Page 8 of 8
Re: New BMS for bq76PL455A based batteries
Posted: Mon Jul 08, 2024 12:46 pm
by Volkmar
If anyone is looking for the connector:
JST 04CPT-B1-2A
https://at.rs-online.com/web/p/kfz-stec ... er/1238228
Posted: Sat Aug 24, 2024 10:27 am
by vanwezel
Hi there
just saw your post on the battery's and the BMS system . BMS board with 16s li-ion battery BQ76PL455A
i have acquired 15 of this batteries with this boards on i do also have teh manage ment boxes but dont have a clu how to make this work for me ,could you please help me on how to manage these as i don't have the expertise you have on these programs please
if you would like a fe i am willing to depart with some for your help.
thanks
Louie
Posted: Mon Aug 26, 2024 7:59 am
by Volkmar
Hello,
quick update and hopefully someone has an idea what to do...
I now only have a cable of about 20 cm. from the battery module to the master BMS board. Since I have two strings in parallel, two mast boards were now used and communication with the Zombie VCU happens via can bus.
Charlie told me that one board needed the CAN ID 0x4f1 and the second needed the CAN ID 0x4f5. Works great! Thanks Charlie!
Something strange happens now: when the BMS is running and the wake up signal is gone, then it shuts down normally... that means after a certain time it goes into deep sleep mode.
But it can no longer be woken up from this state, only if I remove the voltage on the permanent plus, then it starts normally.
It seems as if the board gets "stuck" somewhere in the program when shutting down and can't get out of there...
Posted: Mon Aug 26, 2024 8:01 am
by Volkmar
vanwezel wrote: ↑Sat Aug 24, 2024 10:27 am
Hi there
thanks
Louie
Hello Louie,
what help do you need in particular?
If you tell us exactly what you need, we will be happy to help you!
Posted: Mon Aug 26, 2024 9:44 am
by vanwezel
Hi there
Thank you for your reply.
I would like to use these batterys in my shed as a power source for my ham radios.
But don't know how to arrange these to a power bank as they need to be on a bms .
Each battery have a board and I have all the links
But don't know on what program or how to connect these battery's in a bank of power and then charge them on solar or with a built wind mil maybe
Any suggestion would be welcome.
They are at 58 volt now all of them. They come from a volvo electric Taxi .we're stored fir three years and was new so never been used. They are all in great condition.
Would apriciate any info. On how to utilise these as a power bank .
I have a old inverter too.
Thanks for your reply.
Posted: Mon Aug 26, 2024 12:04 pm
by Volkmar
vanwezel wrote: ↑Mon Aug 26, 2024 9:44 am
Hi there
if these are the same modules as I'm using, then each module has 16 cells. That means 16 x 3.6 volts = 57.6 volts nominal voltage.
Charging limit: 16 x 4.2 = 67.2V
Discharge cutoff: 16 x 3.2 = 51.2 V
Depending on what voltage you need for your system, you can then connect the appropriate number in parallel or in series.
Parallel means plus on plus and minus on minus and so on. This doesn't increase your voltage but increases the possible amps.
Serially, vice versa means plus to minus to plus to minus etc.
This increases your voltage but not the amps.
For the exact structure of your solar system, I recommend a photovoltaic forum because there are a lot of experts there.
Thanks to the excellent work of Catfish, you can recreate your BMS via this link:
https://github.com/catphish/ti-daisychain-bms
Posted: Mon Aug 26, 2024 3:50 pm
by vanwezel
Hi
Thank you for the info much appreciated.
Can I use the existing Bms boards and how do I mange this I can send some pictures if needed I have other electronic boxes that I striped out of the original unit abd have all the relay, exectra too.
How to I wire up the existing bms units on the batteries and what program do I use on this to monitor the bms boards ?please
I can connect the batterys in series or parallel I do understand that part but what voltage do I need to go to to get best and cheapest way to use them as back up batteries wit h I will use my I veryer to 230 volt from them .
I need to know how to set this up please.?
Thank for your help I realy apriciate it .
Louie
Posted: Tue Oct 01, 2024 3:07 pm
by jrubiom74
Hi there
just saw your post on the battery's and the BMS system, Excellent Job!
I have acquired 6 of this batteries with this boards on a EV that I'm working (VW Pick Up 1972). It's working on 360V but I need to manage the batteries and charge them.
I'm use to work with Tesla S Battery Pack and Thunderstruck BMS & EVCC but I have no clue on how to work with this Battery Pack.
Could you please help me on how to manage / charge these as I don't have the expertise you have on these programs please?
If you would like a fee I'm willing to depart with some for your help.
Thank you in advance
Posted: Thu Oct 31, 2024 10:29 am
by catphish
Hello everyone!
I just wanted to update this thread with some important information as I get questions about this from time to time.
First of all, to give a little background, the best way to build a BMS to work with these batteries would be to design a PCB with a bq76PL455A chip and an STM32 microcontroller. Unfortunately, when I designed my car, there was a huge problem with chip availability and this chip was impossible to obtain. What I did instead was to design my own circuit using an RP2040 and some external circuitry that simulates the operation of this chip.
This resulted in two projects, first
https://github.com/catphish/lg-daisychain and then an improved design
Both versions are functional, with the second one being a major improvement. Anyone is free to build and use these boards (ideally the later version).
HOWEVER... I would strongly suggest that anyone serious about using these batteries going forward would be better off designing a new board using a genuine bq76PL455A chip which is now available.
I apologize if I haven't been very responsive in providing support for this design.
Posted: Tue Nov 19, 2024 10:43 am
by Volkmar
Hello everyone,
I also use the BMS provided by Charly and it works very well too! Thank you again for your work Charly!
now to my problem:
I have the following setup:
Daisychain BMS, Zombie VCU, Tesla SDU with the IO board and BMW LiM.
Unfortunately, I haven't managed to charge the batteries with a DC fast charging station yet. Has any of you already managed a charge with the BMW LiM and the BMS and maybe someone can tell me the trick?
Do I have to set a charging limit from the BMS? It is supposedly 9996 A on the display of Zombie VCU. Can you specify this somewhere or is it required for the LiM?
Second question: How do you calculate the SoC and how do you display it? Is the SoC required for a successful charge?
I hope my questions are clear and you can help me further.
Thank you and happy crafting...
Posted: Sat Sep 20, 2025 1:42 am
by malcolmputer
I was just checking that project out because I'm looking at reverse engineering the Chrysler Pacifica battery satellites which appear to be this same bq76PL455A part x3.
Is the kicad project on that github the latest version? Back silkscreen text is "Daisychain BMS v5". I ask because the readme mentions 3 interfaces and this one has 2 (my project is fine with one or two, so no worries there), and also the common mode filter has been increased past the original 22uH so it could be a later rev?
Happy to redesign or add any features you get around to doing if you like, but I've got some batteries at 3.56V average so I'd like to bring them up a little bit and watch their cell voltages when I do on the time-scale order of a few weeks not a few months.
Posted: Sat Sep 20, 2025 8:44 am
by catphish
malcolmputer wrote: ↑Sat Sep 20, 2025 1:42 am
The version on Github is indeed the latest version. The version I designed for my own vehicle supported 3 strings, but more recently while working on a vehicle for someone else, I added a transformer to improve resistance to interference, and due to board space, I reduced the number of channels from 3 to 2 at the same time. The design is otherwise the same.
If you are just going this on the bench for now, the BMS will work perfectly well. If you plan to use this in a vehicle, I would seriously recommend replacing the DIY transceivers with a pair of bq76PL455A chips. I realise this is a much more complicated piece of work though.
Please let me know if you need any more help getting it running.
