Page 6 of 12
Re: Gen 3 inverter converter control software
Posted: Thu Feb 11, 2021 1:31 am
by Bratitude
Possible to add in a menu to just control the buck/boost module?
Edit*
For dc charging from a variety of sources. Ie smaller battery pack, solar, wind, etc
Would have to isolate the module of course
Posted: Thu Feb 11, 2021 4:49 am
by Leo M
Thanks! Waiting for updates.) great job!
Posted: Fri Feb 12, 2021 4:27 am
by Leo M
he second day I try to compile the Interfax WEB file (((constantly gives an error (((I tried to build it in arduino - and also failed (((please re-upload the files...
Posted: Fri Feb 12, 2021 7:45 am
by Bigpie
Whats your error?
Posted: Fri Feb 12, 2021 9:17 am
by Leo M
No connection d1_mini_oto
Posted: Fri Feb 12, 2021 9:21 am
by Leo M
Posted: Fri Feb 12, 2021 9:26 am
by Leo M
Posted: Fri Feb 12, 2021 9:32 am
by Bigpie
Yea, your esp ip address wont be 192.168.1.20, that'll need changing to match your ISP, unless you've told it to join your network you will need to change to connect to the module wifi network and uss the 192.168.4.1 ip look in platform.ini you could also upload via the cable.
Posted: Fri Feb 12, 2021 10:27 am
by Leo M
The photo shows a trial address ))) that's what you have to offer I also tried...I tried it -- the error is the same(((
Posted: Fri Feb 12, 2021 10:29 am
by Leo M
platform.ini, 192.168.1.26
Posted: Fri Feb 12, 2021 10:33 am
by Leo M
This is your code from the file )))
Posted: Sun Feb 14, 2021 8:08 am
by Leo M
Everything loaded normally) but does not work( what is the problem?
Posted: Sun Feb 14, 2021 8:52 am
by Bigpie
You also need to upload the filesystem.
Posted: Sun Feb 14, 2021 9:10 am
by Leo M
ok.thanks.we will try)
Posted: Sun Feb 14, 2021 10:05 am
by Leo M
Yes!!!! It worked.thank you so much for your help . Waiting for the updated files)))
Posted: Sun Feb 14, 2021 11:25 am
by Bigpie
You'll also need the code from my repo on the atmega for the params etc
These haven't been merged back yet, note I haven't charged a high voltage pack with it at the moment. Not sure if anyone else has.
I'm getting laptop out in a bit, I'll push changes.
Posted: Sun Feb 14, 2021 12:45 pm
by Leo M
Ok.waiting for an update)
Posted: Mon Feb 15, 2021 9:24 am
by Leo M
Hi! I attach a photo .why there is no output of parameters . The board is not yet connected to the inverter...Should the parameters be output from Atmega when the inverter is not connected? Or am I in trouble?)))
Posted: Mon Feb 15, 2021 10:27 am
by Bigpie
It loads them from the Atmega, try typing 'params' without quotes, and hitting send, see if that loads them. It should issue that on loading.
Posted: Mon Feb 15, 2021 11:32 am
by Leo M
Tried it) parameters are not loaded(((
Posted: Mon Feb 15, 2021 12:10 pm
by Bigpie
Do you see the message come from the ESP in the browser developer tools? If you look at the web socket messages.
Posted: Mon Feb 15, 2021 1:07 pm
by Leo M
In the browser, here is the information after sending the command
Posted: Mon Feb 15, 2021 1:20 pm
by Bigpie
no capital p.
I'm busy with some other stuff for a while, but I'll try and get set back up to make this more robust asap.
I'm going down the outlander charger route now as my battery pack voltage is too high for this with single phase, but will hopefully at some point reconfigure it to under 300V and do some proper charging with this setup but as this stands, I'll not be using it unless someone comes up with a neat way of using it on single phase on packs the > 340VDC batteries, as that is beyond my ability.
Posted: Mon Feb 15, 2021 1:45 pm
by Leo M
So what about the output of the parameters? What's my problem? I am interested in the charging varian in two versions-both from 3 phases and from one. And I am interested in this project .so fill in the updated files if you don't mind. Maybe there are Arduino files, it's easier for me to work with them, so to speak, more familiar. In any case, thank you for your hard work...
Posted: Mon Feb 15, 2021 2:47 pm
by Bigpie
try typing params, all lower case and hitting send, I've noticed it not always loading them correctly when the page first loads.
