Page 5 of 6
Re: GS450H gearbox with Camry inverter G9200-33171
Posted: Fri May 16, 2025 4:42 pm
PetersonOctavius wrote: Fri May 16, 2025 3:30 pm ully charged, isa shunt max Amp report is around 120-129A, throttle all the way down
Can you please plot this for me. There might be some tweaking you can do to your Zombie code to get a few more amps out.
Posted: Fri May 16, 2025 4:47 pm
by PetersonOctavius
im at 350volts now, should i charge first?
Posted: Fri May 16, 2025 4:48 pm
No need, I want to see the sag reported. Please plot left UDC and invUDC and right IDC
Posted: Fri May 16, 2025 5:25 pm
by PetersonOctavius
after 1 plot, the vcu will not start another plot
Posted: Fri May 16, 2025 5:27 pm
Was this flat out? Can you do IDC right and Potnom left?
Just want to see how much "throttle" is left
Posted: Fri May 16, 2025 5:29 pm
by PetersonOctavius
throttle to the bottom!
Posted: Fri May 16, 2025 5:40 pm
by PetersonOctavius
throttle wasnt fully pressed (user error, to focus on the logging and the end off the road ahead)
Posted: Fri May 16, 2025 5:47 pm
Can you please post your params.
Posted: Fri May 16, 2025 5:50 pm
by PetersonOctavius
freshly downloaded
Posted: Fri May 16, 2025 5:52 pm
So you can change the values here in GS450h.cpp
758        htm_data[81]=(10000)&0xFF;  // discharge ability of battery
759        htm_data[82]=((10000)>>8);
I changed them to this to get more power before, I would say change it to 12500 and test if you get more power. If not there may be another limit like the Torque requested which we can also look at.
Posted: Fri May 16, 2025 5:56 pm
by PetersonOctavius
New code will be then:
758 htm_data[81]=(12500)&0xFF; // discharge ability of battery
759 htm_data[82]=((12500)>>8);
Posted: Fri May 16, 2025 5:58 pm
Yes, the line numbers are for reference. I do not know if you added new lines.
Posted: Fri May 16, 2025 6:46 pm
by PetersonOctavius
changed the code to 12500, both lines.
went for a test drive, 124Amps at 340 volts
Posted: Fri May 16, 2025 7:47 pm
by Gregski
PetersonOctavius wrote: Fri May 16, 2025 3:30 pm My pack is made of samsung sdi cells, 67Ah, 3C peak
96 cells
That would be 67 x 3 = 201A
Fully charged, isa shunt max Amp report is around 120-129A, throttle all the way down
It feels more like a torque request limit
possibly have you logged your torque yet? when I did that on my VW Rabbit with the 3rd Gen Prius Inverter you can clearly see it pegs out at 3500 and wont go above that setting
Posted: Fri May 16, 2025 7:51 pm
by PetersonOctavius
Gregski wrote: Fri May 16, 2025 7:47 pm possibly have you logged your torque yet? when I did that on my VW Rabbit with the 3rd Gen Prius Inverter you can clearly see it pegs out at 3500 and wont go above that setting
im going to log torque now
Posted: Fri May 16, 2025 7:52 pm
Nope thats a fixed zombie setting request. Made no difference raising it on your setup.
Potnom direct translates to it.
Posted: Sat May 17, 2025 1:04 am
by PetersonOctavius
quick run i did a while ago, potnom vs speed
never went above 6k rpm
negative rpm MG2 is forward on my setup
Posted: Thu May 22, 2025 6:47 am
by PetersonOctavius
after quite some days of driving around, same oil pump problem came back.
driving...after while the pump turns of. i've been running it with a separate PWM generator, 1kHz, 16%duty
i started to think its the oil pump controller.
i ve been building drones for almost 10 years now, so i have some ESC (electronic speed controller aka inverter in the ev world) laying around.
i soldered one on the oil pump, it spun really slow but i managed to move the car. drones esc's are sensorless, just plug it in, give it pwm, it spins away.
so can i say its the pump controller?
Posted: Thu May 22, 2025 2:43 pm
by Gregski
i would go super basic and check and clean all them oil pump plugs and connectors and triple check its grounds
the little black side connector likes to break off and or bend its pins
Posted: Thu May 29, 2025 11:03 pm
by PetersonOctavius
i ordered this pump
i opened, it seems to be a brushed dc motor, runs smooth.
on the bottom side, there s a + mark
when connected to 12.7volts, it pulled around 3-4 Amps.
its has a bigger and a smaller hole.
when i connected positive to positive, (as marked next to the pins) its sucks at the bigger hole, and pushes at the smaller hole.
with reverse polarity, it does the opposite which matches the gs450h pump, sucks from the smaller hole and pushes through the bigger hole.
im pretty sure it will make enough pressure to drive the car, for now i need an adapter so i can mount the pump to the gearbox.
Posted: Thu Jun 05, 2025 2:49 pm
by PetersonOctavius
Turns out My oil pump is "dead".
the main reason those pumps die seems (to me) to be water getting in the brushless motor of the pump, which then kills the resolver board. without a resolver the controller will not turn the pump. that s why i could make the brushless motor spin with a sensorless ESC.
that being said i have 2 gs450h pump controller which i butchered the connectors, but they still work, but i have no pump because the resolver board is damaged.
in other news, im trying to fit the BMW oil pump to 450h gearbox, i 3D printed an adapter to directly mount the pump to the gearbox, but the pump's mounting holes and the gearbox's hole interfere with each other.
oil lines will be the way to go. now i gotta but that 99$ adapter for the GS450H
Posted: Thu Jun 05, 2025 5:29 pm
by robertwa
Just a thought - I wonder if it would be possible to remove the impeller from the stock pump, mount it back in place, and add an inline pump across the two ports that are used for an optional oil cooler circuit....
Posted: Thu Jun 05, 2025 5:34 pm
by PetersonOctavius
i m trying to do something similar, but still using the original oil pump head
Posted: Thu Jun 05, 2025 10:13 pm
by jrbe
You could add an oval pocket for the oil flow. Or you could drill on an angle to connect the 2. It complicates it but you could do a double stack plate with the oval port between them. And flush head bolts are your friend for things like this.
You could also consider a vesc to run the dead pump. You can write a Lua script to set the pump rpm to maintain a pressure. Pretty sure you can use a vesc analog input from a pressure sender to reference. Just make sure the vesc you pick can run comfortably at your 12v voltage and check the Lua script limitations first.
Posted: Thu Jun 05, 2025 10:27 pm
by PetersonOctavius
Hey jrbe, that's quite a sketch you made there. i understood it partially, im not that good of a designer, and here on the island the machineshops couldnt fabricate something like that.
the easiest way would be indeed to use the "dead pump" , ive attached a drone esc to it, it did spin and create some pressure to move the car, but not enough as the would go into free spin time to time.
the oil pump has 12 coils in the black casing and 8 magnets on the rotor, not sure if the coils are in a Y of ^ config
the esc im using is rated 26volts 35Amps.
i dont have much options on the esc to try to make it run faster at 12-14 volts
