Page 5 of 10
Re: Prius Gen2 Adapter Board for CHARGING
Posted: Fri Mar 12, 2021 5:58 pm
by Pcstreet
OK thanks I think there is something wrong with the inverter as it will go into run mode and boost mode but not buck mode. I have ordered another inverter so will try again when I get this one. I bought the first one in a unknown condition and I have not been able to get the 12v dc to dc side working. Will post again once I have retested with the new inverter.
Posted: Wed Mar 24, 2021 5:27 pm
by LRBen
johu wrote: Tue Jan 19, 2021 5:17 pm Those things are now fixed. Mind you, the power factor is probably not great, most of the sine wave remains unused as is usual with buck chargers. But it charges :)
I'm just about to start to look into the practical side of charging on my project now and I have been looking over this thread again. I just had a question about the power factor that you mentioned there. What are your thoughts on using this as a daily charger for a car given the power factor? Would the power factor affect performance enough that it might be better to use say the Eltek 3kw chargers that seem to be pretty cheap second hand?
Posted: Sun Mar 28, 2021 6:02 pm
by LRBen
Ok I've been reading through the wikis, posts and watching the relevent youtube videos on repeat today. Ended up with what I think is a overview of the charging process. It looks like one or two things have changed over time.
Is this an accurate overview of the current state of charging with the gen 2 inverter?
Relevant Parameters
  • Charge mode:Buck
  • Chargecur: 1.5
  • Chargekp 20
  • Chargeki: 10
  • Chargeflt 2 dig
  • Charge pwmmin: 10 (Change this to get equivalent to min battery voltage.)
  • udcswbuck: x (HV bus voltage at which point Ground signal is used to control AC and HV battery relays)
Relevant Pins
  • CSDN (pin 29 on inverter)
    Shuts down high and low IGBTs when fed 12v, via 470R
    When CSDN is HIGH both IGBTs are OFF.
  • CPWM(pin 31 on control board, 13 on inverter)
    Enables charge mode when fed 12v via 470R
    When CPWM is HIGH, the LOW side IGBT is on(shorts out battery), when CPWM is LOW the HIGH side IGBT is on.
  • Forward and reverse (11 and 12 on control board)
    Both must be high to enable charging
  • DCSW switch(15 in control board)
    Controls DC relay switch.
Physical setup
  • 240v AC plugs into two MG1 phases, with a precharge resistor always on.
    Relay controlled by DCSW pin connected to ground side of relay signal wires.
  • HV Battery connected with precharge resistor
    Relay controlled from DCSW pin connect to ground side of relay wires.
  • CPWM to 12v via 470R resistor.
  • CSDN pin to 12v via 470R resistor. Ground side connected to DCSW pin.
    CSDN pin also tied to DCSW signal pin.
Process
  • Fwd and reverse signals high, relays open
  • CPWM and CSDN pulled high.
  • Connect AC input voltage with precharge
  • DCSW will then close relays and pull down CSDN pin to activate charging.
  • Activate buck on charger. By manual web interface or does just having FWD and Reverse high activate this?
  • To stop, can change chargecur to 0 or switch off inverter power.
Posted: Sat Apr 03, 2021 11:01 am
by LRBen
One further question I have regarding the DCSW pin and relays. So from what I understand the DCSW switch can be used to close the AC relay once the HV bus is up to voltage. But the DCSW is also used to close the battery side contactors. So I thought this might cause some issues if the precharge on one side was done before the other.
However now I think about it, the HV bus should be common to both MG1 input and the battery inputs. So it isn't a question of precharging each side, it's just about charging up the HV bus. Is that right or have I got the wrong end of the stick?
I'm just trying to source some AC relays for my own setup. Is there a part number for that Leaf board you used for AC precharge and relays?
Posted: Sat Apr 03, 2021 1:15 pm
Forgot to comment on that one. Very good you wrote it up.
LRBen wrote: Sun Mar 28, 2021 6:02 pm [*]CPWM to 12v via 470R resistor. Controlled with a physical switch?
[*]CSDN pin to 12v via 470R resistor. All the time?
[*]CPWM pulled high. Can add switch. (Or always on via 470R?)
Yes CPWM should only be pulled high when you actually intend to charge, likewise CSDN. That way the upper IGBT stays closed and allows regen current to exit the inverter.
LRBen wrote: Sat Apr 03, 2021 11:01 am However now I think about it, the HV bus should be common to both MG1 input and the battery inputs. So it isn't a question of precharging each side, it's just about charging up the HV bus. Is that right or have I got the wrong end of the stick?
When charge mode is set to buck the inverter precharges to "udcswbuck" instead.
Posted: Sat Apr 03, 2021 2:17 pm
by LRBen
Thanks for confirming that. That makes sense. I have updated my post and added the section to the wiki.
johu wrote: Sat Apr 03, 2021 1:15 pm When charge mode is set to buck the inverter precharges to "udcswbuck" instead.
Ah I see, So I am guessing there that the udcswbuck would be for when the AC is connected to MG1 and that voltage would be higher than the battery voltage. So the HV bus needs to precharge to that higher voltage?
Posted: Sat Apr 03, 2021 3:03 pm
Yes exactly.
Posted: Sat Apr 03, 2021 3:07 pm
by LRBen
Brilliant, that all makes sense now!
Posted: Mon Aug 30, 2021 9:29 am
by RetroZero
Question not too dumb (I think)...
Does Mg1 motor need to be disconnected from circuit before using the Charge function? Basically, if I were to run both Mg1 and Mg2, I would need to make a HV Contactor box for seperating Mg1 motor before charging?
Posted: Mon Aug 30, 2021 12:41 pm
Yes, grid 400V AC into the motor is not good ;) (probably just trips your house fuse)
Posted: Tue Aug 31, 2021 1:08 pm
by NiHaoMike
Might be interesting to explore the idea of using MG1 as an inductor for charging, just like the Renault Zoe. Easy way is to add a bridge rectifier with the output connected between phase B (since phases A and C have current sensors) and HV ground.
Posted: Tue Aug 31, 2021 4:22 pm
by RetroZero
I am looking for firstly, a short term solution, to recharge my prius battery for testing purposes. So if MG1 is not in use, I can hard wire in the current solution.
However, I will be running dual motors in the end, so it looks like an external charger will be better suited, since bridge rectifiers will set off alarm bells with my TUV equivalent regulations here.. Another Inverter is too much waste I feel.
Posted: Fri Sep 17, 2021 4:48 am
by kon
I ran into a strange issue while testing charge mode.
When using 24V from a powersupply everything seems to work OK.
However, things didn't quite work when I switched to 110VAC:
A few seconds after plugging in the 110VAC (U and W on MG1, 30Ohm precharge resistor always on) the AC contactor closes (udcswbuck set to 160V)
However, the board reports a DESAT error and I see 160VDC on the HV battery bus and 0VDC on the DC bus.
I have nothing plugged into the HV battery bus, since I want to charge a 12V lead acid battery (for testing) so 160VDC wouldn't be great.
As soon as I unplug the 110VAC from MG1 the DESAT error is gone.
Any idea where that DESAT error is coming from?
Posted: Fri Sep 17, 2021 6:29 pm
What are your charger parameters? Did you measure the two voltages with a meter? The board itself can only measure one of them.
Posted: Fri Sep 17, 2021 8:30 pm
by kon
Yes, measured with meter on copper bus bars.
Charger Params:
Charge mode:Buck
Chargecur: 2
Chargekp 20
Chargeki: 10
Chargeflt 2 dig
pwmmin: 7
pwmmax: 9
udcswbuck: 155
Posted: Sat Sep 18, 2021 4:12 am
by kon
quick update: So the DESAT error was due to the 12V supply drooping when the contactor closed. Replaced it with a solid 12VDC supply and no more errors.
I see 164.8VDC on the DC bus and 164.2V on the HV battery side.
pwmmin is set to 7.18, pwmmax to 9.0.
I was expecting the regulation to only happen within the min-max window (11.8VDC and 14.8VDC), even without a load/battery attached. I changed the pwmmin and pwmmax values but they seem to have no effect on the HV battery bus voltage. What pin has the PWM signal that's used to control the charging voltage?
parameters attached.
firmware 5.06.R-foc
Posted: Sat Sep 18, 2021 7:18 pm
Try loading the output with a cooker element or something.
Posted: Sat Sep 18, 2021 8:21 pm
by kon
Is CPWM supposed to stay pulled high with 470ohm at all times when charging?
Posted: Sat Sep 18, 2021 9:04 pm
by LRBen
kon wrote: Sat Sep 18, 2021 8:21 pm Is CPWM supposed to stay pulled high with 470ohm at all times when charging?
Yes I believe it is.
Posted: Sun Sep 19, 2021 5:54 am
by kon
My bad, I had the wrong pin pulled up high. My HV battery bus voltage is now within the expected window. The charging current however is not where I'd expect it to be. I set it to 1A and saw 2.5A output. Set it to 5A and 10A and also got 2.5A both times. When increasing pwmmax to 10 and max charging current at 10A I saw it spike to 30A and then settle at 26A. All currents were measured with a clamp meter on the HV battery bus cable going to the 12V lead acid battery.
Posted: Sun Sep 19, 2021 10:13 am
Yes in buck mode chargecur (well, rather unintuitively) refers to the INPUT current as that's where the current sensors are located.
Posted: Sun Sep 19, 2021 2:33 pm
by ZooKeeper
johu wrote: Sun Sep 19, 2021 10:13 am Yes in buck mode chargecur (well, rather unintuitively) refers to the INPUT current as that's where the current sensors are located.
That is actually good for my application to avoid overloading the weak US circuits! I never considered installing an element on the battery side to test charging, I will do it! 8-)
Posted: Sun Sep 19, 2021 5:00 pm
by kon
Got it.
Just to recap:
When in charge mode the PI loop regulates the pwm duty cycle within pwmin and pwmax which changes HV battery voltage to achieve set charging current (on AC input).
There is no upper current limit for the input, right?(in case the PI loop freaks out due to poor tuning)
Is there a way of approximating the DC charging current on the battery side based on the other known parameters?
Posted: Sun Sep 19, 2021 6:18 pm
by ZooKeeper
kon wrote: Sun Sep 19, 2021 5:00 pm Is there a way of approximating the DC charging current on the battery side based on the other known parameters?
Watts in ~= Watts Out???
Posted: Sun Sep 19, 2021 9:19 pm
kon wrote: Sun Sep 19, 2021 5:00 pm There is no upper current limit for the input, right?(in case the PI loop freaks out due to poor tuning)
Yes recap is correct. There is a hardware limit implemented in the Prius hardware, therefor there is no further (configurable) current limit on the control board itself.
ZooKeeper wrote: Sun Sep 19, 2021 6:18 pm Watts in ~= Watts Out???
Yes that would be possible, for display purposes at least.
