Jack Bauer wrote: ↑Wed Jan 22, 2020 7:40 am
Just where does this stop? I designed a board to run the Gen 2 inverter. It's through hole for easy soldering. It uses a cheap bluepill board for the mcu. I built it. I tested it. I made video of it running. I uploaded the complete design to Github. I sell the bare boards almost at cost. A programmed bluepill and wifi are available from Johannes. Youtube is full of videos about how to use an st-link to program a bluepill. If the community can't get behind something as simple as this and make it work there is nothing more that I can do. Sure, I could make an SMD version and get JLC to build it. But why does it always have to be me? This stuff is not rocket science. Don't have the skills to do that? Go on Fiverr and pay a guy 50 bucks : https://www.fiverr.com/
I really am losing the will to continue at this...
I am sorry JB i didnt mean to imply your design is not good. I have tested ONE Bluepill chip directly on its pins and i couldnt get Wifi to work with D1. I too have limited time and i am used to a certain way of testing, so i didnt pursue it further. It is just my way of helping people not to loose faith in DIY.
Like you i dont want to get hung on something that was already figured before... have to test the limits, go beyond where no one has gone before.... . Well maybe Toyota engineers have been there before. Bang! LOS!
Re: Toyota Prius Gen 2 Inverter Controller
Posted: Wed Jan 22, 2020 11:39 am
by MattsAwesomeStuff
Jack Bauer wrote: ↑Wed Jan 22, 2020 7:40 amIf the community can't get behind something as simple as this and make it work there is nothing more that I can do. Sure, I could make an SMD version and get JLC to build it. But why does it always have to be me?
It doesn't. And it shouldn't.
That's exactly why I've never messaged you or complained about you. Because you've done more than enough. I wouldn't even have started this without the work you did. I would've abandoned using an AC motor and gone looking for an old DC one.
It's why I've never called out anyone else specific either. I'm not entitled to anyone's help. It was made clear at the start, this is not a finished product, this is not an easy project.
I am attempting to set a good example by contributing as much as I can, in the ways that I can. I have spare time and effort, but lack competence.
Perhaps, but it is by observation, beyond my ability. I don't know why I'm currently stuck, but I'm stuck. I don't know why it's taken me a couple months to follow directions, but it has. I assure everyone I am not deliberately sabotaging my own success for pedantry's sake.
I think the people in the community who can figure this out for themselves are mostly here, and number perhaps in the dozens. And that currently excludes me. If that is the ceiling of this project's efforts, that's okay.
If I can, I aim to be part of bridging things so that a thousand people can follow lower level instructions and find it within their ability.
Posted: Wed Jan 22, 2020 12:18 pm
Lets be clear about something MattsAwesomeStuff, at my first unsuccessful attempts with DIY inverter i was angry at myself and at Johannes because of reversed transistor pinout and about test protocol blowing my IGBT stuff and especialy about unprotected drivers... But i realized then and there not many people have done what he and JB have done. That was some (b)leeding edge Magellan work at DIY!
So i directed my anger at learning myself to draw PCBs and made myself a protected driver board, a design which is standard for all automotive inverters. You guys who are now dealing with Toyota, Volt and Leaf stuff do not even realize how much design knowledge you are spared from because of this. And of course ton of $$$.
Be patient, like i said lots of times, DIY will save you $$$, but will balance that by time spent studiying plans and figuring out application.
My 5c...
Posted: Wed Jan 22, 2020 2:06 pm
JB or others,
how are PWM outputs used on Gen2. The way it looks from schematic the HIGH side is commanded by active signal to NPN transistors pulling LOW gate signals on Prius driver board. Is that correct?
Now what happens to the LOW side signals? This means that if there is no other signal the LOW side is active all the time? Quite ingenious since that would eliminate shootthrough.
I need that info to prepare my version of Rev2 board...
Posted: Wed Jan 22, 2020 2:28 pm
by Dilbert
Yes that's how the GEN2 inverter works, we only need to control the 3 high side switches in the inverter. To turn on the high side switch we pull the input low, when we release the input the high side switch will turn off and the complementary low side switch will turn on automatically. The logic inside the gen2 inverter takes care of the deadband between the high and low side switches etc..
So with the GEN2 the blue pill will only output the 3 high side PWMs.
Posted: Thu Jan 23, 2020 2:44 am
arber333 wrote: ↑Wed Jan 22, 2020 12:18 pmThat was some (b)leeding edge Magellan work at DIY! So i directed my anger at learning myself
To be clear, I'm not angry at anyone for anything. No one said "You will succeed if you do this". They said "I've put time into doing this even though I'm not using it, and it seems to work for me. You're welcome to copy it and try. I'll even sell you boards for it near cost."
Towards myself, I feel a bit like I jumped the gun and bit off a bit more than I could chew, and maybe like I picked the wrong horse considering my capabilities, but that's fine. Either way I wanted to get working on something, and if I screwed up through-hole parts I would've butchered the SMD Gen3 even more.
I think if this was 2 years ago when you were doing this, my solution would have been to not even attempt AC and try to find a DC motor instead.
I think you're probably not just right, you're right about me not being able to realize how much harder it could be.
Again, I'm not upset, I'm just stuck and I'm not sure what to try next other than just re-ordering and starting over. But the Gen3 boards with the onboard hardware to control charging seem so promising that I might end up going that way if I'm just starting over. Kiwifiat mentioned he's got some D1's on the way and he's going to be trying the Blue Pill/D1 combo just in case that's the problem, but, if that doesn't bear fruit I'm stumped.
Anyway, I think people have focused too much on the negative. My point on the Gen3's was... since I can't think of any way to put effort in to make my Gen2 work, and Damien just posted the availability of the Gen3s v2s, I'm going to use my spare time to try to help out with the documentation on that too. So I seeded the wiki and started asking questions that I have and that I think others would have if they ordered one.
Posted: Fri Jan 24, 2020 11:04 am
by konstantin8818
As I'm not an elecrtinics enginer I've got few questions according to Damien's board and preprogrammed blue pill:
For prius PMSM incremental encoder is "no go". It need absolut encoder or resolver. Can this board handle absolut encoder or it is not designed for PMSM?
Posted: Sat Jan 25, 2020 2:05 am
by kiwifiat
MattsAwesomeStuff wrote: ↑Thu Jan 23, 2020 2:44 am
Ok , so my WeMos D1 mini's turned up yesterday and today I had a go at installing both the Huebner web interface and Dima's version. First I flashed a bluepill with https://github.com/jsphuebner/stm32-sin ... 32_foc.hex and a cheap STLink.
Greeted with a flashing green heartbeat from the onboard led I connected a usb -> ttl adapter to the bluepill using this image as a guide:
Having confirmed that I was able to communicate with the bulepill via a serial console I then proceeded to setup the Arduino IDE for use with ESP8266's using Arber's guide earlier in this thread. After flashing the sketch and web data to the D1 mini I was able to connect to the open wifi and the set the access point name to openinverter and set a password. The next step was wiring the serial connections between the bluepill and the D1 mini, again per the posted image from the "Johannes in a Blue Pill" thread. Reconnecting to the D1 mini using the SSID and password I was able to point my web browser to 192.168.4.1 and Johannes web page appears and is fully functional.
Next I tried Dima's web interface using the esptool.py method and the bin file from Dima's github labled for the wemos board. Although the tool reported flashing both the sketch and the spiffs I could not see any wifi instance show up on my computer so that was a fail. Not to be defeated I then tried using the over the air tool espota.py which again reported success but sadly no wifi to connect to. As a last ditch effort I tried again using the bin file ment for the Olimex board and that worked. I have no idea why the wemos bin file doesn't work, possibly I have the memory allocation set wrong as a hangover from the arduino ide configuration. Possibly Dima could chime in?
In any case the bluepill and wemos d1 is a working solution and Damien's Gen2 board and the last bluepill firmware with resolver support will run a PMSM provided you breadboard together the resolver circuitry as Johannes did in one of his YouTube videos. I would suggest using the circuitry from the latest version of openinverter but it is pretty simple and should not represent much of a challenge to an electronics hobbyist.
So a few questions for Matt:
Do you have a heartbeat on your bluepill?
Do you have a common earth between the D1 mini and the Bluepill?
How are you powering both devices?
Posted: Sat Jan 25, 2020 8:11 am
Well thank you sir!
I focused so much on wifi gizmo that I forgot to check the Linux interface. So you get info from wifi interface? How about if you provide 3v to brake pin and other active input pins? Change of state you can see in the interface if you refresh.
Tnx
Posted: Sat Jan 25, 2020 11:15 am
kiwifiat wrote: ↑Sat Jan 25, 2020 2:05 amSo a few questions for Matt:
What are we defining as a heartbeat?
When I connect 12v and GND to my power supply, I get a red and a green light that stay on. If I hit the reset button the blue pill, the green light turns off while I'm pushing the button.
I believe so.
I have used the UART terminals on the Control Board where Johannes' wifi board normally plugs in. I'm using GND, 3.3v, RX, and TX. So, if the D1 is getting it's power from the Control Board, yes.
When I tap the reset button on the D1, a blue led blips on the D1.
I can connect to the wifi and load the web interface, but it doesn't show any parameters like I see on other people's screenshots. So the D1 is presumably working.
I'm powering the control board via a variable bench supply. I'm giving it 13.8v as a lead-acid battery would have. The D1 gets 3.3v power from the pins typically connected to the Olimex wifi board.
Other than being powered, I can't tell that the Blue Pill is in any way operational. I do not have a UART-anything other than the D1 which I connect to over wifi.
You mention you connected via serial and it responded to commands. Are there any commands that can indicate to me that it received them?
Thanks for your help.
Posted: Sat Jan 25, 2020 3:41 pm
One LED (typically green) has to flash in 100ms cycles. Before that isn't happening no need to go further. Re-check your flash procedure.
Posted: Sat Jan 25, 2020 4:06 pm
by SciroccoEV
My Blue Pill arrived with 'blinky' code already on it, so perhaps a double blink to show the code is running?
I apparently had no problems using a generic STLink clone to flash the code, but it's still sitting on a breadboard waiting for me to hook up an interface to see if the code is actually running.
Posted: Sat Jan 25, 2020 6:52 pm
johu wrote: ↑Sat Jan 25, 2020 3:41 pm
When I plug in my Blue Pill to the ST-LInk, it also has both lights stay on.
I just ran ST-LINK on it again, this is what it shows:
However, both LEDs are on solid, ditto from when I remove it from ST-LINK and power the Prius Control Board from 12v. No changes.
Posted: Sat Jan 25, 2020 7:12 pm
Can you scroll up? Did you flash stm32_loader.hex
Posted: Sat Jan 25, 2020 7:20 pm
johu wrote: ↑Sat Jan 25, 2020 7:12 pm
Yeah..... i forgot to stress that in the instructions. With STlink utility you use hex files to programm the chip. Sorry.
You can use .bin files with phone utility though.
A
Posted: Sat Jan 25, 2020 8:28 pm
Me?
No.
I followed these instructions (up until he starts doing his own stuff with what he flashed):
And the only thing I downloaded and flashed was the STM32_sine.hex file.
Did I skip steps?
Posted: Sat Jan 25, 2020 8:57 pm
Here is an excerpt of a guide I made some years back on programming the Tesla boards. Its a bit dated but might clear the air. If not I'll make a video tomorrow.
Firstly, you will need an STLink USB programmer like this one : https://www.aliexpress.com/item/FREE-SH ... STM8STM32-
STLINK-simulator-download-programming-With-Cover/1810358353.html?
And you will need the free STLink software : http://www.st.com/en/development-tools/st-link-v2.html
Download and install the USB driver first : http://www.st.com/content/st_com/en/pro ... menttools/
stm32-software-development-tools/stm32-utilities/stsw-link009.html
Then the STLink programming utility : http://www.st.com/content/st_com/en/pro ... menttools/
stm32-software-development-tools/stm32-programmers/stsw-link004.html
Connect the stlink dongle to the jtag header with 4 leads. +3v3 , GND, SWCLK and
SWDAT.
...and plug the usb into your PC.
Open the STLink programming utility and click the “Connect to the Target” Icon.
Click binary file and load stm32_loader.hex Program this with the "Skip Erase Flash" box
unticked .
Now load stm32_sine_.hex with the "Skip Erase Flash" box ticked.
The LED should start flashing after the program has finished loading and away you go.
Posted: Sat Jan 25, 2020 10:07 pm
unticked .
It appears I did miss a step this whole time.
I didn't find a STM32_loader.hex program. Who wrote/where do I get that?
Posted: Sat Jan 25, 2020 10:40 pm
by Stephen Darbey
Finding this thread very informative and interesting, so much on friday was passing a scrappy I frequent and called in. Foe some reason I see these places as most people see libraries. Yes, you guessed it. He had a Gen2 not in the least pricey. Will check to see if there are any pcbs on evbmw.
Should this work out, and I see no reason why not, it will be the cheapest of all set ups.
I just gave myself another project.
Apart from increasing my knowledge what can possibly go wrong ?
Posted: Sat Jan 25, 2020 10:45 pm
by Alexstarex
in the picture is 1st generation. Need an inverter 2 generation
Posted: Sat Jan 25, 2020 11:00 pm
by SciroccoEV
I was under the impression that anything bearing the 'Hybrid Synergy Drive' badge was Gen-2.
And go to the Boot Loader folder, you can find the STM32_Loader.hex file.
Flash that first, then flash the STM32_sine.hex next.
Of note, Damien's exact instructions didn't work for me. He says when you do the second programming file, the sine wave file, to select the "Skip Erase Flash" box, but if I did that it gave me errors. It seems to have worked with it left unticked both times.
I'm now getting pages and pages of parameters on the landing page. Hurray!
Tangential issue: Did I miss instructions, or are they not there to follow?
I.E. If I'm just dumb, carry on. If the instructions aren't there to find, can I help write them or make them more accessible?
Next up, umm, I guess back to trying to get a motor spinning. Yay!
Posted: Sun Jan 26, 2020 12:57 am
by sfk
You have a lot of perseverance. Keep it up
Posted: Sun Jan 26, 2020 2:32 am
by Igor
Posted: Sun Jan 26, 2020 3:23 am
by kiwifiat
MattsAwesomeStuff wrote: ↑Sat Jan 25, 2020 11:15 am
Glad you got it working.
As you have discovered when the firmware is correctly flashed the onboard led flashes on and off at 100ms intervals. Once you get to that point you can test the serial communications using the "get" and "set" commands as outlined in the "Parameter" section of the main openinverter.org page or https://openinverter.org/wiki/Schematic ... structions using a USB -> TTL adaptor making sure you set the communications parameters correctly to 115200 8N2, note the 2 stop bits. It is possible to use the D1 mini as a serial console via the arduino IDE but I guess if all goes as it should it is an unnecessary step.
