Page 5 of 5
Re: The LandYacht BMW E39 Saloon
Posted: Sat Oct 15, 2022 7:21 am
Inverter fitted. Collected the modified driveshaft and its a perfect fit. Spent yesterday on wiring integration with the VCU so with luck first wheel spins next week. Am in the process of sourcing a VW onboard charger so will need to hack that and with a bit of luck will make a new vcu module to run it.
Posted: Mon Oct 17, 2022 8:30 am
by philbrennan
Looking good. Curious on the charger change - current charging needs an upgrade?
Posted: Mon Oct 17, 2022 2:29 pm
Well part of why I build cars is as test beds for things I'm developing or hacking. Noticed there are very few options for low power on board AC charging so decided to give the VW a go as they are plentiful and cheap. May as well use the E39 for testing and development.
Posted: Mon Oct 24, 2022 5:02 pm
Posted: Mon Oct 24, 2022 9:09 pm
I saw VW Golf/Passat GTE hybrid inverter had DCDC converter inside. Very compact that one.
I dont know if ID has the same arrangement though.
Posted: Tue Oct 25, 2022 3:03 pm
Getting nearer. Added the CAN to the Zom VCU today to make the gear display work. Yacht now thinks she's an auto:)
Posted: Wed Oct 26, 2022 7:53 am
wow, very neat integration
Posted: Wed Oct 26, 2022 8:10 am
Nice and clean. Im sure this will drive quite well once on the road.
Posted: Thu Nov 10, 2022 6:57 pm
Made a little more progress on the E39. PCS wired in and cooling system refilled and bled. Getting near a first drive.
Posted: Wed Nov 16, 2022 8:49 am
On the road :
Posted: Sun Nov 20, 2022 1:41 pm
by Ev8
Nice to see that you still get the ev grin even after all these ev miles
Posted: Sun Nov 20, 2022 6:02 pm
by RetroZero
Man you make it look so easy. Must be Gom's influence. Like
