Page 5 of 5
Re: can id´s 4 Gear Selector
Posted: Wed Jul 12, 2023 6:03 pm
by VanGogh
LRBen wrote: ↑Wed Jul 12, 2023 5:56 pm
What do you mean by brake pedal?
Now the knob rotates freely. But in the car, it is locked and only when the brake pedal is pressed does the knob unlock. How to implement it? What data needs to be sent to the CAN bus?
Posted: Wed Jul 12, 2023 6:25 pm
by VanGogh
I checked the code Gen1 by tom91 with a modified void setup ().
void setup()
Serial.begin(115200);
if (CAN0.begin(MCP_ANY, CAN_500KBPS, MCP_16MHZ) == CAN_OK)
Serial.println("CAN Init OK");
else
Serial.println("CAN Init Failed");
CAN0.setMode(MCP_NORMAL);
pinMode(CAN0_INT, INPUT);
Now everything works great. The first module (silver) performs all functions. The second module (black) does not unlock, I think the problem is in the solenoid. The question about the brake pedal remained open.
Posted: Wed Jul 12, 2023 6:49 pm
by LRBen
VanGogh wrote: ↑Wed Jul 12, 2023 6:03 pm
Wouldn't be too hard to implement. We know what canbus is used to lock or unlock the knob, you could run the brake light voltage through a relay (So you don't send 12v into an arduino pin)to act as a signal for the arduino. When the brake light is on, send the canbus messages to unlock.
Posted: Sun Jul 16, 2023 8:51 pm
by VanGogh
Hello. If anyone needs a modified GEN1 code to connect the relay to the module buttons. Also added module highlighting. But I can’t find what data I need to send to the Can bus to block the knob in the P and R positions. And how to track when the ignition is off and the knob is down (I need this to restart the arduino)?
Posted: Mon Jul 17, 2023 7:22 pm
by VanGogh
LRBen wrote: ↑Wed Jul 12, 2023 6:49 pm
What message exactly unlocks and locks the knob? And what message does the knob drop down?
Posted: Mon Jul 17, 2023 9:16 pm
by LRBen
VanGogh wrote: ↑Mon Jul 17, 2023 7:22 pm
On Gen 1 I think just switching off ignition 12v will lower the knob. You should be able to lock it by just not sending any canbus messages.
Afraid it's been a while since I looked at this so I can't remember much. But all the information is on this thread. Experiment with it for the details.
Posted: Thu Jul 20, 2023 7:16 am
by VanGogh
Do you think the voltage on the start/stop button and the handbrake depends on the CAN bus signal or not? I apply 12V to pin 12 (Wake up). And on pins 7, 18 and 11-ground (start/stop) I get 0V. But according to GSMTSM - Pinout.pdf they must be under voltage. The same situation with manual brake, on pins 8,9,10,19,20 I get 0V. Maybe I need to send some kind of message to the can bus and wake up these outputs? Or these contacts work on the Lin bus
Posted: Thu Jul 20, 2023 7:12 pm
by nkiernan
VanGogh wrote: ↑Thu Jul 20, 2023 7:16 am
Did you check if the start button for example simply closes a switch, so continuity between ground and start_stop_1 when button is pressed?
Posted: Fri Jul 21, 2023 6:09 am
by VanGogh
This is not a simple switch. There is a resistor between the buttons and ground. When the button is pressed, there is no short circuit between ground and start_stop_1 or _2. The tracks from the buttons go inside the board and there is no way to track them
Posted: Thu Sep 07, 2023 1:24 am
by connor016
Great info here! I was able to get one working with an UNO and CAN shield with tom91's code for gen 2. It appears to all work without crashing except the sport mode does not engage. Below is a photo of the model for reference if anyone is looking for one:
I will try LRBen's code when I get a DUE. Note with the code above, you need to make the following changes as others noted that I missed initially (likely due to a newer library for mcp_can):
1) Add MCP_ANY in the setup loop:
while (CAN_OK != CAN0.begin(
MCP_ANY, CAN_500KBPS, MCP_16MHZ)) // init can bus : baudrate = 500k 8MHZ crystal
2) Add the following line at the end of the setup loop:
CAN0.setMode(MCP_NORMAL); // Change to normal mode to allow messages to be transmitted
Posted: Thu Dec 07, 2023 9:19 pm
by VanGogh
Hello. I looked at the logs from tom91 for Gen1. I don't understand. How does ID 312 turn 0x20 (locked) into 0x10 (unlock)? What command blocks the knob? If you look at Gen2 ID 02C there are two command 0x00 and 0x40 (D3). But they don't work for Gun1
Posted: Wed Jun 25, 2025 4:01 am
by Bogged
Hi guys,
I stumbled across this forum while searching for ideas to replace the LR dial shifter. Has anyone tried a BMW 8hp shifter and converting it to work with the LR/JAG harness/Box? I've busted the dial shifter and just want to go back to a shift style lever. Less to go wrong.
Thanks in advance!
Posted: Fri Oct 24, 2025 9:58 am
by einet
hello,
Frend i must repair may Evoque selector, but i have trayed to rebild this project
but i dont can put this to work, because i dont know what MCP library i must use.
i have tested some but on complie i become erros from this labrary MCP Can.
Can any sheare this library that work with this project on Adruino Nano ?
Posted: Tue Mar 03, 2026 2:29 pm
by HWS
I just bought this selector jlr gj32-7e453-ab. When I power it up on the bench, with just the kvaser on its canbus, it starts streaming just one message on the ID 0x1F0
0- 20
1- 00
2- 00
3 and 4 its a cyclic message, looks like some kind of check sum
5- 00
6- 00
7- 40
I just looked at the github projects and couldn't find any log that looks like it. Does anybody knows if the canbus payload can change if the selector came out of a Jaguar or Land Rover?
Posted: Mon Mar 09, 2026 11:15 pm
by HWS
One thing that I've found so far on the GEN1 GSM (jlr gj32-7e453-ab) I have here is:
ID 0x370
byte 6 = LED backlight dimmer (00 = 0% / FF = 100%)
byte 7 = LED backlight on (00 = off / FF = on)
We can adjust the backlight brightness. I didn't figured out any thing more yet.
