle "how to set scale factors etc"
Re: MEB Chargers
Posted: Fri Oct 18, 2024 1:39 pm
by RetroZero
Confirmed that when running Damiens code and 0x097 00 0F 80 A0 93 00 00 00 ,
WHILST there is no AC connected, "Current condition of battery management" can be switched to HV Mains active, Voltage HV battery=232volts and Current HV battery=1.0amps. When a Type2 charger cable is connected, the values remain at 0.
I know, for testing purposes, the code is supposed to mimic values for a BMS, this where I manually go change Damiens values right?
Re: MEB Chargers
Posted: Wed Oct 23, 2024 7:46 am
by modellfan
I won't say how I found out. VW id.3 Chargers and the other chargers discussed here don't have the same AC plug. The id.3 and propably also id.4 / enyaq have small deviders bentween the horizontal pins. The others don't. CCS HARNESS NOT COMPATIBLE!
Re: MEB Chargers
Posted: Wed Oct 23, 2024 7:53 am
by uhi22
Yeah, this is a very good point. This thread is mixing different vehicle architectures. The headline says MEB (which is ID.3, ID.4, Eniaq, ID.Buzz and so on), but a lot of discussions are around the old MLBevo (Taycan, Audi Q7) / MQB (Golf) platforms.
That's why I always propose to write the related part number to the discussion.
5QE ... ... is the old MQB platform.
1EA ... ... is MEB.
Re: MEB Chargers
Posted: Wed Oct 23, 2024 7:55 am
by modellfan
One more thing my nightly research gave me. Since arround 2021 you can buy an option for 22kw in Audi etron 55 resulting in at least 4 different serialnumbers for chargers. Propably some of them are coded in a tandem mode. As well as there is the option to order the vehicle with one or two charge ports resulting in two numbers, one for single port and one for dual port just for the ccs cable. The dual ports at least are not directly connected to the charger but have an extra splitter [Current DIstribution Unit] in between. If someone has one arround would be interesting how it is working, as it looks like it is just a passive part.
Re: MEB Chargers
Posted: Wed Oct 23, 2024 7:58 am
by modellfan
uhi22 wrote: ↑Wed Oct 23, 2024 7:53 am
1EA ... ... is MEB.
Thank you for clarification. Propably in the whole thread there isn't one post about MEB
Re: MEB Chargers
Posted: Thu Oct 24, 2024 5:56 am
by RetroZero
modellfan wrote: ↑Wed Oct 23, 2024 7:58 am
I agree, this thread is related to 'older' MQB platform . Can we change the Header?
Re: MQB Chargers
Posted: Thu Oct 24, 2024 8:11 am
by Bigpie
I've updated the title of the first post, I'm not going through 8 pages to update them all unless I get really bored
Re: MQB Chargers
Posted: Wed Nov 06, 2024 9:10 pm
by modellfan
Can anybody confirm the pinout? I want to put it into the Wiki.
Re: MEB Chargers
Posted: Thu Nov 07, 2024 12:04 am
by modellfan
Mitchy wrote: ↑Mon Mar 06, 2023 9:27 pm
As per the DBC file I posted, The charger is pretty integrated into the other bus messages, but the messages seem totally different than those found by Damien
**See Next Post for CAN Signal List**
Where do I find the dbc file ?
EDIT:
viewtopic.php?t=3152
Re: MEB Chargers
Posted: Thu Nov 07, 2024 11:16 am
by crasbe
RetroZero wrote: ↑Thu Oct 10, 2024 5:33 am
That does not appear to be the case. 5EA is mostly static and does not have a counter, I would even say it does not have a CRC.
These are the individual messages from this log here:
https://github.com/DomT177/GolfGTE/blob ... TrnRnd.asc
Timestamp: 9.086060 ID: 5ea S Rx DL: 8 00 00 00 00 00 fe fb ff Channel: 1
Timestamp: 10.085670 ID: 5ea S Rx DL: 8 00 00 00 00 78 fe fb ff Channel: 1
Timestamp: 11.086500 ID: 5ea S Rx DL: 8 00 c8 c8 c0 78 fe ff f7 Channel: 1
Timestamp: 11.586220 ID: 5ea S Rx DL: 8 00 c8 c8 c0 78 fe 13 f8 Channel: 1
Timestamp: 36.575940 ID: 5ea S Rx DL: 8 00 c8 c8 c0 78 fe 17 f8 Channel: 1
Timestamp: 37.075410 ID: 5ea S Rx DL: 8 00 c8 c8 c0 78 fe 1b f8 Channel: 1
Timestamp: 40.073940 ID: 5ea S Rx DL: 8 00 c8 c8 c0 78 fe 1f f8 Channel: 1
Timestamp: 43.072480 ID: 5ea S Rx DL: 8 00 c8 c8 c0 78 fe 23 f8 Channel: 1
Timestamp: 47.070790 ID: 5ea S Rx DL: 8 00 c8 c8 c0 78 fe 27 f8 Channel: 1
Timestamp: 51.567900 ID: 5ea S Rx DL: 8 00 c8 c8 c0 28 fe 2b f8 Channel: 1
As you can see, sometimes individual bytes are changing which would be weird if it had a CRC. You'd expect changes happening in two bytes.
It could be something else than a CRC though or it might be a two-part message where the checksum is somewhere else etc.
Re: MQB Chargers
Posted: Mon Nov 11, 2024 9:44 am
by modellfan
modellfan wrote: ↑Wed Nov 06, 2024 9:10 pm
Can't anybody pop out their mutlimeter and measure it? I unfortunatly don't have the original harness yet. Thank you ahead.
Re: MEB Chargers
Posted: Mon Nov 11, 2024 1:34 pm
by modellfan
jrbe wrote: ↑Mon Aug 12, 2024 11:18 am
Reverse image search of a Normaquick NW12 image
with something like "vag coolant connector" finds a bunch.
I put some time into verfying this / finding the original Audi/VW part number. For Audi etron this is the coolant hose assembly:
https://parts.audiusa.com/p/Audi__e-tro ... 480AM.html with part number: 4KE122480AM. One of the connectors is 90° bend, the other is 90° bend + bleed pipe connector. Searching the part number gives some detailed pictures like the one attached and I am pretty sure, I can read 4KE 122 298 as part number. But google doesn't find any parts for this. Any ideas ?
Re: MEB Chargers
Posted: Sun Nov 24, 2024 2:07 pm
by ReasonableMotors
golfdubcrazy wrote: ↑Wed Oct 26, 2022 8:03 pm
looking good, are you planning on doing a teardown ?
Doh! Almost...
Hi all - looking for inside information about the 5QE915681 series of chargers; my B variant isn't lighting up. Details over in Ross-Tech thread (
https://forums.ross-tech.com/index.php?threads/46318/)
If you or anyone on this forum has opened the inverter to probe around inside, please send hints/tips/tricks to keep from breaking the darned thing while trying to interrogate it. I have the 5-star security bit to open the cover, and even got to the point of peeling it up... but wimped out without a second charger in my hands to fit instead. And, no scope immediately in hand to make the most of the reveal.
Am I really the first to open one of these? A pointer to a teardown ... or anyone who wants to send me one to perform a teardown - it's time.
Thoughts?
Micah
Re: MQB Chargers
Posted: Sun Nov 24, 2024 5:23 pm
by jrbe
You unplugged the retract motor. I wonder if it lost it's position reference when it was unplugged or if it's limit switches? are faulty.
Sounds like it can't lock the cable / can't confirm it's locked and won't charge because of that from your description / info.
VCDS should have a way to test all of these io's.
But!!!! Someone on here activated a test in their egolf and heard a bang and now has battery issues. So try to find that post before doing any output tests.
Re: MQB Chargers
Posted: Sun Nov 24, 2024 7:51 pm
by ReasonableMotors
But, lock motor is used when charging with DC/CCS at the Tesla station - arguably more important for lock motor functionality due to no 0V cross-over. And DC/CCS charging is working.
VCDS shows me the motor is locked and unlocked when it's supposed to be; but why, when unlocked already, does it try to unlock 'more' and unlock? Maybe it's a waste heat generator function to keep the motor from freezing ... pure speculation without VW firmware programmer insight.
The, uh, inlet warming is going well. About an hour in and moisture has dried up on the rubber, and the plastic housing is warm to the touch, but not hot.
Re: MQB Chargers
Posted: Sat Feb 15, 2025 8:33 pm
by m.art.y
Anybody had any luck getting the 11kw variant with part number 1EA915684EA to work?
