Re: 1971 GMCe Lexus GS450H BMW 530e Tesla Model S Electruck
Posted: Wed Apr 30, 2025 2:50 pm
by Gregski
watch this Certified Zip Tie Technician attempt to explain how a pre charge circus works
Posted: Tue May 06, 2025 2:03 am
by Gregski
bigger 24 kWh BMW battery pack going in tonight, this should give me a range of just over 80 miles
modules arranged in installation formation
the patented porcupine design
Posted: Tue May 06, 2025 3:09 pm
by Gregski
well then I saw this mess and I just couldn't let it go...
some time later.jpg (9.72 KiB) Viewed 5521 times
Posted: Thu May 08, 2025 5:13 am
by Gregski
So now lemme tell you what I'm not supposed to tell you, the extra curriculars
so it all started with me wanting to relocate the water pump which then led me to this, replacing the radiator, and I did this for a couple reasons, first I got tired or using many reducer hoses to step down from like 1 1/2 inches down to 3/4 for the Tesla water pump and even further down to 5/8ths for the inverter, and transmission
and the second reason was cause the darn bottom outlet port on my stock Chevy radiator headed straight for the passenger side frame rail, so I needed a narrower radiator, complements of this sexy 2014 Nissan Versa
Mandatory Stare 'n' Compare
the new Versa rad has only 1 1/8th inch inlet and outlet
all moched up
notice how the bottom outlet clears the frame rail now - Winning !
Posted: Thu May 08, 2025 12:32 pm
by jrbe
Consider blocking some of the grill off if you haven't. You likely don't need that much of an opening with your reduced cooling needs. Should help you get some more mileage.
Posted: Fri May 09, 2025 2:04 pm
by Gregski
you all ever werk on your car and say ahhh I'll do that later, well looks like now it's later for the Greg and he is going around and a fixn' everything he should have done did right the first time
here I am finishing loomin' the OEM headlight wire harness, I swear once I run out of this corrugated split wire loom (pronounced: cheap crap) I am graduating to that sexy braided expendable wrap like all the cool kids be runnin'
Posted: Fri May 09, 2025 2:10 pm
by Gregski
I swear there's a wire mess every where I look, that green and yellow wire bundle is the stock rear lights harness, and all I really have going to the OEM bulkhead (everything else was engine related and has been deleted) is the red wire which supplies main 12v power to the OEM fuse box in the cockpit, the tiny black wire is the signal for the Prius EPAS Electronic Power Ass. Steering, this should get cleaned up tonight, so that my brain can function and not be distracted
that's a little gooder
Re: 1971 GMCe Lexus GS450H BMW 530e Tesla Model S Electruck [Upgrade]
Posted: Fri May 09, 2025 4:45 pm
by Alibro
Just follow my mantra and all will be well.
"If you can't be bothered to make it tidy, cover it up"
You're bound to have a suitable 'something' that will hide all sins.
Posted: Sat May 10, 2025 8:32 pm
by Gregski
Alibro wrote: ↑Fri May 09, 2025 4:45 pm
ha ha, you mean like I've been hiding this fugly Prius power steering mess for over a year, note the unclipped zip ties, how recluse it that?
I can live with this
Posted: Sun May 11, 2025 5:33 pm
by Gregski
Progress Not Perfection
I live my life one module at a time!
Posted: Mon May 12, 2025 4:02 am
by Ghia66
This is getting real!
Posted: Mon May 12, 2025 9:25 am
by Gregski
Ghia66 wrote: ↑Mon May 12, 2025 4:02 am
Posted: Thu May 15, 2025 4:56 pm
by Gregski
GMCe DIY EV 24 kWh BMW Battery Pack Upgrade
Posted: Fri May 16, 2025 1:23 pm
by Gregski
how it started...
Posted: Fri May 16, 2025 2:03 pm
by Jacobsmess
Wow, that's a real nice paint job on that piece of card.
Posted: Fri May 16, 2025 2:06 pm
by Gregski
how it's goink...
[ just a trial fit, so please put away your EyeCrometers ]
meanwhile at the lesser known, Send, Notch, Send Facility
Posted: Sat May 17, 2025 7:32 am
by Alibro
Nice box!
Not even slightly jealous!
Posted: Mon May 19, 2025 1:49 pm
by Gregski
Alibro wrote: ↑Sat May 17, 2025 7:32 am
Nice box!
Posted: Tue May 20, 2025 2:48 am
by Gregski
rethinking the component placement, not in love where the black box has taken residence
good ol' air cooled first gen Chevy Volt DC-DC alternator
and above it in the middle(ish) is it's older sibling first gen Chevy Volt battery charger
Posted: Tue May 20, 2025 7:46 am
I see a lid for the top, is there a Bottom to the Battery box?
Also the SBox outside the battery box, thats a NO-NO in my opinion as its the thing that shut off HV from leaving the box. It is also clearly not waterproof in any way.
Posted: Sat Jun 28, 2025 4:02 am
by Gregski
so my Alibaba 400x300x200mm Electrical Outdoor Metal Waterproof Vented Junction Box With Fan finally arrived
Posted: Sat Jun 28, 2025 4:12 am
by Gregski
a little sneak peak ahead to Phase III, we will be upgrading to a 6 Killer Whaler battery charger/dc-dc combo unit, and rolling our own contactor/junction box
no Phase II is not completed, you did not miss anything
that gray box looks ridiculous
Posted: Sat Jun 28, 2025 11:10 am
by Alibro
Nice looking box.
Too rich for my tastes tho.
Posted: Sat Jun 28, 2025 12:48 pm
by Gregski
Alibro wrote: ↑Sat Jun 28, 2025 11:10 am
Nice looking box.
I hear you, well it all started with $52 bucks, then the fees, charges and taxes added up
Posted: Sat Jun 28, 2025 2:13 pm
by Alibro
Gregski wrote: ↑Sat Jun 28, 2025 12:48 pm
Is that your 'Trump Tax' that was meant to be absorbed by the importer costing $36.75?
Oh!, I guess you're the importer.
