Page 1 of 2
Re: PowerWatcher Display for Tesla
Posted: Tue Oct 01, 2019 4:27 pm
You could always use the Zero EV can messages for the DU as a base.
Currently populated two messages with the following
Posted: Tue Oct 01, 2019 6:10 pm
Thanks Tom. I'll use that as a template.
Posted: Tue Oct 01, 2019 6:31 pm
Ok then here is a stripped down DBC attached, also has the base Can info for SimpBMS and the open source Tesla Charger. I removed some info I received in confidentially.
Cannot upload '.dbc' that is why it is rar'ed
Posted: Mon Oct 14, 2019 7:45 pm
New webshop for Powerwatcher products :
https://shop.emkit.net/shop
Posted: Mon Oct 14, 2019 8:34 pm
by zippy500
Looks interesting.
I just looked at his power watcher 3 high voltage,
Max voltage 200v
Is this correct ?
Posted: Tue Oct 15, 2019 6:42 am
Where did you see 200v for the powerwatcher 3? powerwatcher 2 was limited to 200v NOT powerwatcher 3. powerwatcher 3 can go to 450v.
Posted: Tue Oct 15, 2019 6:32 pm
by jon volk
Jack Bauer wrote: Mon Oct 14, 2019 7:45 pm New webshop for Powerwatcher products :
Just to confirm, the high voltage V3 kit currently in the webshop is ready to go for Telsa LDU compatibility, assuming the proper CAN messages are loaded?
Posted: Tue Oct 15, 2019 8:23 pm
by Igor
The webshop lists two different powerwatcher 3 kits. The lower priced "middle voltage kit" looks like it's limited to 200v.
Posted: Wed Oct 16, 2019 7:50 am
@jon volk no not yet. Seeing as no one wants to bother making a list of can commands for Yuriy it's waiting on me.
Posted: Wed Oct 16, 2019 8:27 am
What can commands are you after? As I provided an dbc on the previous page for certain parameters.
Posted: Wed Oct 16, 2019 11:54 am
Right so based on Tom's dbc I have attempted to make a human readable CAN spec which is attached. I think it captures most of the items we would care to have on a display. Powerwatercher should be able to do the maths to get road speed from motor rpm and tyre size. It already has this facility for analog speed input. Let me know if I've missed anything.
Posted: Wed Oct 16, 2019 1:21 pm
Attached amended version following some feedback from Yuriy. He has confirmed vehicle speed from motor rpm will be supported.
Powerwatcher V3 can go up to 600vDC. I have asked him to update his website to reflect this as I could buy a Model 3 if I had a euro for everyone asking this:)
Posted: Wed Oct 16, 2019 5:01 pm
aaannnnd the final version:) Temperature now 1 bit per deg C and signed.
Posted: Mon Feb 24, 2020 1:18 am
by jon volk
Does the below look correct for translating the .pdf of standards into values that get plugged into the software?
IDC= 309, 0, 16, .1
UDC= 309, 16, 16, .1
UAUX= 309, 32, 8, .1
DIN_OCUR= 309, 40, 1, 1
IAC= 309, 48, 16, .1
OPMODE= 310, 0, 4, 1
DIR= 310, 8, 4, 1
SPEED= 310, 24, 16, 1
TMPHS= 310, 48, 8, 1
TMPM= 310, 56, 8, 1
Posted: Mon Feb 24, 2020 7:33 am
by joromy
Have put it in the Wiki.
Would recommend to not shorten any values in the CAN messages, that are coded in the inverter hardware.
Better to shorten in the receiving end.
Posted: Mon Feb 24, 2020 3:36 pm
by jon volk
So, you're saying just leave the gain fields at 1 and just manipulate the data in the receiving code?
Posted: Mon Feb 24, 2020 3:45 pm
by joromy
That to, but was more referring to the motor and HS temp they are 16bit resolution in code.
I think is good practice to have it same as the programmer intended.....
I don't know the reason for having so high resolution, only the programmer knows.
The point is to have a defined CAN standard, not exactly the way I want it :)
Good to have some input and suggestions.
Posted: Mon Feb 24, 2020 3:56 pm
by jon volk
Ahhhh got it. I wasn't sure if that was directed at my post or the parameters in general.
Posted: Mon Feb 24, 2020 4:16 pm
Just to update on this I now have the hardware and software for testing this with the Tesla drive unit. Just not had time to do so as yet.
Posted: Sun May 17, 2020 5:30 pm
by bulletbug
I've got the basic high voltage hardware from PowerWatcher. I'm not far enough with my first build to have it up and running yet but I'm definitely interested in seeing what type of customization will be possible for displays. I'm hoping that I'll be able to pickoff the data being reported and display it within a graphic that I set up. I'm working on converting a 69 VW beetle, and would love to replace the speedo with a digital version that looks like the original with the extra fields on information like WH, consumption and "fuel gauge".
Posted: Sat Sep 05, 2020 11:32 pm
by Roadstercycle
jon volk wrote: Mon Feb 24, 2020 3:56 pm Ahhhh got it. I wasn't sure if that was directed at my post or the parameters in general.
Jon, Did you get your power watcher up and running?
Posted: Sun Sep 06, 2020 12:00 am
by jon volk
Roadstercycle wrote: Sat Sep 05, 2020 11:32 pm
Never went that route. Working on a web-Bluetooth display instead.
Posted: Sun Sep 06, 2020 12:08 am
by Roadstercycle
Hopefully a new thread on that sometime. I'm interested and curious.
