squidopolis wrote: ↑Mon Jan 19, 2026 5:27 am
Got this working, below is my python script:
#send_msg
# The CANlib library is initialized when the canlib module is imported. To be
# able to send a message, Frame also needs to be installed.
from canlib import canlib, Frame
import time
#CAN
ch_a = canlib.openChannel(channel=0)
ch_a.setBusParams(canlib.canBITRATE_500K)
ch_a.busOn()
#IGNITION MSG
IGN_counter = 0
IGN_DLC = 4
IGN_data_array = bytearray(4)
IGN_MSG_ID = (0x03C0 & 0xFFFF)
#MSG_EMG_01 MSG
EMG_01_counter = 0
EMG_01_DLC = 8
EMG_01_data_array = bytearray(8)
EMG_01_MSG_ID = (0x0151 & 0xFFFF)
MO_EMG_OperationModeReq = ( 1& 0xF)
MO_EMG_SpeedReq = (2048&0x7FFF)
MO_EMG_MaxTorqueGradient = (0x01&0x7F)
MO_EMG_Clamp15 = 1
MO_EMG_Deactivate_HV = 1
MO_EMG_MaxVoltage = (4&0xFF)
#MSG EMG_02 MSG
EMG_02_counter = 4
EMG_02_DLC = 8
EMG_02_data_array = bytearray(8)
EMG_02_MSG_ID = (0x0152 & 0xFFFF)
MO_EMG_MaxCurrent = (1027&0x7FF)
MO_EMG_MinCurrent = (1023&0x7FF)
MO_EMG_MinVoltage = (106&0xFF)
MO_EMG_TorqueReq = (32781&0xFFFF)
#Constant Bytes
# VAG MB 0 1 2 3 4 5 6 7 8 9 A B C D E F
MB0151 = bytearray([ 0x42, 0x7E, 0xB4, 0x01, 0x0A, 0x91, 0xDF, 0x10, 0xA1, 0x73, 0x59, 0x05, 0xF6, 0x79, 0x0B, 0xDE])
MB0152 = bytearray([ 0x58, 0x61, 0xCF, 0x30, 0x69, 0x6A, 0xC4, 0xC6, 0xB2, 0x53, 0x22, 0xB6, 0xEC, 0x95, 0xCA, 0xF8])
MB03C0 = bytearray([ 0xC3, 0xC3, 0xC3, 0xC3, 0xC3, 0xC3, 0xC3, 0xC3, 0xC3, 0xC3, 0xC3, 0xC3, 0xC3, 0xC3, 0xC3, 0xC3])
#Calculate the CRC checksum for VAG CAN Messages
def vw_crc_calc(byte_array: bytearray, DLC: byte, MSG_ID: int):
poly = 0x2F
xor_output = 0xFF
crc = 0XFF
magic_byte = 0x00
counter = byte_array[1]&0x0F
if MSG_ID == 0x151:
magic_byte = MB0151[counter]
elif MSG_ID == 0x152:
magic_byte = MB0152[counter]
elif MSG_ID == 0x3C0:
magic_byte = MB03C0[counter]
for i in range(1, DLC + 1):
if i<DLC:
crc ^= byte_array
else:
crc ^= magic_byte;
for j in range(8):
if (crc&0x80):
crc = (crc << 1) ^ poly
else:
crc = (crc << 1);
crc ^= xor_output;
byte_array[0] = crc&0xFF
# Send command messages ~1ms for ~10seconds
for i in range(50000):
#load Ignition Frame
IGN_counter += 1
if IGN_counter>0xF:
IGN_counter = 0
#Load Data (Constant 0x23 Value)
IGN_data_array[1]=IGN_counter&0xF
IGN_data_array[2] = 0x2
#IGN_data_array[3] = 0x03
#Modify CRC byte[0]
vw_crc_calc(IGN_data_array, IGN_DLC, IGN_MSG_ID)
#Send Igniton CAN FRAME
frame = Frame(IGN_MSG_ID, IGN_data_array, flags=canlib.MessageFlag.STD )
ch_a.write(frame)
#load EMG_01 Frame
EMG_01_counter += 1
if EMG_01_counter>0xF:
EMG_01_counter = 0
#load Data
EMG_01_data_array[1]=((MO_EMG_OperationModeReq<<4)&0xF0)+(EMG_01_counter&0xF)
EMG_01_data_array[2]=(MO_EMG_SpeedReq&0xFF)
#EMG_01_data_array[3]=((MO_EMG_SpeedReq>>8)&0x7F)+((MO_EMG_Clamp15<<7)&0x80)
#EMG_01_data_array[4]= ((MO_EMG_Deactivate_HV<<2)&0x1C)
EMG_01_data_array[4]=0xFF;
EMG_01_data_array[5]=0x01;
#EMG_01_data_array[4]= 0x26;
#EMG_01_data_array[5]= (MO_EMG_MaxVoltage&0x1)
EMG_01_data_array[7]=(MO_EMG_MaxTorqueGradient&0x7F)
#Modify CRC byte[0]
vw_crc_calc(EMG_01_data_array, EMG_01_DLC, EMG_01_MSG_ID)
#Send EMG 01 CAN FRAME
frame = Frame(EMG_01_MSG_ID, EMG_01_data_array, flags=canlib.MessageFlag.STD )
ch_a.write(frame)
#load EMG_02 Frame
EMG_02_counter += 1
if EMG_02_counter>0xF:
EMG_02_counter = 0
#load Data
EMG_02_data_array[1] = ((MO_EMG_MaxCurrent<<4)&0xF0)+(EMG_02_counter&0xF)
EMG_02_data_array[2] = ((MO_EMG_MaxCurrent>>4)&0x7F)+((MO_EMG_MinCurrent<<7)&0x80)
EMG_02_data_array[3] = ((MO_EMG_MinCurrent>>1)&0xFF)
# EMG_02_data_array[4] = ((MO_EMG_MinCurrent>>9)&0x3)
EMG_02_data_array[4] = 0x3D
EMG_02_data_array[5] = (MO_EMG_TorqueReq&0xFF)
EMG_02_data_array[6] = ((MO_EMG_TorqueReq>>8)&0xFF)
EMG_02_data_array[7] = (MO_EMG_MinVoltage&0xFF)
#Modify CRC byte[0]
vw_crc_calc(EMG_02_data_array, EMG_02_DLC, EMG_02_MSG_ID)
frame = Frame(EMG_02_MSG_ID, EMG_02_data_array, flags=canlib.MessageFlag.STD )
ch_a.write(frame)
#Constants
B000_const = bytearray ([0x76,0x40,0x01,0x05,0x02,0x00,0x00,0x00])
frame = Frame(0x1B000076, B000_const, flags=canlib.MessageFlag.EXT)
ch_a.write(frame)
B504_const = bytearray ([0xC4,0x09,0x00,0x00,0x26,0x19,0x14,0x51])
frame = Frame(0x504, B504_const, flags=canlib.MessageFlag.STD )
ch_a.write(frame)
B3A3_const = bytearray ([0x17,0x9C,0xFB,0x41,0x42,0x3F,0xFE,0xCC])
frame = Frame(0x3A3, B3A3_const, flags=canlib.MessageFlag.STD )
ch_a.write(frame)
B18B_const = bytearray ([0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00])
frame = Frame(0x18B, B18B_const, flags=canlib.MessageFlag.STD )
ch_a.write(frame)
B18D_const = bytearray ([0x00,0xF0,0x7F,0xC1,0x00,0x80,0x26,0x2])
frame = Frame(0x18D, B18D_const, flags=canlib.MessageFlag.STD )
ch_a.write(frame)
B171_const = bytearray ([0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00])
frame = Frame(0x171, B171_const, flags=canlib.MessageFlag.STD )
ch_a.write(frame)
BEE_const = bytearray ([0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00])
frame = Frame(0xEE, BEE_const, flags=canlib.MessageFlag.STD )
ch_a.write(frame)
if i % 2 == 0:
B040_const = bytearray ([0x07,0x0E,0x00,0x00,0x80,0x00,0x20,0x62])
frame = Frame(0x040, B040_const, flags=canlib.MessageFlag.STD )
ch_a.write(frame)
else:
B040_const = bytearray ([0x4B,0x0F,0x00,0x00,0x80,0x00,0x20,0x64])
ch_a.write(frame)
if i % 2 == 0:
B0FD_const = bytearray ([0x23,0xE0,0x3F,0x00,0x00,0x00,0x00,0x00])
frame = Frame(0x0FD, B0FD_const, flags=canlib.MessageFlag.STD )
ch_a.write(frame)
else:
B0FD_const = bytearray ([0x29,0xE1,0x3F,0x00,0x00,0x00,0x00,0x00])
ch_a.write(frame)
B0A8_const = bytearray ([0x00,0xE0,0x3F,0x57,0x7F,0x64,0x00,0x00])
frame = Frame(0x0A8, B0A8_const, flags=canlib.MessageFlag.STD )
ch_a.write(frame)
# Example: print first 5 rows of data
#print(f"{msgID_INT:04x}: ,{d0_INT:04x},{d1_INT:04x},{d2_INT:04x},{d3_INT:04x},{d4_INT:04x},{d5_INT:04x},{d6_INT:04x},{d7_INT:04x}")
#print(i)
time.sleep(0.01)
# Lastly, close all channels with close() to finish up.
ch_a.close()
#ch_b.close()
