Page 5 of 10
Re: Switched ADC BMS
Posted: Sat May 06, 2023 8:18 am
This morning I made the decision
I will just add around 10 Ohm series resistance on each input. Then even if there is a glitch it will be limited to a few 100 mA. It's a rather pragmatic solution but as it seems to only be a power-on problem I think it is appropriate.
I might also lower the gate resistors somewhat.
Posted: Sun May 07, 2023 7:22 am
And just discovered another issue:
This is the voltages of my 40Ah ESS pack. When I installed the BMS 7 weeks ago, the delta was 5 mV. Now it is more like 50 mV.
I think this is caused by the resistive dividers of the mux being on there 24/7. The lower the cell, the more often will it see the little drain. Would be less pronounced in a car with less uptime but still, a BMS should never contribute to disbalance. Amazing what many 10k of resistance can draw over time.
Argh
EDIT: makes we wonder, could the mux control also be floating... gotta think about this.
Posted: Tue May 09, 2023 10:09 am
I'm redoing the topology now. Each P-FET pair will have its own opto coupler controlled from the LV side. The STM32 is directly connected to the 3-to-8 decoders. Adds the optos (5 cts each) but makes 3 74HC chips and 18 N-Fets redundant. I'm keeping the decoders to have a degree of hardware protection against SW bugs.
Posted: Tue May 09, 2023 12:15 pm
This would be the new mux design:
The two lower channels are NFETs and when turned on are connected to the cell 2
above it to always have sufficient gate voltage. The upper channels keep the PFETs that are pulled to the cell 2
below again fur sufficient gate voltage. This will draw an equal amount of current from all cells when doing a mux sweep, except the lower 3 cells. They deliver twice as much. I think I will compensate for that with lower pull down resistors on the upper channels.
And the according layout
Posted: Tue May 09, 2023 5:14 pm
by Jacobsmess
Apologies for my ignorance on BMS type things, but will this be a flexible option to manage any homebrew battery packs up to certain cell amounts? Thanks
Posted: Tue May 09, 2023 6:23 pm
by uhi22
Bipolar optos, with 10k load, can be quite slowly turn off, this needs to be considered for the blanking time. And maybe series resistors on the outp/outn would avoid smoke. And is it possible to place parts on the bottom side, to reduce the PCB size?
Posted: Thu May 11, 2023 1:23 pm
Jacobsmess wrote: ↑Tue May 09, 2023 5:14 pm
Yes, I already use it in that application (see my ESS thread under renewables)
uhi22 wrote: ↑Tue May 09, 2023 6:23 pm
Yes, will make sure to insert like 50-100us of blanking time, not a lot compared to the 25ms sampling time per channel.
JLCPCB only allow one sided population, double sided should indeed make the board a lot smaller.
I'm SO sure that I will no longer have glitches now that I omitted the resistors - will regret later
I have also now gone over all mux states and calculated the total current draw through the pull-up resistors. The very first and very last channel see the least draw, also the 2nd one sees a bit less and the middle ones all have the same. I have changed the resistors to compensate for that, the upper-most channel needed an extra 2k4 resistor switched in to be on par. Now I'm at 54mAh/year between the cell that sees the least and the most draw (assuming 24/7 ontime)
Posted: Thu May 11, 2023 4:44 pm
by Jacobsmess
johu wrote: ↑Thu May 11, 2023 1:23 pm
Thanks, would it be possible to setup to manage a 96s pack? I need a BMS system for my planned pack of 32 IPace modules (3S4P)
Posted: Fri May 12, 2023 8:12 am
Alright, alright, series resistors added
Jacobsmess wrote: ↑Thu May 11, 2023 4:44 pm
Yes, it is stackable. Gotta do a bit of testing with the latest revision to make sure it no longer blows up, then it's ready for sale.
Posted: Fri May 12, 2023 5:14 pm
Took 5 days to put the cells back in balance:
Posted: Wed May 17, 2023 1:59 pm
by Proton
@Johu
are you continuously balancing the cells? because that will imbalance the cells. For my solar system I have an active balance that can be setup when to start balancing. my cells are LiFePO4 3.2v and I setup the balance to start balancing only when cells reach 3.40v.
Posted: Wed May 17, 2023 3:12 pm
I also start balancing above 3.8V, in that region soc/voltage curve is steep
Posted: Wed May 17, 2023 8:57 pm
by Proton
LiFePo4 are full at 3.43V. but they can go to 3.65V. 3.4V / 3.65V = 93% charge.
Li-Ion 3.8V / 4.2V = 90% I think you can start at 3.9. But again, I only have experience with LiFe batteries.
Is this BMS going to work with LiFe Batteries ? I do not intend to ever use Li-Ion Batteries. The new Mercedes Sprinter coming this summer is going to use LiFe batteries.
Posted: Thu May 18, 2023 8:15 am
by chentron
johu, how much time for the birth ? days , weeks , months ?
Posted: Thu May 18, 2023 1:35 pm
by EV_Builder
johu wrote: ↑Wed May 17, 2023 3:12 pm
No so steep you mean?
Posted: Thu May 18, 2023 4:08 pm
Proton wrote: ↑Wed May 17, 2023 8:57 pm
That is software-defined really. The ADC accuracy is high enough to do an open voltage estimate of SoC even for LFP batteries.
chentron wrote: ↑Thu May 18, 2023 8:15 am
weeks, I think. New revision is currently on its way. If it's stable I could start selling boards. Software is not 100% there but good enough for tracking min/max cell voltage (and individual cell voltages of course) and Coulomb counting. Software is 100% open source so others can chime in
https://github.com/jsphuebner/FlyingAdcBms
EV_Builder wrote: ↑Thu May 18, 2023 1:35 pm
What I mean is at 3.6V recent NMC chemistry has a plateau, so 30% is 3.6V and 40% is 3.65V or something so 5 mV/%. Above 3.8V this becomes steeper, say 3.8V is 70% then 3.9V is 80% i.e. 10mV/%. So differences in top balancing are more visible in the upper voltage range.
Posted: Sat May 20, 2023 12:38 pm
by janosch
I hope I will have time to contribute to the software side.
It will be a version of the chglim/dislim, built upon my thoughts here from December:
viewtopic.php?t=2861
Posted: Mon May 22, 2023 5:18 pm
Yes, that would be great. Will come up with a list of things that I can think of.
I have received the new boards and hooked one up. Worked out of the box this time.
Next I will assemble a test battery to test two modules in cooperation. The thing that didn't work back in London.
STM32 had a little surprise for me: PB4 is tied to JRST (jtag reset). So you need to turn jtag off. But in order to do that you need to enable the AFIO clock. Took me a few moments to figure out...
Posted: Mon May 22, 2023 6:10 pm
by Proton
I would love to buy and test one of those on my solar system. My current BMS is working perfectly but it has Bluetooth and I always have to use a phone with GPS enabled to see what is going one. Would be nice to replace that.
Posted: Mon May 22, 2023 7:39 pm
Proton wrote: ↑Mon May 22, 2023 6:10 pm
Sure, did you say you were going to order something anyway? Can just throw one in. WIP as always but certainly sufficient for obtaining min/max cell voltage over CAN
Posted: Mon May 22, 2023 8:07 pm
Thought I'd just summarize current state of affairs and plans
EDIT: this will be maintained in the opening post
viewtopic.php?t=2338
Posted: Mon May 22, 2023 8:29 pm
by Proton
johu wrote: ↑Mon May 22, 2023 7:39 pm
Unfortunately my order is already on the way.
Posted: Sat May 27, 2023 2:28 am
by mackoffgrid
johu wrote: ↑Sun May 07, 2023 7:22 am
Argh
I don't see how this could be the problem unless your control mosfet is not off fully?
Posted: Tue May 30, 2023 10:38 am
mackoffgrid wrote: ↑Sat May 27, 2023 2:28 am
The gates of the P-FETs are pulled to the voltage they are switching with a 10k pull-up resistor. E.g. gate of FET for V7 is pulled to V7. To turn on the gate is pulled to V0 by its N-FET companion via another resistor, say another 10k. So now current is circulating through two resistors pulling like 1mA from cells 0-7. It means cell 0 sees all turn-on currents, cell 1 sees 15 out of 16 and cell 15 sees just 1. You could say cell 0 sees a constant draw of 1 mA and cell 15 of just 1/16 mA. That's how they get disbalanced.
With the new topology that is mitigated.
Apart from that I just checked the displayed cell voltages against my multimeter and found cell 1 always reads 10 mV low. The others are correct.
Posted: Fri Jun 02, 2023 10:12 pm
by mackoffgrid
johu wrote: ↑Tue May 30, 2023 10:38 am
Thanks, I misunderstood. The imbalance is not happening while the circuit is shutdown.
